Coming full-circle... Solo Lobo's next project - 1984 R100RS
Discussion in 'Airheads' started by Solo Lobo, Feb 28, 2018.
  1. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    11,434
    Shoreline, WA
    Heat sink paste done... this shot is before I cleaned everything and put it back together
  2. Dreem Ride
    Dreem Ride Adventurer Supporter
    Dec 5, 2016
    56
    Seattle, WA
    Can the ignition module display an intermittent failure?
  3. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    6,566
    any electronic device can go intermittent if it has a heat problem
    you didn't have to go that far. Just take the ignition module off.. Usually craps out when hot, comes back when it cools down.
    forum screwing up. I was replying to two posts.
  4. Solo Lobo
    Mar 16, 2004
    11,434
    Shoreline, WA
    I did the re-pasting when I had the bike apart last year, the module literally fell off when the bolts were undone.
    I have an NOS module in my part stash, and if the issue repeats itself I will probably toss it on for fun. I need to check the coils as well.
    No time for these things until the weekend.
  5. Cogswell
    Cogswell Now living the new normal.
    Jan 3, 2005
    10,414
    Riding with my pal Richard Cranium
    If you have a heat gun you could warm parts individually to see if anything goes open circuit. :dunno
  6. Plaka
    Jun 19, 2010
    6,566
    That game works a little better the other way. You chill parts individually and see what comes back to life. Chiller spray takes components to sub zero temps. The cans of chiller spray have wands on them like carb cleaner so you can be very precise.
  7. Solo Lobo
    Mar 16, 2004
    11,434
    Shoreline, WA
    Well, made it to the office today, the RS ran great and had a deeper exhaust note... must be timing that changed the tone.
    spo123, kenbob, mbanzi and 8 others like this.
  8. Tiggum
    Tiggum Retired
    Mar 2, 2015
    473
    Nashvegas
    Since you didn't post anything, we will assume that you didn't find anything; we are awaiting further reports.......
  9. Plaka
    Jun 19, 2010
    6,566
    it would be more fun to make some stuff up...
    Solo Lobo likes this.
  10. Solo Lobo
    Mar 16, 2004
    11,434
    Shoreline, WA
    Actually, see my earlier post where I found the screws holding the female wire connections onto the coils were loose and corroded... all four of them with the power supply having the most rust.
  11. Plaka
    Jun 19, 2010
    6,566
    To be honeat I wsn't overly impressed with your clean-up job, Any corrosion you leave will breed more. I would have used a dip rather than a brush.
  12. Solo Lobo
    Mar 16, 2004
    11,434
    Shoreline, WA
    Understood Plaka, the plan is to replace those screws shortly with new... that's why the cleaning wasn't 100%
    WRC51 likes this.
  13. Plaka
    Jun 19, 2010
    6,566
    Ah so. That is the best way because it preserves the plating. Acid dip does not.
  14. Solo Lobo
    Mar 16, 2004
    11,434
    Shoreline, WA
    OK, where was I??
    The RS seems to be working fine, the exhaust note seems deeper and less sharp than before I changed the can. When I get to 500 break in miles, I'll re-check the timing when I change the fluids and filters
    Since I found the bearing for the old-style throw-out assembly and want to swap that back in, I figured I would also replace the clutch friction disc (which measured OK, but wasn't as new) but mostly I wanted to change the spring as the best I had was at the bottom end of the allowable range
    kenbob and Bigger Al like this.
  15. Solo Lobo
    Mar 16, 2004
    11,434
    Shoreline, WA
    One more update, you may remember that the frame tabs to retain the left sidecover broke off, oddly enough the sidecover had the perfect hole to retain the cover with a zip tie
    Just discovered that this weekend
  16. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,844
    Clever!
  17. ME 109
    ME 109 Long timer
    Jun 25, 2009
    8,709
    Albury Australia
    Somebody already drilled the hole for the cable tie.
  18. Solo Lobo
    Mar 16, 2004
    11,434
    Shoreline, WA
    Well, when it rains it pours.... (see my R65LS thread as well to see what I did there)... brake felt a bit squishy on the way home yesterday...
    found this:
    That upper line put up a real fight when I removed the old lower line, and I am not really surprised there is an issue... need to find a replacement fast as the LS also suffered a brake fluid leak yesterday
  19. Solo Lobo
    Mar 16, 2004
    11,434
    Shoreline, WA
    Part in hand
    Something like this
    Once that was installed, I went to test-fit the most seriously cool tank cover I think I have ever seen
    Figured there would be a problem
    Too small an opening for the gas cap. Might have this modded a bit to work
    Using the hold-the-lever-down-with-a-zip-tie bleeding method now, after pumping out lots of bubbles and will ride to work tomorrow.
    The LS parts arrive late next week I think...
    ME 109 likes this.
  20. Tiggum
    Tiggum Retired
    Mar 2, 2015
    473
    Nashvegas
    Actually, Tuesday is what I was told.....
