Continental Trail Attacks..shimmy?
Discussion in 'GS Boxers' started by JStancampiano, Jul 17, 2008.
  1. JStancampiano
    JStancampiano PhotoJoe
    Sep 20, 2006
    527
    N GA Mts
    I just replaced my worn Anakees with a set of Conti Trail Attacks and noticed the front end shimmys, worse at 40 to 50 mph. Has anyone noticed this and/or found a solution? My front wheel has about 1.5mm laterial runout which hasn't cause much of a problem in the past (really worn and cupped Anakees would also shimmy slightly).
    I have tried different air pressures and suspension settings and am beginning to suspect that this is the nature of this tire.
    Joe
  2. Norsman
    Norsman ...a GSophile
    Dec 5, 2004
    2,724
    Plover, WI
    It's the tire. Several threads have popped up , including mine, with this same problem. Apparently, not all Cont. Trail Attack tires are the same... many with the same bike, same tire, same conditions profess that they have no problem at all.
    I think Continental had a bad batch or they get them from different sources.
    edit: After 5,000+ miles mine still shimmys
  3. Firefight911
    Firefight911 Long timer
    Apr 16, 2007
    1,000
    Rancho Cordova, CA
    Have not experienced this whatsoever on my '07 R12GS Adventure.
    Take a good look/eval of your riding. Loosen up on the bars, tighten your core, get your weight off the bars, etc.
  4. duckboy
    duckboy Been here awhile
    Nov 6, 2004
    298
    So. CA
    my Road Attack did it at 25-40mph when i released the throttle. the hand grips would displace about +/- 4"... if i released the throttle at higher speeds, the bars wouldn't shake. must be some weird frequency issue w/ the tire's carcass design or construction that couples w/ the suspension frequency... i took off the RA's and put back on the BattleWings. problem gone.
    duckboy
  5. walrond
    walrond Earth Wanderer
    May 24, 2005
    1,066
    Leander, TX - R1150GS
    Not a problem on my GS but if I had the same problem I would definately contact Continental.
  6. JStancampiano
    Sep 20, 2006
    527
    N GA Mts
    Do you know to country of origin of your tire? Mine says "made in Korea" Good German stuff.
    Joe
  7. Norsman
    Dec 5, 2004
    2,724
    Plover, WI
    No, don't have a clue.
  8. JStancampiano
    Sep 20, 2006
    527
    N GA Mts
    Any idea on contact info in US. I searched the net and couldn't find any US contact info...SWmototire offered to replace the tire, but there is no assurance that it will be any better. And of course guess who gets to pay for mounting, shipping..etc.
    Joe
    #8
  9. Zombie73
    Zombie73 Been here awhile
    Jan 24, 2007
    269
    Castleton, VA
    Mine still do it after 5k. I notice it the most when engine breaking around 30mph or so. Have read that its a GS trait as well, so who knows. Never happened until I threw the trail Attacks on. Other then that they feel great, and when I find out the right pressure for whatever weight I have at the time I might stop squaring off my frickin' rear's!
    #9
  10. JStancampiano
    Sep 20, 2006
    527
    N GA Mts
    Well SWMototire is refunding the cost of the front tire to me when I send back the "defective" one. They would not take the rear one back too as there is nothing wrong with it. I am in the process of installing a set of Tourances on the bike (I know they work) and will save the Conti rear and either sell it, or when the Tourances wear out install it on the bike with a new front Conti (which by that time should be fron another batch).
    I can't blame SWMototire for this problem, and their service has been good, but I won't run different manufactures tires at the same time.
    Joe
    #10
  11. 450kid
    450kid XC racer
    Apr 21, 2006
    294
    OKC, Oklahoma
    Well, my 08 r12gs is nearing 900 miles with the trail attacks on it. So far not a single complaint. They do pretty well everywhere. They even suprised me with how decent they were in the sand. I was suprised I was able to low speed rail a sand berm with them and not eat dirt. :ricky
    Of course, the bike in general, has impressed the crap out of me.
    #11
  12. cammyontheback
    cammyontheback ADV'ers
    Dec 10, 2006
    537
    El Dorado Hills, Ca
    +1
    Mark
    #12
  13. Norsman
    Dec 5, 2004
    2,724
    Plover, WI
    This is definitely not the issue.... infact, what you sugest here invokes the shimmy. And it's not just coincidence that the shimmy is prevelent with this tire only and when changed for another ALL symptoms dissapear...
    ..it's the tire... and it's obvious that not all trail attacks are the same. For those that claim they have the trail atack on their bike and have no issues at all... I'd be willing to bet that if you put my trail attack on your bike you would instantly have the same symptoms.
    #13
  14. Burnszilla
    Burnszilla BurnsMoto.com
    Jun 10, 2005
    1,397
    Redwood City, California
    My front TA shimmies too. I still like everything else about these tire though.
    #14
  15. JStancampiano
    Sep 20, 2006
    527
    N GA Mts
    Put a new trail attack on the front after wearing the tourances out, This one works perfect. QC at factory must not be the greatest....get a bad one you got wobbles, good one works great.
    Joe
    #15
  16. RED CAT
    RED CAT Bumpy Backroader
    Jun 2, 2005
    3,757
    Western Canada
    Try running the best of both worlds. My front Tourances in the past wobbled when slightly worn but I liked the long wear, so now I have found a Tourance(non EXP) in the rear and a Michlin Anakee 2 in the front works best.
    #16
  17. UK_Engineer
    UK_Engineer Adventurer
    Nov 13, 2005
    67
    Cambridgeshire UK
    Fitted Trail Attacks a few days ago - rode a couple of hundred miles since at all speeds - not noticed any shimmies. Pressure on rear 41psi, front 35psi - so very close to recommended max.
    Nice tyres - more stable at speed than the Tourance or Dunlop 607's that I had before; slightly heavier steering, but not a bad thing because the 1200 steering is on the light side anyway.
    2005 1200GS
    #17
  18. cammyontheback
    Dec 10, 2006
    537
    El Dorado Hills, Ca
    #18
  19. Pappy541
    Pappy541 Been here awhile
    Jul 23, 2006
    890
    on the road
    My 09 GSA came with the TA's and they did just like the OP stated. IMHO they SUX. The dealer said that they had cupped and that was a problem that they had heard of before.
    I am going to replace them with tourances that I liked a lot on my 1150!
    #19
  20. pixelcodex
    pixelcodex Adventurer
    Oct 5, 2006
    70
    South Florida
    Had them for about 1.2 K and VERY happy with them. About 800 miles of twisties on those... Which ones did you get? I got the V rated ones, but I know they have H rated ones too... Almost bought those by mistake... These are the ones I have: http://www.tireexpress.com/prod.cfm/fid/10/pid/17318
    Hope you resolve it, cause I find them to be phenomenal tires.
    #20
