    Dismiss Notice
Cool Trials tools and workshop tricks
Discussion in 'Trials' started by Hoss Cartright, Oct 10, 2019.
  1. Hoss Cartright
    Hoss Cartright 219.474.6657
    Oct 23, 2016
    970
    Galapagos Islands
    I searched for a thread like this and couldn't find one.
    Thought it might be nice to have a thread for our tips, tools, hacks etc.
    Check out this work table that was at GASGAS Spain.
    A little hydraulic piston pinches the front wheel into the chock. Locks the bike in place.
  2. y4m4
    y4m4 Calvin
    May 24, 2009
    572
    Federal Heights, CO
    I collect stuff like this because you never know...
    Clutch basket tool for "frugal" trials riders. Stolen from https://advrider.com/f/threads/beta-evo-thread.1007749/page-24#post-34206239
    Little mudflap that won't get in the way. Stolen from wherever the watermark says.
    A deflated #3 soccer ball is an really handy for transporting your bike, especially on rough roads (my picture, but not my idea):
    The chain tensioner makes connecting the chain tricky on these bikes. I use zip ties. Picture from my trials bicycle, but you get the idea.
    Super Dirt Dud and jonnyc21 like this.
  3. Hoss Cartright
    Oct 23, 2016
    970
    Galapagos Islands
    "Teepee Puller" for primary crankshaft driven gear on GasGas Pro engines.
  4. Cascao
    Cascao Been here awhile
    Apr 4, 2018
    196
    Brazil
    my 2 cents....
    Place the main link of your chain on inside side of the chain. In this way, it is harder to it be hit by a rock
    Find and install a small gas filter if your bike is equiped with keihin. (dellorto already have one integrated)
    https://www.flickr.com/photos/cascao/28506369766/in/dateposted-public/
    https://www.flickr.com/photos/cascao/48051783527/in/dateposted-public/
    Place a small "O" ring on bolt gap of triple clamp and handlebar. It will help a lot keeping these bolts free of rust
    After beeing very close to a 6km walk home, replaced de gear lever bolt with one longer and a spacer. Now my allen key reach the screw
    Clutch tool made of old separators discs
    And tool I did trying to fix the infamous formula brake
    ZippyGasGas, Junglejeff1, D2W and 8 others like this.
  5. UstaKood
    UstaKood Been here awhile
    Feb 5, 2016
    491
    Michigan
    5FF60F2B-4E26-4714-B4D0-59C954D38B15.jpeg 8AA38152-4EF4-4DC9-B1FE-94582E5AC551.jpeg Just basic shop stuff .
    You can buy em but ...
    I made the lift from junk .
    Real handy on the lift / floor / ground
  6. Cascao
    Apr 4, 2018
    196
    Brazil
    PVC cut in a half tranformed in my suspension washing tray. Below in green the formula fork internals holding tool (a nut machined to increase ID welded in a pipe)
  7. Cascao
    Apr 4, 2018
    196
    Brazil
    This tool I made to fix early braktec master cylinder. Just poition the sfere over bleed hole and give tool a small blow with a hammer. Sharp hole edge will be rounded and stop eating seal
  8. Cascao
    Apr 4, 2018
    196
    Brazil
    Sherco dog bone busching installer/remover.
    #8
    slicktop, tomatoe333 and Brewtus like this.
  9. Cascao
    Apr 4, 2018
    196
    Brazil
    Left wheel bearing extractor. The collet expand when hit by stem.
    Right wheel bearing installer.
    #9
    DyrWolf, laser17, slicktop and 4 others like this.
  10. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    10,927
    Cowford, Fl.
    This popped up today.
    #10
  11. Hukamosh
    Hukamosh Been here awhile Supporter
    Feb 18, 2012
    328
    Cincinnati, Ohio
    a Spade as shown in the video is sharp (if prepared for use correctly). I've used a piece of a wood board sitting around the shop, (ideally 2"x8"x6" or similar seems to work great).
    #11
    jonnyc21 likes this.
  12. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    4,056
    Boise aria
    I was able to do pop the bead with two blocks of 2x4 and a large C-clamp before I got a decent bead breaker. Was at least a lot safer for potential rim damage that way.
    #12
    Takataka and Huzband like this.
  13. mung
    mung Long timer
    Apr 18, 2008
    1,177
    Idaho
    Squeeze the rear tire in a vice to break the bead.
    #13
  14. D2W
    D2W Been here awhile
    Jun 8, 2017
    322
    Summerland, B.C., CANADA
    #14
    Junglejeff1 and jonnyc21 like this.
  15. Slowerthenyou
    Slowerthenyou Adventurer
    Mar 12, 2014
    16
    Is the "TeePee" puller something that you purchased or did you make it and is it available?
    #15
  16. Hoss Cartright
    Oct 23, 2016
    970
    Galapagos Islands
    #16
    koh kood and Slowerthenyou like this.
  17. Cascao
    Apr 4, 2018
    196
    Brazil
    Steering head bearing installer
    #17
  18. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    4,990
    England On the Scotish border
    I use 1 part molasses to 9 parts water for rust removal , just submerge any parts you want rust removing from and leave them about three days repeat for stubborn jobs. Its non abrasive its no dust no work the most part just pressure wash off a nylon or wire brush all thats needed.
    #18
  19. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    39,241
    Pittsburgh PA
    All the parts that he soaked in molasses were ruined. Did you intend to post a different video?
    #19
  20. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    4,990
    No i posted the right video, but perhaps i was a little too economical with my explanation.
    This video shows molasses works which was my point in posting it.
    So a couple of hints on using molasses,
    !. Type of molasses. ?
    Food type molasses is stronger than equestrian animal stock feed molasses one of the posted videos shows this, i use 9 to 1 molasses rather than the oft quoted 10 to 1 ratio. with stock feed molasses i get here it works perfect.
    2. Immersion times? With that guys engine block i would have left that in the tank 3 days took it straight out pressure washed it off and took it from there, leaving it in weeks will only eat the rusted areas and create pitting in some castings.
    3. cleaning? straight out the tank get on it pressure wash off the parts immediate, wire brush if it has the thick orange crud left on very rusty parts, get it cleaned as quick as possible review the job if its not clean enough get it straight back in the tank. i go about three days between cleans and inspection, once your happy then thoroughly clean and paint or oil up the parts i dry parts off after cleaning with a heat gun then waste oil dip helps with shelf life as with anything its now bare metal.
    The first two vids below explain mix life and the proses in detail.
    #20
    Junglejeff1 and Yinzer Moto like this.
