Coolant leak?
Discussion in 'Parallel World (790/890)' started by JohnRansom, Apr 13, 2020.
  1. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    536
    Hood River, OR
    I spoke too soon. On closer inspection a small puddle inside the skid plate dripping off the engine case above oil filter. Will investigate in the morning tomorrow. IMG_20200513_143203579~2.jpg
    #21
  2. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    5,969
    Ontario .. Superior
    Had you wiped that area prior, or could that be blow back from riding if a hose clamp were loose etc?
    #22
    JP4 likes this.
  3. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    536
    Hood River, OR
    That was after sitting all night. I did wipe it down the day before and stuck my head up there with a bright light and didn't see anything. I rode for a couple hours today and every time I stopped there was a strong coolant smell, so it's either dripping onto the exhaust manifold or just evaporating off the hot engine case.
    Most of these on the Duke seem to be a hose clamp buried way up where you can't reach it. I'll take a more solid look tomorrow.
    #23
    TrailTrauma likes this.
  4. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    536
    Hood River, OR
    After going out to find another puddle today, I popped off the skid plate again and found the source of the leak. Like has been documented by others, it was leaking from the hose attached to the thermostat. Fortunately the clamp was positioned perfectly to reach with a 6mm socket on a swivel. Snugged it up, ran it until the fan came on, and it looks like that fixed it.
    IMG_20200514_101450724.jpg IMG_20200514_102809529~2.jpg IMG_20200514_102943047.jpg
    #24
  5. slink
    slink Been here awhile
    Feb 19, 2015
    254
    Estes Park, CO
    Dealer just confirmed my coolant leak is due to a warped thermostat housing. New one ordered.
    #25
  6. Poweranger
    Poweranger Long timer Supporter
    Aug 15, 2009
    1,202
    Michigan
    I think mine is leaking at the thermostat housing. Tighting the hose clamps 1K ago didn't help. Still waiting on the dealer to get back with me about it.
    #26
  7. slink
    Feb 19, 2015
    254
    Estes Park, CO
    Mine is leaking a fair amount after it cools down.
    #27
  8. BobcatSig
    BobcatSig They call me... Huckajawea
    Aug 15, 2014
    3,631
    Protestlandia, OR
    Which year is your bike?
    #28
  9. slink
    Feb 19, 2015
    254
    Estes Park, CO
    It's a 2020 (S not R).
    #29
  10. Poweranger
    Aug 15, 2009
    1,202
    Michigan
    I tightened my clamps around 1k ago but still have a leak so last night I investigated a little further into it. I took a picture and zoomed in and it looks to me like it is leaking from the hose. I removed the top portion of my BDCW skid plate so I could get a screwdriver to the hose clamp. The clamp was positioned in a way that it was difficult to get tightened all the way so I loosened it up, repositioned it, and tightened it down good. Will see if that solves it.
    #30
    roookie1 and brunosac like this.
  11. DanOGrande
    DanOGrande vorn and confused
    Aug 1, 2004
    304
    Bigfork, Mt
    My thermostat housing just started to leak. I’ve got about 3000 miles on a 2020 S.
    #31
  12. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,984
    Star Tannery, VA
    I try to not be such a skeptic (must come with age) but I sort of doubt the thermostat housings are leaking.
    My inner skeptic says "KTM probably doesn't pay the dealer to snug up a hose clamp and check two bolts." so... easier to get paid if that housing needs replacement.
    #32
    Flatroads likes this.
  13. Poweranger
    Aug 15, 2009
    1,202
    Michigan
    Check that hose clamp on the housing. I tightened mine up and it still leaked for another 1000 miles so I assumed I had a bad housing or gasket. Last week I repositioned the hose clamp and was able to tighten it better. No more leaking now.
    #33
    JP4 likes this.
  14. DanOGrande
    Aug 1, 2004
    304
    Bigfork, Mt
    I can see the coolant glistening at the interface of the plastic thermostat housing and the cylinder head. It’s not weeping around the end of the hose. I could get a long blade screwdriver up there and the hose clamp couldn’t be tightened anymore anyway. I’m gonna let the dealer handle this. Since the housing is only like a ....$35 part, might as well replace it while the tech has spent a lot of time exposing it. If a piece of plastic has warped during repeated heat cycles, perhaps it’d never seal again even when snugged down. I may even buy the housing now and have it ready. Earliest I could get an appt is September 4 and I don’t wanna wait for the service tech to affirm what I’ve seen then wait for the part to arrive. I live in Montana and you never know. Could be the last few weeks of riding season .
    #34
