Cootz' End of Pavement Rally, Cedarville, CA May 10-13 2018
Discussion in 'West – California, the desert southwest and whatev' started by Sfcootz, Jan 5, 2018.
Are you coming?
  1. Yes. This sounds awesome.
    58.1%
  2. No. This sounds stupid.
    3.2%
  3. Maybe. I like stupid awesome things.
    38.7%
  1. Chip Seal
    Chip Seal Long timer
    Aug 18, 2004
    2,983
    Western Orygun
    Ride the Sherpa to Fairgrounds. Ask around, several of the guys attending are great technicians. You never know. Sure beats being so close but so far!
  2. jkam
    jkam Nomadic Man
    Jul 8, 2001
    6,695
    Somewhere out there
    I will do that tomorrow when attendance is better.
    I have everything I need, this is my home after all.
    Chaostrophy likes this.
  3. Andrew
    Andrew Optimus Primer Super Moderator Super Supporter
    Sep 25, 2001
    21,288
    Eastbania
    Sorry, I'm out, I've come down with something nasty in my gut, would not be any fun on a ten-hour moto ride. Have fun, y'all. :thumb
  4. cagiva549
    cagiva549 whats a cagiva
    Oct 10, 2004
    5,308
    Cypress Tx
    Ford fuel pumps are famous for failures , in tanks SUCK airtex makes a external pump that can be plumbed into the lines back near the tank and easily repairable next time only around 40 bucks and for fuel injection
  5. jkam
    jkam Nomadic Man
    Jul 8, 2001
    6,695
    Somewhere out there
    I have thought about it being the fuel pump.
    At 125,000 miles that seem like a likely candidate.
    In tank will be expensive to repair, fucking labor costs.
    Getting a tow is hard to come by around here.
    Seems I might have to get something from Susanville.
    That's 85 miles away, so costly.
    Anyone riding in on 299, stop and say howdy if I'm still on the side of the road.
  6. KiLeR650
    KiLeR650 tjoseph is unethical.
    Feb 4, 2004
    1,250
    A squirt of ether will answer if it's a fueling problem or not. Or if you're bored and have a screw driver, it'll be dark enough to check for spark soon. I'll assume you've already gone ahead and taken a look for any blown fuses.
  7. RandyM
    RandyM Less talk, More ride
    Jun 9, 2007
    984
    Grass Valley, Ca
    jkam,
    My helpful suggestion is to check the fuses. Good luck.
  8. jkam
    jkam Nomadic Man
    Jul 8, 2001
    6,695
    Somewhere out there
    I have my mechanic buddy showing up tomorrow sometime.
    He will help me figure out what is wrong.
    I will check fuses and other things that I can do until then.
    Working on the van isn't easy. Access is limited until you pull the dog house.
    I want to avoid that if possible.
  9. cagiva549
    Oct 10, 2004
    5,308
    Cypress Tx
    First thing to check is fuel flow , when electronics fail they usually work again after cooling off . If no fuel check power to pump if none route temporary power from switch to pump if that fixes it your good to go , you've bypassed all the safety crap if not it's pump time . If you can make it work with a bypass turn the switch off if you go over a cliff so it doesn't blow up when you hit the bottom . If you have two tanks try the other tank course the only time that's the problum is when you've already emptied the other tank .
  10. cagiva549
    Oct 10, 2004
    5,308
    Cypress Tx
    Wish I could be there , I really wanted to see where I grew up 60 years ago , maybe next year .
  11. Chip Seal
    Aug 18, 2004
    2,983
    Western Orygun
    I'm out!
  12. avejoe
    avejoe Been here awhile
    Mar 20, 2011
    958
    Down around the corner half a mile from here
  13. Distant thunder
    Distant thunder Been here awhile
    May 16, 2010
    279
    Penngrove
    EC8C3699-5A0E-480A-895D-FAAA3F3043E2.jpeg Didn’t know there would be swimming involved
    CA Stu, Sfcootz, Foot dragger and 6 others like this.
  14. hansi
    hansi Teurer Abenteurer
    Jan 1, 2010
    940
    State of Jefferson
    Bonnie & Clyde likes this.
  15. Apple Jam
    Apple Jam Forest Flyer Super Supporter
    Aug 26, 2007
    9,004
    Hood River
    Fords Fords all had a small electric cutoff switch about 1" dia and about 3" long with a red button on top. Most fords had them mounted under the passenger foot kick side panel or under the glove box. We used to trip them regularly with a small impact while installing audio systems. Crank forever, no fuel. Can't say why it would ever do that w/o an impact, but you never know. If it is that.....push the button and go. Good luck, hope you make it tomorrow!!
  16. Apple Jam
    Aug 26, 2007
    9,004
    Hood River
    ....and wet boots for all!!
    But yer still smilin', aintcha?
    Sfcootz and Bonnie & Clyde like this.
  17. Distant thunder
    May 16, 2010
    279
    Penngrove
    Yes i am..
    Apple Jam and Bonnie & Clyde like this.
  18. Distant thunder
    May 16, 2010
    279
    Penngrove
  19. jkam
    jkam Nomadic Man
    Jul 8, 2001
    6,695
    Somewhere out there
    My buddy showed up and he towed me to town about 6 miles using his Jeep Grand Cherokee.
    Funny to see the Jeep pulling the Lazy Daze, good that traffic was light.
    Mongox and Treadless stopped by for moral support, good to see you again guys.
    Got the RV running, the wire from the coil to the distributor was corroded and came apart.
    Now, there is another problem.
    No brake lights, turn signals or flashers.
    Diagnosing has been difficult. Fuses and bulbs are good.
    Have had rodent issues in the past and this thing has sat on the farm from October.
    There is evidence of rodents again, so maybe they got to a wire.
    Looks like I'm stuck here in Alturas until Monday when the mechanic can resume work.
    Y'all have a good time, might ride over later to see if anyone is around.
  20. Bonnie & Clyde
    Bonnie & Clyde Wishing I was riding RTW
    Jan 10, 2006
    3,639
    Gardnerville NV
    got to love the BIG BIKE ADV! Not those cheater small bikes
