Cota 4RT 260 rear shock
Discussion in 'Trials' started by Vintage pro, May 26, 2020.
  1. Vintage pro
    Vintage pro Been here awhile
    Sep 26, 2013
    257
    Stallion Springs , Ca
    Anyone on this link have pictures of the Montesa Cota 4TR 260 shock (Ollie 16v ) on the bike, off the bike, and have the eye to eye length with eye width on each end? I'm unable to get hold of Martin.
  2. LowPSI
    LowPSI Been here awhile
    Jan 19, 2010
    716
    California
    Norman Foley likes this.
  3. DyrWolf
    DyrWolf Long timer Supporter
    Jan 21, 2012
    2,753
    RICHMOND VA
    I will try to pull mine on the weekend
  4. Vintage pro
    Sep 26, 2013
    257
    Send pictures and measurements when your able, Martin hasn't gotten back with me yet.
  5. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    To start with. Thank you for your time. I pulled the shock. 10 1/4 center to center . I have ordered a TRP replacement but will gladly send E7AE4570-B8F2-466C-9AB2-95D3B5F3318F.jpeg 48FFD027-2C5C-469B-804A-CC49F38B825B.jpeg 300DAE4C-A8A4-4FA6-8CAC-FF7CA5D5EB21.jpeg CCB35A1A-3EAD-46D2-ABC5-A754BEEACBC8.jpeg you this to you to experiment on. Kind of interested in the remote reservoir idea and will be happy to switch back for testing. No hurry as I will have a shock for the bike. I can pull the spring and get the pressure measurement if you like. If your busy with other projects thats fine to Thanks again for your knowledge and input
  6. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    Lets go with 10 3/8
  7. Vintage pro
    Sep 26, 2013
    257
    Take measurement width of the eyes, take photos of the back of where the shock sits farther back so I can see location for a reservoir.
  8. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    I couldn’t even get the top bolt out without removing the airbox 946EC48C-4C19-4275-AEA8-752911C25CFE.jpeg 1E26018B-A459-4F59-ADED-8F6A729A51A6.jpeg 6062A835-FC05-4C70-A4D5-43C3CEB665B1.jpeg 0E857EF8-3EAF-4CB4-B7BE-2864481A6053.jpeg
    #8
  9. Vintage pro
    Sep 26, 2013
    257
    I'm going to need an exact measurement on the shock eye in mm, use a Vernier Caliper. Give me your # again and I'll call.
    #9
  10. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    Not sure this is what you want. Ill send you my number. 6A2CEE24-3F72-4126-A3BF-8A3CFCF3EC67.jpeg 5E787708-DE2A-4986-9CA0-FE1BD1767F47.jpeg
    #10
  11. UstaKood
    UstaKood Been here awhile
    Feb 5, 2016
    447
    Michigan
    Oh FGS !
    Just send it to him !
    :D
    #11
    Norman Foley and Brewtus like this.
  12. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    Yes. I tried to pull the spring. Dont have the tools or ability.
    #12
  13. Vintage pro
    Sep 26, 2013
    257
    Give me a call and I'll walk you through it.
    #13
  14. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    #14
  15. Vintage pro
    Sep 26, 2013
    257
    That's what I thought, should have between 60 to 70 Lbs. Most people think they need a stiffer spring when all they need is a shock with the correct pressure inside. For this shock around 210 to 220 P.S.I.
    #15
    Brewtus and DyrWolf like this.
  16. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    New shock accidentally got in a order that went through customs. Its sitting in a box in Kentucky. Ill check the pressure when I get it and call you after it’s installed
    #16
  17. Vintage pro
    Sep 26, 2013
    257
    Call when you take spring off and I'll walk you through it.
    #17
    DyrWolf likes this.
  18. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    Have a ride planned this weekend so put the old shock back in. Stock linkage 15 over fork spring. Set rear sag 11/16
    #18
  19. Vintage pro
    Sep 26, 2013
    257
    Are we talking about the bikes' own weight? ( Called free sag ) 11/16"
    #19
  20. DyrWolf
    Jan 21, 2012
    2,753
    RICHMOND VA
    Yes. Book says 1”. I thought you said 1/2 to 3/4 I should have the new shock next week. Just put that one on for the weekend
    #20
