Countersteering, shmountersteering
Discussion in 'The Perfect Line and Other Riding Myths' started by garandman, May 27, 2011.
  1. bgoodwin
    bgoodwin Got Parelli?
    Nov 19, 2007
    1,173
    Eva, Alabamer
    I should stay far away from this thread, but it's like a 25 car pile up...you just gotta look at it.
    No two wheeled, single track vehicle can be turned without "counter steering".
    Counter steering moves the track of the tires outside of the center of the motorcycle, thus causing lean....which is actually roll. As the correct amount of roll is achieved, you steer the front tire into the turn to maintain the desired trajectory.
    This second bit of steering is very hard for allot if folks to detect, as it is subtle, and mostly muscle memory, you learned the first day you successfully rode a bicycle.
    Sent from my SCH-I500 using Tapatalk
  2. bgoodwin
    Nov 19, 2007
    1,173
    Eva, Alabamer
    Maybe I should start my, completely unrelated, "Center of gravity height vs degree of lean angle for a given curve" thread...
  3. TebKLR
    TebKLR Been here awhile
    Jun 12, 2006
    750
    SE 'sconsin....for now....
    Press right..lean tight. It's just that simple.....
  4. orangebear
    orangebear Long timer
    Aug 12, 2010
    1,396
    dumfrie scotland
    that what i do and it works:clap
  5. David R
    David R I been called a Nut Job..
    Oct 16, 2009
    3,438
    Hamlin NY
    Press harder right, leans more right.
  6. erkmania
    erkmania I'll take better everytime
    Mar 19, 2004
    2,349
    San Diego, CA
    Wrong. In a car you can let go of the wheel and let the castor forces take care of the steering angle while it is sliding the rear tires. There was a terrific video of a Ferrari (or was it a Lambo?) test driver doing just that while he was on a test track. He used the throttle mid-corner to control the slide.
    Take your car onto a clear dirt lot and try for yourself. It's good fun. Do remember to take control later, though. :D
  7. Grackle
    Grackle Adventurer
    Sep 9, 2011
    80
    Maine
    Yup the car basically wants to counter steer on its own. My miata (:D) doesn't have enough balls to drift on pavement, but in the snow it's incredibly easy. Upset the rear wheels coming onto a turn (gas, clutch bump, e-brake, weight transfer from braking, whatever suits your fancy) and the rear end comes around... All you need to do to help it out is give the wheel a flick in the right direction.
    Of course FWD is totally different... Power on and aim where you want to go. That's a very strange feeling.
  8. Klay
    Klay dreaming adventurer Supporter
    Nov 19, 2005
    120,084
    right here on my thermarest
    What happens with a car is not countersteering.
  9. Grackle
    Grackle Adventurer
    Sep 9, 2011
    80
    Maine
    Well, there is something called countersteering in the automotive world, but yeah... the physics and purpose is different. Anyway I was just replying to the post above mine, sorry for the derail.
  10. Griffin44
    Griffin44 Been here awhile
    Jan 12, 2010
    363
    British Columbia
    I just can't believe that anyone that has ever ridden a motorcycle in a curve can not understand countersteering. It truly boggles my mind.
  11. orangebear
    Aug 12, 2010
    1,396
    dumfrie scotland
    people like me can get a bike round a bend at speed without needing to know what counter steering is. When I started riding and when I did my test nobody ever mentioned counter steering or needed to sit me down and explain how to steer. i just ride a bike and if i need to turn i just push down on the left bar and lean left and bike will go left.
    with a car you just turn the steering wheel left and car will go left more you turn the wheel the more a car will turn.
  12. JDLuke
    JDLuke Ravening for delight
    May 3, 2007
    8,644
    New Jersey
    In other words, you countersteer the bike and add a bit of body english. I'd suggest that pushing forward rather than down is the only modification that technique might warrant.
  13. JDLuke
    May 3, 2007
    8,644
    New Jersey
    I practice on snow and ice with every car I ever drive through a winter. Whenever I experience oversteering, I turn the wheels into the slide and the front tends to recover very nicely as a result. This technique is also (rather unfortunately) called countersteering but is unrelated to the countersteering that is the topic of this thread.
    I have to admit, I've never tried letting go of the steering wheel in order to rescue an oversteer.
  14. ikonoklass
    ikonoklass Kountersteering Krew
    May 5, 2002
    2,635
    Denver, CO
    Now we're beginning to get to the proper application of Newton's Third Law as it relates to motorcycling.
  15. PFFOG
    PFFOG Richard Alps-aholic Supporter
    Aug 19, 2005
    6,969
    Western NY, further from NYC than 6 entire states
    I understand counter steering and won many bets with it as far back as the early 70's, BUT I completely understand why good, long time riders don't have a clue.
    Here is why, you walk, but do you fully understand the dynamics and mechanics that let you do so??? I bet not, because you learned to walk years ago and it is just natural, I bet you walk much better (at least sober) than you did when you started too, as practice makes perfect.
    Same with counter steering, we all learned it when we started riding a bicycle at 4 or 5 years of age, and it is now just instinctive, although counter intuitive. Just watch a new rider weave back and forth zigging and zagging, until the muscle memory takes over and it seems natural, you don't need to understand it to do it. I am sure birds don't have a clue how to fly. they just do it.
  16. SgtDuster
    SgtDuster Long timer
    Feb 23, 2010
    4,496
    Province of Quebec!
    Not understanding all the ins and outs is one thing...to argue that c-steering isn't required or doesn't even exist is a whole another thing.
    It's like saying "I never learned to walk, I don't actually walk at all but I can move forward on my feet without a problem".
  17. sasha18yug
    sasha18yug Been here awhile
    Aug 18, 2011
    137
    Germany , Berchtesgaden
  18. Crisis management
    Crisis management Latte riders FTW!
    Feb 14, 2007
    2,031
    New Zealand
    For those still struggling with the countersteering concept but smart enough to own an Iphone the C/S app is available for that switch from portrait to landscape display, a simple twitch in the opposite direction of the way you want to go and the image flicks in the opposite. :deal
    For those not smart enough for Iphones there is a manual alternative but it involves decision making, planning, synapses and muscular control. :D
  19. vortexau
    vortexau Outside the Pod-bay
    Feb 18, 2008
    1,914
    Just off the Warrego, S.E. Queensland
    Means you have to get clear of the two trucks. Once he's not restricted to Left and Right, the driver can resume countersteering . . . . until the rightside drops down and he's FOUR Wheels again.
  20. PSYCHO II
    PSYCHO II Crusty Demon
    May 30, 2011
    556
    Gold Coast, AUS
    Interesting! Is this vehicle not on two wheels ... at the moment. Not exactly motorcyle tyres but balancing nonetheless. I like your positive out come but get it wrong and he's on his side.:lol3 Just thought I'd balance the argument.:lol3:lol3:lol3 Sorry, I'm not laughing at you but with you.
