Craftsman lawn mower problem
Discussion in 'The Garage' started by dtysdalx2, Aug 22, 2019.
  1. dtysdalx2
    dtysdalx2 Only a matter of time.
    Aug 1, 2004
    26,166
    Moneyapolis, MN
    Mom's RER1000 or AKA #29000 sears won't move.
    It starts and mower works, just doesn't go forward and back.
    Any ideas? May have to go fix it Saturday. Found this so far...
  2. GroceryRun
    GroceryRun Been here awhile
    May 4, 2010
    261
    Central NJ , USA
  3. GroceryRun
    May 4, 2010
    261
    Central NJ , USA
    dtysdalx2 likes this.
  4. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,796
    below the sea
    Check out Mustie1 on utube. He fixes stuff like that by the gross.
    You didn't pull out the drive disengage thingy did you? Or was it someone else.
    JR356 likes this.
  5. dtysdalx2
    Aug 1, 2004
    26,166
    Moneyapolis, MN
    Well, Ma found a local repair shop that won't rip her off hopefully. The last place took a month and $400 bucks to fix.
    So, looks like it's handled.
    My guess is the clutch brake lever adjustment or the belts. Unless #42 is a PTO and is shot.
    Looks like #42 is a variable speed pulley made by MTD. They make a ton of parts.
  6. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,707
    Va
    Taryol is entertaining.lol
  7. unfocused_adventure
    unfocused_adventure Not my circus, not my monkeys... Supporter
    Oct 1, 2019
    73
    Auggieland FL.
    what happens is the variable speed pulley or #3 locks up. this causes a loss of tension on either belt causing slippage.
    Although #41 can lock up as well, it's rare.
    I so hate this design LOL
  8. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,943
    Hiding off Hwy 6, B.C.
    My MTD does that.Vigorously pumping and pulling back the clutch brake usually gets it going then the belts warm up and do engage.
    A good seasoning of the belts with KleenFlo(?) belt dressing?Usually fixes the problem.
    #8
