CRF300L and CRF300L Rally
Discussion in 'Thumpers' started by Lapchik, Nov 10, 2020.
  1. NateLePain
    NateLePain The Illegitimate Painter
    Dec 17, 2006
    6,521
    Arkansas the Beautiful
    Ty for this post. I've had 2 WR250s and sold them both without regret. I've wondered if the CRF300 would please me. Your post helped answer many of my questions.
    nlp
    NJ-Bill and Mister D like this.
  2. Cuttlefish
    Cuttlefish Riding to disappear.
    May 31, 2016
    2,345
    Sunshine coast Qld Australia
    I would mention this about the WR...adding a Rekluse auto clutch allows the WR to have an almost no stall lugability that makes it really easy to ride in slower, technical terrain and gives excellent traction. So the low down torque advantage of the crf is largely cancelled out by this mod. Mentioning this for WR owners who may not realise this and be thinking of selling their WR due to the torque difference of the two bikes. Rekluse don't make an auto clutch for the crf300s as yet.
    For those who appreciate good suspension the crf 300l will still require work on the front forks and a rear shock replacement to get closer to the stock WR suspension. Expertly re-valved WR suspension will make the gap even larger.
    For a gravel road/back roads tourer the softly suspended Rally with its wind protection for highway stints and larger tank is a great choice.
    Mikec012003 likes this.
  3. LibertyMachine
    LibertyMachine Adventurer
    Jun 12, 2021
    30
    Maine
    Anyone have any bad luck with aftermarket handguards? Lots of options out there, it would be just my luck to buy the one set that doesn't fit well. It seems that most every MFG claims a "universal fit".
    I've had BarkBusters on both my 800GS and my older KLX250, they worked well
  4. Nickhob
    Nickhob Armchair adventurer
    Nov 7, 2013
    1,521
    Nyon, Switzerland
    I bought these UNIVERSAL Hardware Kit -Two Point Mount (Straight 22mm) - Barkbusters Moto
    for the stock handlebars as someone here mentioned that they worked. Unless I'm a complete moron and I'm happy to entertain that thought and fess up if I'm wrong, I can not for the life of me get them to fit correctly.
  5. chopper13
    chopper13 Been here awhile
    Dec 3, 2010
    442
    in northwestern ohio
    Just be aware in side your stock bars is a threaded insert,I think 10 mm.so if you don’t replace the bars,it’ll be a bi###ch to remove the incerts
  6. Nickhob
    Nov 7, 2013
    1,521
    Nyon, Switzerland
    6 mm thread
  7. LibertyMachine
    Jun 12, 2021
    30
    Maine
    I was planning on drilling and tapping the inserts
    Neil_The_Wheel likes this.
  8. Griff2
    Griff2 Griff
    Jul 17, 2010
    2,288
    Wicklow Ireland
    I was thinking of doing that. However it occurred to me that I was mounting handguards, not crashbars. They have to be sufficiently robust to protect Your hands against bushes and small branches etc. I obtained some good quality 6mm allen bolts (the type used by Givi to mount top box base plates) and locked everything up. All is well. Imho it will take a hefty wallop to break them, and given that my handguards are old KTM 950 Adventure items which are thick plastic mouldings, I suspect that the guards will deflect before the bolts break. Just some thoughts.
    Gustavo and Vark like this.
  9. LibertyMachine
    Jun 12, 2021
    30
    Maine
    Quite valid, the shear strength on a 6mm bolt (tad smaller than a 1-4"-20) is not insignificant
    Griff2 likes this.
  10. Swamper
    Swamper Been Nowhere Done Nothing
    Aug 24, 2003
    1,249
    Nor-Cal, Nevada City
  11. LibertyMachine
    Jun 12, 2021
    30
    Maine
  12. Swamper
    Aug 24, 2003
    1,249
    Note: 2018 250 Rally
    DSC_0828[1].JPG DSC_0829[1].JPG DSC_0830[1].JPG DSC_0837[1].JPG DSC_0835[1].JPG DSC_0831[1].JPG DSC_0831[1].JPG
  13. LibertyMachine
    Jun 12, 2021
    30
    Maine
    Awesome, thank you much!
  14. SRTie4k
    SRTie4k Northeast Explorer
    May 11, 2009
    3,676
    Dublin NH
    The only thing I don't like about the Tusk handguards is for some reason when you pair them with the Tusk Chub 1-1/8" bar (their own product), the backbones don't sit flush with the mounting face on the inner handguard mounts.
    Every picture I've seen of them on the OEM bar, they are flush, however.
    I'm not sure if it's the Chub bar that is not quite the bend that the handguards were designed for (I believe they are basically identical to the CR bend, and look damn close to the OEM bend), or if the inner mounts were not machined correctly, or maybe I just got a set of backbones that were not bent correctly.
  15. Neil_The_Wheel
    Neil_The_Wheel Long timer
    Mar 6, 2006
    1,160
    Idaho
    I drilled and tapped my wife’s 300L and it turned out fine and is very solid.
  16. inroads
    inroads Go West old man
    Feb 12, 2010
    1,679
    Hye,Tx./ Grand Junction,Co.
    FWIW...my Rally 300 for sale in Flea Market..
  17. amol
    amol Been here awhile
    Aug 4, 2009
    208
    San Francisco
    Thanks, but I really need to try one on for size before I plunk down money on it :)
    inroads likes this.
  18. gmtech
    gmtech Been here awhile
    May 16, 2011
    135
    betterthanyoudorf Iowa
    just FYI hawkeye honda in davenport iowa has 2 crf300 rallys. one abs and one not. both in stock as of last night. of course I bought a 18 250rally last month because they said they wouldn't have any for stock this year...
    jon_l, amol and Vark like this.
  19. jon_l
    jon_l Long timer
    Feb 8, 2008
    8,614
    Collingwood, Ontario
    I got on a waiting list, with the dealer I prefer, for a $250 refundable deposit. Six 300 Rallys were allocated to the dealer for 2021, and 6 people were ahead of me with deposits.
    After all 6 were delivered, I emailed the dealership guy, who is fair and honest (I have bought and sold 6 or so bikes with him) and asked him to return my deposit.
    He replied "sure Jon, but.... it turns out that there is another one in transit to us now, which would be yours. Come sit on it before you decide."
    What can I say, depending on the in-person evaluation, I may get a 300 Rally after-all!
    GregDavidL, Griff2 and Mister D like this.
  20. Jakebrake
    Jakebrake Adventurer
    Sep 17, 2018
    65
    Canada
    I have one and you won’t regret buying it
