CRF300L/Rally Owners
Discussion in 'Thumpers' started by mcmann, May 1, 2021.
  1. Dmorcos
    Dmorcos Been here awhile
    Oct 30, 2018
    101
    Hot Springs, Arkansas
    Ok, I thought that you said you removed the weights which I think is doable, but have not figured out how.
  2. On the dry side
    On the dry side Been here awhile
    Nov 29, 2018
    114
    Bend, Oregon
    I removed the weights (original poster). There are two tabs that are only visible under the handle grips, which you will need to remove. Plan on getting new grips since you will post likely destroy them getting them off. You will need to depress these tabs at the same time, or drill them out in order to pull the weights out of the handlebar.
  3. Dmorcos
    Oct 30, 2018
    101
    Thank you so much. I do have new grips waiting to be installed.
  4. appliance57
    appliance57 Long timer Supporter
    Dec 11, 2014
    3,028
    Boston
    What are the things that make you unsure about the bike. I'm thinking of getting one and I'd be interested in hearing your ownership experience.
  5. appliance57
    Dec 11, 2014
    3,028
    Boston
    Blackshirt likes this.
  6. mullman
    mullman Adventurer
    Feb 19, 2008
    75
    CLT
    DFD460B1-53C2-4CC3-A87E-90791E649F82.jpeg 48648D45-82DA-4432-A9D5-D13DA9A0C022.jpeg Beautiful day on the BRP with my two week old CRF300L. Today was Blowing Rock to Little Switzerland for a few loops of 226/226A, then Mt Mitchell for lunch. For those that don’t know it’s the highest point east of the Mississippi and south of Canada in NA.
    Time for a oil change already. I’m 180 lbs and two turns shock preload made all the difference for me.
    Honda hit a home run with this one.
    TDC_ERock, Yeti2ride, Storz and 8 others like this.
  7. Dmorcos
    Oct 30, 2018
    101
    Had my bike a month now. 950 miles so far 60 % trails. I have put the bike through some nasty stuff with stock tires, many trails I did not think I would dare go on with a new bike that is stock. She has done so well no matter what I put her through and has failed me nowhere. I ride mainly wood trails, the more technical the better. Love this bike.
  8. Firecatdude
    Firecatdude Adventurer
    May 17, 2021
    78
    Northwestern Ontario, Canada
    So this is the one you used?
  9. Diskodik
    Diskodik Adventurer
    Jan 1, 2021
    90
    Sweden
    We talked about wheel hop before. I have had this issue and many with me. Check this video:
    randypower likes this.
  10. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    4,547
    Jefferson, GA
    Good wheel truing video . . . even for a true rim that needs periodic spoke maintenance.
    If My Rally had an issue, I would try rotating the tire 180 degrees.
    More than likely, most tires are a bit out of round. Maybe if you can line up the high side of the tire with the low side of the rim. Fortunately, my Rally is very smooth at highway speeds.
    Cabrito likes this.
  11. HarveyMushman
    HarveyMushman Long timer Supporter
    Jun 21, 2002
    21,035
    LoCo, Virginia, USA
    I've wondered about this, and it would definitely be my preference. Do you simply remove the lower bits or is there more to it?
  12. On the dry side
    Nov 29, 2018
    114
    Bend, Oregon
  13. On the dry side
    Nov 29, 2018
    114
    Bend, Oregon
    You have to make one cut of the plastics which is irreversible (the rest simply unbolts). You will want, or should, think about adding a skid plate from the 300L and an exhaust guard.
    HarveyMushman likes this.
  14. ilovetacos
    ilovetacos n00b
    Jul 18, 2021
    9
    Bergheim, TX
    1900 miles about to change tires. Got some motoz rallz. 1300 road 600 dirt on stock irc.
    zooomer, Fast1 and Cabrito like this.
  15. Diskodik
    Diskodik Adventurer
    Jan 1, 2021
    90
    Sweden
  16. On the dry side
    Nov 29, 2018
    114
    Bend, Oregon
    Have any US based riders installed the Thai ECU from Bikerzbits? If you have, I would love to hear your thoughts - did it trip any codes, performance, etc.. Thanks,
  17. fastnlight
    fastnlight Tire Tester
    Sep 25, 2007
    802
    Gig Harbor, WA
    Get ready for some power and speed loss. They are great but heavy tires with tall knobs. I am running something similar a dost 5mph on the top end. Great dirt traction....
    Greg
  18. ilovetacos
    ilovetacos n00b
    Jul 18, 2021
    9
    Bergheim, TX
    Yes. And didnt get really much power and speed loss with riding I do. I gained lot of grip though, especially on the front end. Doesnt feel like its going to wash out anymore on loose dirt.
    rolinrok likes this.
  19. Green Mtn Rider
    Green Mtn Rider Husky Rider
    Jul 20, 2008
    223
    Vermont
    Do you have a 21 inch front tire?
  20. ilovetacos
    ilovetacos n00b
    Jul 18, 2021
    9
    Bergheim, TX
    Yes. Next trip is alot more offroad miles.
