CRF300L/Rally Owners
Discussion in 'Thumpers' started by mcmann, May 1, 2021.
  1. outdoorgb
    outdoorgb Been here awhile
    Sep 10, 2015
    200
    Clackamas Oregon
    I too am liking the 38T... 1st and 2nd work better for my rides. If it were steeper, more technical, probably would leave 40T on.
    Bolts for tapered sproket: https://www.amazon.com/dp/B00HMZEUP2?psc=1&ref=ppx_yo2_dt_b_product_details
    (yes, you can buy some for 1/2 that...I like this company)
    Torque specs per OEM are 24 ft-lb (32.5 Nm) and 25 ft-lb (33.9Nm) per JT.
    zooomer, mcmann, Adamèl and 4 others like this.
  2. Rockfish Dave
    Rockfish Dave Been here awhile
    Jul 3, 2006
    146
    Can anyone refer me to a reference for the canister and solenoid delete.
    Have the bike apart and want to do this before reassembling.
    Thank you.
  3. Tewster2
    Tewster2 Long timer Supporter
    Jun 17, 2011
    7,877
    DeLand Flatistan
    yep I've taken to enjoying North America with my camper van these days...I have a nice bumper carrier for the 125 and a 5x8 enclosed trailer for the 300...both serve me well...my favorite place to spend the summers is Alaska....glad the borders are open again.
    Griff2, Aces 6, YahyeeDooby and 4 others like this.
  4. Adamèl
    Adamèl Adventurer
    Sep 15, 2021
    48
    Belgium
    Quite tempted by the 38t ...
    I use my 300L like a proper dual sport, meaning also 90/100km transfers from home to the riding path.
    However I still have the stock exhaust, and will not be able to flash the ecu (euro spec is different and not compatible with the 555 flash which is for US ecu only)
    Undecided....
    P.s. for the tapered bolts I'd ask a honda dealer honestly
  5. Adamèl
    Adamèl Adventurer
    Sep 15, 2021
    48
    Belgium
    This one is for the 250L, but should be 100% the same. Only difference is that the PAIR solenoid on the 300L is on the right becauseits mounted on the radiator fan bracket if I'm correct.
    https://www.rickramsey.net/CRF250Lcccmods.htm
    Rockfish Dave likes this.
  6. Blackshirt
    Blackshirt Long timer
    Mar 20, 2011
    1,194
    Waldheim, Louisiana
    Another view of the GT Kompozit shield. The dark tint provides a good background for the GPS and instrument screens. The taller height of this shield provides better protection for me and my Zumo XT. In addition, the top 4”-5” section of the shield is raked back to reduce buffeting. At 5’11”, I can see over it pretty easily. It’s an interesting design…we’ll see how it does on a longish ride.
    Fast1 and randypower like this.
  7. randypower
    randypower Been here awhile Supporter
    Jul 2, 2016
    436
    Spring Branch, Texas, USA
    I'm particularly interested in this, and in any comments you have about changes at highway speeds in wind noise from the stock Rally screen.
    I'm 6'2" and have a noisy helmet experience... Low frequency rumbling is very pronounced when sitting down. If i stand up (into "clean" air), it's far more quiet.
    I wonder if this taller windscreen might make it better or worse for me.
  8. Rockfish Dave
    Jul 3, 2006
    146
    Thank you so much!
    Got to love this community!
    Adamèl and randypower like this.
  9. Nyufuka
    Nyufuka Adventurer
    Apr 3, 2016
    65
    Europe
    I managed to install only left hand guard today. Had to play with it a little to get it in place. First, I only opened a hole in the bar but then cut that whole rubber end (photo taken before the cut).
    I bought a M6x40 bolt in a local hardware store and just screwed it into the bar end (actually in the threaded weight stuck in the bar). We’ll see if it’s strong as the original M8x50 bolt which came with Acerbis handg guards (M6x50 is too long and cannot be screwed in all the way!). Had to reposition clutch lever a bit to the right to get enough place for the lever to move. It still lacked a bit of space so I fixed it a bit lower than the aluminum bracket. It should be all right.
    Right handlebar is not as straightforward. I didn’t have a saw to cut that white plastic off.
    Screenshot from Youtube:
    I’ll borrow a saw tomorrow and will try to finish installation. From what I have seen so far, the right hand guard fits perfectly when just put in position. There’s no need to reposition anything. Break lever has all the space it needs and is 100% protected.
    It should look like this when it’s done:
    theweezersdad and Adamèl like this.
  10. emoose
    emoose I have no idea what I'm doing. Supporter
    Oct 27, 2008
    541
    NC
    Y’all convinced me. I ordered the 38T.
    For anyone that’s interested, Rocky Mountain ATV has the sprockets and tapered bolt kits in stock.
  11. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    4,614
    Jefferson, GA
    It pulls fine in 6th. IMO, It makes 5th more usable. . . I stay in 5th longer to get up to hwy speeds . . . then shift to 6th for cruising speeds etc. 6,000 RPM = true 60 mph
    Fast1, Adamèl, Grubslinger and 2 others like this.
  12. Ed@Ford
    [email protected] Long timer
    Jan 16, 2004
    4,399
    Dearborn MI
    There are a number of folks here who went for a Thai cal reflash of their USA 300 CRF. On page 155 torque specs were quoted which said Thai spec had peak torque of 19.3 lb-ft at 7000 RPM, and Euro spec was 19.6 lb-ft torque at 4750 RPM. It would seem that a reflash of a US or Euro 300 to Thai cal would feel VERY different with power coming on much later. Any opinions?
    EDIT: The 19.6 lb-ft @ 4750 was a quote of Honda Pro Kevin....which was a misquote from a different Honda document that specifies 19.6 @6500....which makes more sense.
  13. Blackshirt
    Mar 20, 2011
    1,194
    Waldheim, Louisiana
    I had a ride with the GTK windshield today. There were no buzzes or weird vibrations initiated by the taller windshield at any speed. It was very solidly mounted. Above 60mph, the bike felt a great deal less busy. It was easier to ride at higher speeds. The 38T rear sprocket notwithstanding, it feels pretty great up to 70 mph. Above that it becomes difficult to maintain velocity when a hill intrudes. However, throughout the ride the bike remained stable and the riding position super-neutral. It feels like there is plenty of air circulating around me, but no buffeting or strong blasts anywhere. As I stated before, this shield may be too tall for folks under 5’10,” but for taller riders it is a great option. My plans include substantial highway miles, so this is a valuable find. The look is slightly insectoid, but it looks cool in a dragonfly kind of way. The price is pretty reasonable, too.
    Fast1, morkys, theweezersdad and 5 others like this.
  14. mikejjmay
    mikejjmay Long timer
    Dec 15, 2008
    1,293
    Wisconsin
    Sorry if I missed it- I assume stock chain still works with 38tooth rear? (Meaning there is enough adjustment left to take up the chain slack from a smaller rear sprocket?)
    mcmann and Blackshirt like this.
  15. paprides
    paprides Been here awhile Supporter
    May 2, 2006
    349
    Under the radar...Lower left British Columbia
    Hitch style bike racks:
    I'm liking what these folks are doing. Tilting rack, front wheel well and decent tie down capability. None in stock at the moment though. US and CDN outlet's i'm given to believe (their web page).
    TMC201 MOTORCYCLE CARRIER — DK2 (detailk2.com)
  16. Blackshirt
    Mar 20, 2011
    1,194
    Waldheim, Louisiana
    Yes…it’s only two links. The bike has ample adjustment.
  17. mikejjmay
    Dec 15, 2008
    1,293
    Wisconsin
    Thank you
  18. mikejjmay
    Dec 15, 2008
    1,293
    Wisconsin
    Interesting I was just on their site browsing by ride and the crf300l had two rear sprocket options, one steel and one aluminum. Neither one had options less than 40T to select. You got the part #s for what you ordered?
  19. emoose
    Oct 27, 2008
    541
    NC
    Part # 1263590155
    https://www.rockymountainatvmc.com/parts/jt-rear-steel-sprocket-p
    It’s not specified for the CRF300L. If you search this thread, someone posted a link to the correct sprocket on the JT site: JTR210. I think the correct one says it’s for the 2009 CRF230.
    Rockfish Dave and Adamèl like this.
  20. Ed@Ford
    Jan 16, 2004
    4,399
    Dearborn MI
    Rockfish Dave and emoose like this.
