CRF300L/Rally Owners
Discussion in 'Thumpers' started by mcmann, May 1, 2021.
  1. RVDan
    RVDan Long timer
    Jun 4, 2010
    8,020
    Abbotsford British Columbia Canada
    You’re kidding right? The rubber pieces are actually grommets that insert into the holes
  2. Nyufuka
    Nyufuka Adventurer
    Apr 3, 2016
    65
    Europe
    Yes, they do insert into the wholes but on the other side of skid plate. At least that’s how I understood from the installation instruction. Shouldn’t you have only the bolt and the washer on the outside of skid plate?
  3. RVDan
    RVDan Long timer
    Jun 4, 2010
    8,020
    Skip to 4:00 on this video to see how they insert, you’ll see rubber on both sides of the skidplate
    That’s how a grommet works, you’ll notice the OD of the middle of the grommet matches the hole size.
    Cabrito and Nyufuka like this.
  4. Nyufuka
    Nyufuka Adventurer
    Apr 3, 2016
    65
    Europe
    Didn’t get that from the instructions. Thnx! :) It’s time to correct the mistake on my bike than. :D
    Cabrito and RVDan like this.
  5. birdbreeder
    birdbreeder Been here awhile
    Apr 6, 2017
    218
    Just picked up my new 2021 Honda CRF300L today and thought I'd let any-one who is intered -it's a very nice package to own. I previously had a new 018 CRF250 Rally plus a 020 CRF250L and I can notice the increase in power on the very first ride.
    Very nice slipper clutch and such a light sqeeze with positive gear changes. Over-all its a nice bike to ride
  6. Nyufuka
    Nyufuka Adventurer
    Apr 3, 2016
    65
    Europe
    I stand corrected. :D
  7. schmack b
    schmack b Adventurer
    Aug 10, 2021
    27
    Clarksdale, Mississippi
    I used compressed air to get my stock grips off without damaging them. Just blew in from the switch side and slowly pulled it off. Do not use to much air or u can pop the grip like a ballon.
  8. schmack b
    Aug 10, 2021
    27
  9. emoose
    emoose I have no idea what I'm doing. Supporter
    Oct 27, 2008
    541
    NC
    Throttle sticking at full-lock to the right.
    I was adjusting my throttle free play yesterday, and when I checked the throttle at full lock to the right, it felt like it stuck. Basically, it took more effort to open the throttle from closed and the return didn’t seem to fully close on its own. It’s not massive. Just a slight stickiness when opening and a slight softness when I let it return on its own.
    I checked the cable routing to look for binds and tried moving the cables around, but couldn’t figure out what was causing it.
    I did change out the handlebars and throttle tube somewhat recently, so I’m wondering if it’s something I did or if others are experiencing the same thing.
    I might take everything apart and lube the cables to see if that improves it.
  10. Nyufuka
    Nyufuka Adventurer
    Apr 3, 2016
    65
    Europe
    Same issue here noticed half an hour ago. :D Just came back home and noticed that when I was checking how I installed handguards. I took right handguard off just to eliminate it as a cause since this is the only change on the bike (except the skid plate which is not important in this case). Still, at full lock to the right, throttle gets stuck and does not come back. As I slightly moved the handlebar to the left, it got unstuck. Strange…
    emoose likes this.
  11. outdoorgb
    outdoorgb Been here awhile
    Sep 10, 2015
    200
    Clackamas Oregon
    I would jump on that RFN...
    randypower likes this.
  12. Ed@Ford
    [email protected] Long timer
    Jan 16, 2004
    4,399
    Dearborn MI
    The throttle grip too?
  13. Adamèl
    Adamèl Adventurer
    Sep 15, 2021
    48
    Belgium
    Have no electricity in my parking spot (apartment building).
    I had to cut the left grip. It was full of glue.
  14. Ed@Ford
    Jan 16, 2004
    4,399
    Dearborn MI
    For me the left grip is easiest to get off. Carefully slide about 25mm of a slim phillips head screwdriver between the grip and the handle bar. Then take an aerosol can of brake cleaner with it's thin spray tube in place and squirt a little bit of brake cleaner up in there. Wear safety glasses as the spray is nasty....never get it in your eyes. Let it sit a while then twist the grip to see if the glue has weakened,,,do this a couple extra spots...Grip will eventually let go and come off. The throttle sleeve has lots of ridges on it, and no glue and doesn't come off...in my experience, and slitting the grip works. Since I glue heated grips on (Oxford) next all those ridges must be cut, sanded, or carved off. I've never tried the compressed air trick on the throttle grip.
  15. schmack b
    Aug 10, 2021
    27
    Yes. That is how i got both mine off. It is also the way i put my new grips on the bike. One of the older mechanics at my work showed me how to do it, said it was the only way he ever did it. Worked pretty good but the throttle side was a lot more of a pain. There was very minimal glue if any on my bike from the factory.
  16. RVDan
    RVDan Long timer
    Jun 4, 2010
    8,020
    did it fit a lot better?
  17. Nyufuka
    Nyufuka Adventurer
    Apr 3, 2016
    65
    Europe
    It does sit a bit nicer. :)
    What bothers me are those thin bolts (M6) which I used to install handguards. I don’t think they are strong enough. Especially on the right side where I couldn’t use anything longer than 3cm (1.18 inch). There just isn’t more thread in the original bar weight or whatever that is stuck in the handlebar. I guess I’ll have to find somebody to drill a bigger hole and make a longer thread to fit longer M8 bolts. Either that or drill it completely to make room for the original hadguard bolts.
    This is just too small and too weak.
  18. Myrks
    Myrks Been here awhile
    Apr 2, 2017
    104
    Just drill a complete hole and cut a new M8 thread.
    Nyufuka likes this.
  19. randypower
    randypower Been here awhile Supporter
    Jul 2, 2016
    436
    Spring Branch, Texas, USA
    Is there a good source for switched power under the seat?
    I have the OP (Options Plug?) connector that can attach behind the front left fairing but there was too much going on there. My cluster of wires, connectors, relays, fuse box was kinda ridiculous, so now I'm cleaning up my installation and moving the bulk to be under the seat.
    There is a 4-pin white/yellow plug on the side above the toolbox (wire colors: blue/black, green, red, black/yellow) and a 3-pin clear connector under the seat and still taped up as stock in my photo (wire colors: orange, light blue, orange/light-blue).
    Info, ideas, and suggestions, please?
    And if anyone has added a fuse block and/or wiring for multiple accessories, I'd love to hear about it and see your pictures.
    IMG_20211023_180715.jpg IMG_20211023_180723.jpg IMG_20211023_180732.jpg IMG_20211023_180738.jpg
    JackBurns40 likes this.
  20. Dmorcos
    Dmorcos Been here awhile
    Oct 30, 2018
    122
    Hot Springs, Arkansas
    I also had this happen to me trying to take out as much free play as I could. Full turn to the right and the throttle will open but not return. Loosened the cable until the issue was solved.
    Then again, I tried the cyrca hand guards and could not make them clear the throttle cable, the same thing would happen as above. I abandoned installing them and went with the Zeta pro bend and do not have that problem.
    Nyufuka likes this.
