CRF500L build #3 - The Brit remix
Discussion in 'Some Assembly Required' started by Scutty, Mar 20, 2017.
  1. michaelkozera
    michaelkozera Long timer
    Jan 11, 2015
    1,434
    calgary
    ^ this
    +1
  2. Samtech79
    Samtech79 Two wheeled lunatic
    Feb 27, 2014
    1,401
    NorCal
    Well... it's still a mystery what you have nuts couple of things I would check.
    1. Your meter. Use a different one and see if you get a different reading. Even good Fluke meters read weird sometimes, especially if the batteries are low and sometime with certain batteries.
    2. Try a different lead acid battery. Some lithium batteries have internal shunts to avoid overcharging that can act up and really screw with things. Ask me how I know...
    3. Try a different regulator.
    4. Check your wiring again... and again. Soz.
  3. mjc506
    mjc506 Been here awhile
    Feb 8, 2013
    231
    Wales, UK
    The bike's a total loss. Only one thing for it, give it to me, and build another one :-)
    larryboy likes this.
  4. Scutty
    Scutty Talent-limited bike builder and rider Supporter
    Jul 19, 2011
    738
    Sunny Surrey, UK
    Of course, you're right. Why didn't I think of that - can you pick it up this weekend?
    Montana Maniac likes this.
  5. Scutty
    Jul 19, 2011
    738
    Sunny Surrey, UK
    Ok, I'll give that a go, I think I have a standard (non mosfet) regulator knocking around and I still have the old crf battery.
    I am running a mosfet Reg and a LiPo battery - time to try the old skool parts
  6. michaelkozera
    Jan 11, 2015
    1,434
    calgary
    well no wonder why your bike is not working.
    u are using a Lipo batt!!!! im surprised you havent caught fire yet. LiPo batts and li-ion batt have different working voltages. not to mention they charge complete differently. if you try and charge a lipo with a 12v charging output the battery will heat up and boom, ive tried.
  7. Scutty
    Jul 19, 2011
    738
    Sunny Surrey, UK
    Its a Lithium Ion battery for the CRF, a Yuasa YTZ7S. I am not sure where the catch fire idea comes from, I have used these batteries very successfully before.
    But, to erase that from the equation, I have gone back to the standard PB battery for testing.
    I still have the same problem.
    When I measure the battery at idle it is showing 12.8v approx, when I raise the revs to 4000rpm, the voltage at the battery drops to 12.5v. Surely that should be up around the 14v mark?!?
    Very annoying
    I thought I had a spare RR but I don;t so I have ordered a standard OEM one for testing.
  8. Samtech79
    Feb 27, 2014
    1,401
    NorCal
    Tried using a different meter? Just to check that yours is working correctly and is within calibration.
    I have a number of fluke meters and they can and have sent me a few wild goose chases.
  9. OHjim
    OHjim Long timer
    Aug 12, 2009
    1,027
    KC
    Could it be a missing ground? Or maybe one (or more) that's not connected well?
  10. Scutty
    Jul 19, 2011
    738
    Sunny Surrey, UK
    I have 2 different meters, both read the same so I am guessing they are right.
  11. Scutty
    Jul 19, 2011
    738
    Sunny Surrey, UK
    I tested from the RR ground and its got a good connection
  12. OHjim
    OHjim Long timer
    Aug 12, 2009
    1,027
    KC
    Might not be just that one??? Could be other grounds involved as well. I wonder if it would read OK under no load, but not be good under load? My other thought is maybe a (ground) wire didn't get attached from somewhere in the CB harness? Sometimes it's the little things. I'll try to remember to look at the wiring diagram tonight for the CB and see if anything jumps out.
  13. Scutty
    Jul 19, 2011
    738
    Sunny Surrey, UK
    Thanks! All the help is greatly appreciated
    Sent from my SM-G935F using Tapatalk
  14. michaelkozera
    Jan 11, 2015
    1,434
    calgary
    o, so you are using a Li-Ion batt.
    u wrote Lipo, so guess that was a typo.
  15. Samtech79
    Feb 27, 2014
    1,401
    NorCal
    This is the ground you checked, right? Got all the paint cleaned off under it?
    xajb likes this.
  16. OHjim
    OHjim Long timer
    Aug 12, 2009
    1,027
    KC
    It looks like the ground wire goes directly to ground, so not sure there's much to find there edit: (other than what Levi beat me to). The red wire goes to the starter solenoid, so maybe there is an open circuit inside there? May be why the engine dies? Can you run a jumper from the red regulator wire directly to the battery? Here is a good flowchart for finding faults of this type: http://www.electrosport.com/media/pdf/fault-finding-diagram.pdf They recommend following it precisely as skipping any step will cause you to run around in circles.
  17. totensiebush
    totensiebush re-tarded
    Feb 17, 2006
    336
    Alameda, CA
    I've been running a Shorai LiFePO4 on my SV1000 with everything else on the charging system stock for 3+ years no problems....
  18. michaelkozera
    Jan 11, 2015
    1,434
    calgary
    "LiFe-PO" is not the same as "LiPo". LiFe-PO batts and li-ion batts can be bought and made for a conventional 12v charging system, there are many example of both types online. however LiPo batts ( RC places, helis, RC cars , etc, etc) cannot be used on a conventional 12v charging system unless using a DC/DC inverter, which no one does.
    LiFe-Po =//= LiPo. different working voltages, different charge potentials, different chemistry.
    outbacktm likes this.
  19. totensiebush
    Feb 17, 2006
    336
    Alameda, CA
    I would be very surprised if he was running a LiPo battery of the type you describe.
    I've also run a pack made of 18650s with a box stock charging system and no problems (but I suspect the 18650 isn't the type of LiPo you describe).
  20. michaelkozera
    Jan 11, 2015
    1,434
    calgary
    he made a typo, he wrote Lipo instead of li-ion. i figured he made a typo but wasnt sure until after he confirmed. cuz yeah lipo most certainly would not work.
    and yes 18650 cells ( primarily li-ion) can be used for 12v charging systems, im pretty sure my "featherweight lithium battery" i have in my crf500L has them.
