CRF500L build #6?
Discussion in 'Some Assembly Required' started by drag123, Jan 7, 2018.
  1. Samtech79
    Samtech79 Two wheeled lunatic
    Feb 27, 2014
    1,398
    NorCal
    Well? You had a whole weekend, why ain't it done yet?
    :hmmmmm
    #41
    Roadracer_Al and FJ Fun like this.
  2. drag123
    drag123 Been here awhile
    Jun 27, 2013
    176
    Ottawa Canada
    Waiting for exhaust pipe parts at the end of this week
    #42
  3. Samtech79
    Feb 27, 2014
    1,398
    NorCal
    Wire till your fingers bled?
    #43
  4. drag123
    Jun 27, 2013
    176
    Ottawa Canada
    I have figured it out but will wait untill i have the frame back from poweder coat so i know how much wiring to add
    #44
  5. Slytheslayer
    Slytheslayer Ride or Die!!
    Jan 18, 2017
    830
    Fort Lewis, WA
    Looks awesome. You got some skills. Would love to be able to do something like this in the future.
    #45
  6. Samtech79
    Feb 27, 2014
    1,398
    NorCal
    Look in the owners thread. There's enough info in the six build threads to get a degree in dirt bike.
    Go take some hobbies welding lessons and you'll be golden.
    Or, (shameless plug) pay me to build it for you.
    #46
    Te Hopo and Slytheslayer like this.
  7. Slytheslayer
    Jan 18, 2017
    830
    Fort Lewis, WA
    Fair enough.. I've welded a little about 20 years ago but have been interested in getting one. I'll look into some classes. Thanks for the tip.
    #47
  8. Samtech79
    Feb 27, 2014
    1,398
    NorCal
    If you find yourself in Sacto, I give free "intro to welding" lessons.
    Just the basics, enough to take up the torch on your own afterward.
    #48
    Slytheslayer likes this.
  9. Slytheslayer
    Jan 18, 2017
    830
    Fort Lewis, WA
    Thanks for the offer!
    #49
  10. drag123
    Jun 27, 2013
    176
    Ottawa Canada
    Thanks slytheslayer its not so bad. This guy has some realy good info about welding. Watch his welding videos http://www.weldingtipsandtricks.com/how-to-tig.html
    #50
  11. drag123
    Jun 27, 2013
    176
    Ottawa Canada
    Well i was waiting for about 2 weeks for pipe bents and pipe to come in and somehow i either forgot to order a 2 into 1 murge collector or they didnt send it. So more waitiing. 20180210_165243.jpg
    #51
  12. drag123
    Jun 27, 2013
    176
    Ottawa Canada
    In the meantime I fabed the gear shifter and the rear brake petal 20180210_165102.jpg 20180210_165118.jpg
    #52
    Nixels likes this.
  13. michaelkozera
    michaelkozera Long timer
    Jan 11, 2015
    1,434
    calgary
    looking good.
    i see you have an ABS 500.
    you gonna rip out the LED light that shows "ABS", or just cover it with tape lol?
    on my crf500l i just bent the stock crf250l rear brake lever to make it fit around the engine, but welding up a new one also works.
    #53
  14. Oyabun
    Oyabun 親分
    Apr 7, 2016
    708
    Budapest, Hungary
    One can open up the speedo unit housing and desolder the ABS led. BTW that's the only difference (the missing led) between the abs and non-abs model speedo units.
    #54
  15. drag123
    Jun 27, 2013
    176
    Ottawa Canada
    Yes i will tackle the abs bulb when i get to that later i was thinking of cutting the wire that feeds power to the LED
    #55
  16. Oyabun
    Oyabun 親分
    Apr 7, 2016
    708
    Budapest, Hungary
    A lot cleaner to desolder it. i have one open in front of me. I did the reversal. It was advertised as an ABS version so I bought it, but it seems to be from a non-abs bike.
    BTW, this is a bit modern unit, so no dedicated wire for the individual lamps, but communicates with the ecu via a serial bus and signals sent digitally - so cutting the abs warning cable does not work.
    Edit: rechecked the wiring diagram, and you're right. Everything else but the ABS is via the serial bus, so your method of cutting the cable would be feasible too.
    #56
    Nixels likes this.
  17. drag123
    Jun 27, 2013
    176
    Ottawa Canada
    To michaelkozera: I see that you installed rear spools on your bike. Did you drill the rear swing arm as i see that B&B makes a kit that is incorporated into the chain adjusters but at $80us thats a little expensive.
    #57
  18. michaelkozera
    Jan 11, 2015
    1,434
    calgary
    I drilled holes. I also installed lock nuts from the inside of the swing arm.
    80$. Holy #%$^@&@. Yeah i payed like 5$
    #58
  19. drag123
    Jun 27, 2013
    176
    Ottawa Canada
    Do you have any pics?
    #59
  20. drag123
    Jun 27, 2013
    176
    Ottawa Canada
    Finally got the exhaust done 20180304_174256.jpg 20180304_174339.jpg 20180304_195810.jpg
    #60
    KayDubbya likes this.
