CRF500L build #6?
Discussion in 'Some Assembly Required' started by drag123, Jan 7, 2018.
  1. Samtech79
    Samtech79 Two wheeled lunatic
    Feb 27, 2014
    1,402
    NorCal
    Not to be a downer but I'd saw that header apart and move the O2 sensor...and start over on the skid plate.
    It's gonna collect crap on it and probably won't survive a good shot to it.
    Don't get discoraged or insulted.... I had to start over on the original exhaust and I'm probably going to to it for a third time.
    #81
  2. drag123
    drag123 Been here awhile
    Jun 27, 2013
    194
    Ottawa Canada
    I dont know if you noticed but i did move it to the side
    #82
  3. Samtech79
    Feb 27, 2014
    1,402
    NorCal
    Can you carve out some of that hump in the exhaust? I'm not trying to be a dick.
    That just looks like It's gonna break.
    #83
  4. Samtech79
    Feb 27, 2014
    1,402
    NorCal
    You are at that last hurdle in the build. Fix it now or fix it later.
    The exhaust is the bit that still needs figuring out.
    #84
  5. 11motos
    11motos Feral Rider
    Oct 27, 2017
    2,388
    On the Road
    Awesome project. It seems that honda should be putting 2 and 2 together and giving folks this great combination.
    #85
  6. drag123
    Jun 27, 2013
    194
    Ottawa Canada
    20180331_195836.jpg 20180331_201211.jpg I tamed the loom of doom today hope to fire it up soon
    #86
    brownvv, KayDubbya and Te Hopo like this.
  7. drag123
    Jun 27, 2013
    194
    Ottawa Canada
    I started it today wow it sounds realy good i am glad i did this.
    #87
    MotoPolo, invisa-bill, ben2go and 2 others like this.
  8. Samtech79
    Feb 27, 2014
    1,402
    NorCal
    Did you get to go for a ride?
    #88
  9. Slytheslayer
    Slytheslayer Ride or Die!!
    Jan 18, 2017
    830
    Fort Lewis, WA
    Video or it didn't happen...lol
    #89
  10. drag123
    Jun 27, 2013
    194
    Ottawa Canada
    no not yet. waiting for the acerbis gas tank to get here then will take it for a rip
    #90
  11. flipflopdog
    flipflopdog Youth & Talent, no match 4 Old Age & Treachary
    Mar 27, 2011
    592
    Gateshead the Grim North of England...!!!
    My full recommendation on fitting the pump to the new tank is bin the OE gasket and cut your own from some 4mm nitrate petrochem resist rubber, the cut-outs in the OE gasket are to match the raised studs on the steel tank and the slightest bit of over tightening will wrinkle the new plastic tank, you need an evan pull when doing up the six bolts. If you are going to use it then go easy not too tight...
    #91
  12. Scutty
    Scutty Talent-limited bike builder and rider
    Jul 19, 2011
    740
    Sunny Surrey, UK
    Strange, i had no problems fitting mine, you just need to make sure the gasket is exactly the right way around and the hole pattern is not regular at all. Also i used the CB500 fuel pump but with the CRF float arm fitted, which is very easy to swap over.
    #92
  13. flipflopdog
    Mar 27, 2011
    592
    The gasket only fits in one position to ensure the correct outlet direction. I think over tightening the bolts is easily achieved on the Chinese tank i used, the aluminium insert ring looks proper flimsy but tbh you only get that small width of sealing say 6mm/7mm to do the job. I used some well decent nitrate rubber and Wurth sealing gunge and a contact width diameter of around 35mm. That OEM gasket will crinkle the tank by its design given the slightest opportunity or there again i might just be a 'Ham fisted' spanner thug....!!!!
    #93
    Scutty likes this.
  14. OHjim
    OHjim Long timer
    Aug 12, 2009
    1,040
    KC
    #94
  15. drag123
    Jun 27, 2013
    194
    Ottawa Canada
    20180406_191632.jpg 20180406_191534.jpg 20180406_190906.jpg 20180406_190839.jpg All done what do you think? I think she looks good now if it wasnt snowing outside i would of taking her for a ride. Must be global warming.
    #95
    MotoPolo, Barmtbr, KayDubbya and 3 others like this.
  16. Samtech79
    Feb 27, 2014
    1,402
    NorCal
    Bahahaha! I love it!
    Now go ring its neck!
    #96
  17. drag123
    Jun 27, 2013
    194
    Ottawa Canada
    Ohhh dont worry i will.
    #97
  18. Yorgo52
    Yorgo52 n00b
    Sep 20, 2017
    4
    Ottawa
    Mission accomplished yeah whoo!!!
    Time for Blast Off!!!
    Looks nice drag
    Let's see some video soon as you launch this beast.
    #98
  19. drag123
    Jun 27, 2013
    194
    Ottawa Canada
    Oh yea looking forward to this riding season should be a blast
    #99
  20. flipflopdog
    Mar 27, 2011
    592
    Nice job there Dragster, looking very purposeful and ready for a trip already..!! I'm liking the cockpit area with that screen plus the utility panel AND an after market fuel tank that actually fits...!!
