Ct - I Repair Riding Gear
Discussion in 'Vendors' started by akarob, Sep 29, 2010.
  1. akarob
    akarob Rob
    Apr 8, 2009
    9,320
    Skuncasville, CT
    PM sent
  2. nobody
    nobody motomaniac Supporter
    Oct 26, 2005
    3,568
    Newington CT
    Rob I want that Bruins bag,you know I'm a big fan...
  3. akarob
    akarob Rob
    Apr 8, 2009
    9,320
    Skuncasville, CT
    Yea, I can't blame ya there. It did come out pretty nicely. The guy I made it for bought the patch on eBay and gave it to me. I did the rest.
  4. nobody
    Oct 26, 2005
    3,568
    Newington CT
    K gone patch hunting
  5. KTMtrailrider
    KTMtrailrider Been here awhile
    Jun 3, 2008
    234
    Northeast
    Rob,
    I have a pair of over the boot riding pants, that need zippers installed on both legs so they fit over the boot. Otherwise, I can't get them on over the boots. You will probably need to add the zippers to each leg, and a little material to open them up a bit. PM me your address, and I'll pop them in the mail to you. You can PM me the amount, and return shipping, and I will PayPal it to you.
    Thanks as always for your great work!
    Joe
  6. Cobia235
    Cobia235 Been here awhile
    Aug 11, 2009
    238
    Norwich, CT
    Hey Rob,
    I have a Carhart type work coat that needs a new zipper can you do it as well? Thanks Gene
  7. akarob
    akarob Rob
    Apr 8, 2009
    9,320
    Skuncasville, CT
    Yes. I will probably just have to order the proper zipper. Sounds like it'll be one with metal teeth. I just have to measure it to make sure I get the right length, but replacing it isn't a problem.
    PM sent
  8. Cobia235
    Aug 11, 2009
    238
    Norwich, CT
    Great, the one that is in it frayed at the bottom so you can't zip it I think it was nylon, but metal would be better:evil Let me know and I could drop it off to you. thanks Gene
  9. scootac
    scootac Just a Traveler
    Feb 18, 2008
    11,830
    Northcentral PA
    Sounds like you might be able to help me out!
    I have a pair of heavy nylon riding pants, First Gear I think, with a seam that's splitting out up near the crotch,,, maybe 4-5" long. Would it be a problem for you? How long does it take for turnaround? Need pics?
    George
  10. akarob
    akarob Rob
    Apr 8, 2009
    9,320
    Skuncasville, CT
    Split seam? Not a problem. I'll have them fixed up better than new. PM sent.
  11. beckgr
    beckgr Beckgr Supporter
    Apr 10, 2008
    21
    Covington, LA
    Really heavy duty zipper is smoked. can you repair?
    Thx,
    Greg
  12. akarob
    akarob Rob
    Apr 8, 2009
    9,320
    Skuncasville, CT
    Main zipper on a jacket? Not a problem.
    This is my most recent one. A picture of the finished repair. The inside looks just as neat.
  13. beckgr
    Apr 10, 2008
    21
    Covington, LA
    Thx. PMd you.
  14. avc8130
    avc8130 Long timer
    Nov 14, 2008
    1,701
    Northern NJ
    I need a heated gear "pass through" on my Olympia Phantom full suit. Basically I need a hole in the liner and another in the side pocket liner so I can let the wire hang out the side pocket.
    Any suggestions?
    ac
  15. akarob
    akarob Rob
    Apr 8, 2009
    9,320
    Skuncasville, CT
    I'd suggest a reinforced opening covered with a velcro flap if it needs to repel water. The alteration doesn't sound very involved so your highest cost will be the shipping. Just guessing, but the full suit will probably be $15-$18 each way. Send me a PM if you would like to discuss it further.
  16. TonyKZ1
    TonyKZ1 Long timer
    Dec 15, 2005
    1,226
    Marble Hill, MO. U.S.A.
    Hey Rob, I need to get my Fieldsheer Highland II suit repaired. Basically it needs the short zipper on the right side (so you can access your right pants pocket) replaced and the crotch area repaired. Also if possible I'd like some velcro pieces added to better attach the insulated liner on the right leg. They put velcro pieces on the left leg to attach the liner but on the right side used a loop and button combination for some reason. I'm currently using paper clips for zipper pulls on the right leg and the main zipper that goes from head to left ankle, so if those could be replaced, that'd be fine too.
    Thanks, Tony
  17. akarob
    akarob Rob
    Apr 8, 2009
    9,320
    Skuncasville, CT
    I just figured I'd post up a couple recent pictures of a repair job.
    Below shows a buckle I replaced. The one that came on the pants (bottom) was taken off and replaced with a better one.
    The next picture shows a leather patch I added to the inside of the pant legs. Notice the double needle stitching. The corners are all double stitched to prevent the patch from coming off.
    I also just bought 100 high quality waterproof jacket zippers because I got sick of trying to buy them one at a time. They're nearly impossible to find at all, and when you do fine one, the quality will be questionable. So, if you need a new jacket zipper, I will be able to turn the job around in a day or so with a 1st quality zipper. I'll post some pictures of the zippers when they come in.
  18. KTMtrailrider
    Jun 3, 2008
    234
    Northeast
    Hey, those pants look familiar, and a lot better than when I sent them to you!
  19. KTMtrailrider
    Jun 3, 2008
    234
    Northeast
    Got my riding pants back in the mail today from Rob. To say I was pleased would be an understatement. The quality of the work is excellent, the zippers he uses are first rate, and pants are much better than new. It's too bad that the manufacturers don't put as much effort into their products as Rob does.
    Thanks again Rob!
  20. dmottv
    dmottv Take the Long Way Home
    Jan 26, 2008
    673
    NH Blue Hills
    Hey Rob, I've got Nitro snowmobile bibs that I wear on cold weather rides with one of the ykk type nylon two way leg zippers stripped out. The oem zippers look rugged enough but stripped out somehow. They sure were tough to get outta when they stripped out! I kinda like the rugged two ways on my First Gear pants. Sound like something you could fix? BTW, your waterproof zipper replacement on my Olympia jacket liner is working just fine. Thanks much.
