Custom rubber clutch lines?
Discussion in 'The Garage' started by Drop_Center, Oct 9, 2019.
  1. Drop_Center
    Drop_Center Long timer
    Sep 3, 2007
    4,530
    Rocky Mountains
    I put bar risers on my bike and needed a longer clutch line, but the steel one makes it too grabby for my likes. I'm having a hard time finding anyone that makes them in anything but steel.
  2. szurszewski
    szurszewski Long timer
    May 26, 2010
    3,463
    Olympia, WA
    If the fittings are common - or somewhat - you can probably have one custom made. There are a couple of shops near me that do custom hydraulic lines. I recently had a short brake line made on the spot.
  3. usgser
    usgser Long timer
    Nov 6, 2005
    3,580
    Westside WA
    If you can find the fittings a tractor shop can workup a hyd clutch line. Lot of NAPA autoparts stores used to make custom hyd lines while you wait. Again the proper fittings may be an issue but also check with your local autoparts store, you may find an existing hyd brake/clutch hose for a car/pickup that will work.
    I also don't get your issue of a steel line making your clutch "grabby". I'd look elsewhere for your grabby problem.
    nickguzzi likes this.
  4. Drop_Center
    Sep 3, 2007
    4,530
    Rocky Mountains
    I wouldn't mind someone using the fittings from the steel line, I'll look around locally.
    I don't know if grabby is the right word but it's a problem others with my bike have had as well.
  5. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,940
    Hiding off Hwy 6, B.C.
    Good hydraulic shops may be able to reuse your fittings and crimp a new longer line onto them.
    I had that done back then on both brake lines and oil cooler lines.However that won't work on my BMW with the hard plastic clutch line,them banjos aren't reusable.
    Not a lot of pressure inside a clutch line.A few hundred pounds at the most.300? I very much doubt that a SS braided Teflon line would make for a grabby clutch.
  6. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,743
    below the sea
    Another wondering why a hydraulic line is being blamed for problems that are likely caused somewhere else.
  7. cagiva549
    cagiva549 whats a cagiva
    Oct 10, 2004
    7,088
    Cypress Tx
    Every bike I own has braided metal lines , clutch action is way better than rubber lines . I’d be looking for a problum someplace else . And brakes are like model T versus a new car different .
  8. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,607
    Central Ohio
    1. Use braided steel and fix the other problem, which might be in your head. Your might think the brake is "grabby" just because you are not accustomed to having balloon in the hydraulic system. Adjust your input.
    2. Order a longer rubber hose from another bike by the same manufacturer. I did this once when I added a windshield and changed bars on a Yamaha Seca 650.
    #8
  9. bwringer
    bwringer Gimpy, Yet Alacritous
    Jan 22, 2008
    3,180
    Indianapolis
    I'm also in the camp of not understanding why you imagine a braided line is affecting the action of a hydraulic clutch.
    Source: I upgraded all the hydraulic lines on my V-Strom, including the clutch line. Big upgrade to the brakes, zero effect on the clutch feel.
    #9
    9Realms likes this.
  10. concours
    concours WFO for 48 years
    Dec 2, 2008
    7,637
    NH USA
    Keep the steel one. Get the air out of the system.
    Get you operator skills in order.
    Carry on.
    #10
