CX 650 Custom/ Stupid is as stupid dose ... till it's black and blue
Discussion in 'Some Assembly Required' started by waylongway, Nov 26, 2014.
  1. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    25,263
    Über Alles,California
    I have a little turbo off of a John Deere, want to play with it? You pay shipping and it's yours, send it back if you don't use it. You'll need a pop off valve.
    #41
  2. Kevan Garrett
    Kevan Garrett Been here awhile
    Apr 7, 2009
    723
    Benicia, CA
    Hey you go kid. First one is free. :evil
    Yeah, that old trap still works more often than you can imagine.
    Heh
    Kevan
    (P.S. Loving the build)
    #42
  3. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    3,992
    NorCal
    Ahhh,...What he said , OK! If you throw in that land in Florida...:deal
    #43
  4. nouhlaC
    nouhlaC Adventurer
    Sep 19, 2014
    50
    Nor Cal
    That is by far the nastiest looking lathe I have ever seen. Brush some oil on it.
    #44
  5. waylongway
    Dec 16, 2009
    3,992
    NorCal
    Are you calling her nasty? :whip
    I think she looks hot! :sweeti Maybe a little to much concrete makeup dust...:lol3
    #45
  6. waylongway
    Dec 16, 2009
    3,992
    NorCal
    I like to try and have lots of things going a once ,So if I can"t do this I can do that or the other thing...
    Been trying to figure out all the parts for the frame jig and one is the cones to hold the head set..
    E-bay $60 and that's $60 that could go somewhere else...There must be something I can make some out of??:shog
    I ask Jeff the millwright at work if he knows of something that will work. he says let me think on it..:hmmmmm
    Ten minutes he comes up with this..
    :thumb Prefect !!Looks like some frame cones to me..
    They are conveyor belt rollers that are worn out. The middle was as thick as the ends...Cut...
    I put them in the lathe to check them and not to bad but we will take them to the machinist for a touch up ...Then drill and cut more off...
    Here....:huh
    Some weird stuff here, need a rolls !:rilla
    Scott the man!
    I tell him what I need and back to the shop...
    Try to work on the frame bracket to get it more eye pleasing so I can pop it out at work tomorrow (other stuff to to).
    Then more work on the right side carriage..
    See how we do things?
    I once took a blacksmith class for for fun. It helped me alot !!:bash
    Pretty close, It always sucks doing the 2nd one of any thing.
    Thats all I got..:hide
    Hey its Monday :puke1
    #46
    brstar likes this.
  7. bk brkr baker
    bk brkr baker Long timer
    Jul 19, 2006
    10,241
    The Bluegrass
    Good penny-tech move on the cones !
    You are hard at it with the bulid thread, keep it coming, we're watching .
    #47
  8. waylongway
    Dec 16, 2009
    3,992
    NorCal
    OCD??
    Maybe....:smile6 There is a vintage show in Corvallis OR. in May..I'm sure I won't have it (done) by then but I would like to bring it along as a under construction roller. :stupid
    #48
  9. SloMo228
    SloMo228 World Class Cheapass
    Sep 22, 2012
    1,882
    SE Michigan
    I'm in on this one. My first bike was a '79 CX500, and a year or two ago I picked up a CX650 for a project that I ended up giving to my brother for his first bike (if he ever ends up finishing it). I always thought the CX series had a great powerplant, and I wish Honda had stuck with it and kept on developing it, instead of sticking with the "safe bet" Shadow line.
    #49
  10. jon_b
    jon_b Been here awhile
    Oct 16, 2011
    127
    Vancouver
    Esthetics and numbers moved may have killed it off unfortunately. I rode a CX500 across Canada 2 weeks after purchasing it in April 2000. I almost got frostbite but the bike didn't have a hiccup.
    Great build so far, the worn conveyor roller into jig pieces is damn funny.
    #50
  11. waylongway
    Dec 16, 2009
    3,992
    NorCal
    Turn it back a notch to last night..Got to looking at the left side pin again and still did not like the hang out on the inside.
    I think a collar would be good around the outside ,then weld it to the frame not the nut..:norton
    After school we tool one up out of a shaft collar (hard) with the big nasty, like this..
    Now ,lets make those brackets..1/8 should be good ..Take a look on the scrap table..:evil
    What do we have here? Prefect...:thumb
    mark them out...And punch set the holes.
    [[​IMG]
    Now the cheat machine..holes first. Stick the tit in the punch mark and put some stock on top to keep this thin stuff from pulling back up..
    Put the pattern on the back for a hole check..
    One more and to the sheer...
    Leave some to grind..WE LOVE GRINDING..:clap:clap
    little ruff because the sheer wants to pull this thin stuff over the edge..
    Its only metal..:bash
    Done... clean up drive home,,,,Scott calls my head set and cone are done. :clap
    SEE....:tb
    the cones will get drilled and cut...
    Then the true rod..
    Dust seal.
    NOW we can see how the forks fit..With the spacers we got 7 5/16
    Same..
    Now putting on the top clamp, I'm like somthing is missing..:ddog
    I have no top nut???:baldy
    I got so side tracked with no axle nut and the nancy boys at the yamaha shop..(The fish don't show one dude) .That the lock nut went out the window .... :becca
    Next..back to the Collar.
    Perfect ! just need to cut it back on the nasty...
    Bracket check...
    Stuff to do tomorrow...:wave
    Dinner time ..
    #51
  12. 1stiski
    1stiski Ride that nasty thing
    Oct 23, 2003
    1,736
    Elizabethville, PA
    LOVE all the grinding:sweeti.. Keep it up.. Nice Build coming along.
    #52
  13. bkowal
    bkowal Been here awhile
    May 5, 2003
    285
    Oakville, Ontario, Canada
    But that Guzzi is so pretty...
    Another warning... the starter on 650 is VERY weak, I believe Honda used the same one on the 500. It barely does the job and a top condition battery is required to get a good crank going. So, increasing the compression might be a problem.
    #53
  14. Scubawerx
    Scubawerx Scubawerx
    Dec 19, 2012
    763
    North Georgia
    Well planned and photographed build. Enjoyable to read. Once owned a CX. Love to see this one go. Keep the reports up. Thanks.
    #54
  15. waylongway
    Dec 16, 2009
    3,992
    NorCal
    Wow ...Thanks you guys ,I'm glad you are enjoying my stupidity .:lol3
    No pressure RIGHT? :lol3
    Yes I knew about the starter and plan to rebuild or see if my friend can rewind it....
    535 cca Odyssey should make it spin..Under the trans.:wink: I don't believe in wimpy batteries.
    2 cups of coffee and we will head to the shop...
    #55
  16. bk brkr baker
    Jul 19, 2006
    10,241
    The Bluegrass
    If you plan to turbo it , dropping the compresion goes with that. Starting will be easy with the low compresion , then when it spins up the turbo will bring back the compresion and add to it. Woo hoo !
    The way this build is going , it'll be plenty cool sans turbo. If you go the turbo route, woo hoo hoo .
    #56
  17. waylongway
    Dec 16, 2009
    3,992
    NorCal
    Stay after school and finish up the collar and cones...
    first we tac the collar to this pipe so we can hang on to it..
    Need to cut 3/8 off..
    more rigging at the saw..
    Live action ! yeee Haaa :jive
    not to much...:nono
    Now to the cones! Pilot hole..
    16 MM next...:gun2
    mark for the cut..
    looks funny because one is cut off farther up the cone .
    More rigging, Hey I like this pipe on the inside now...:viking
    More Live Action!!:jive
    Hey look $60 E-bay cones...:deal
    I know ,,,,It would have been much EASIER to buy them. But look at all this manly stuff we are doing!! :beer We got new skills..:1drink
    Back at the shop..:D
    Sexy...
    Back to the collar...Almost fits..:jjen
    Still to tight ,carbide tip..round and round ,back forth really fast... If you not not have one of these,Get one... It will make you look like a really good welder Too..:lol3
    Hog the back out a bit ..
    Still to tall..:fpalm
    And what seemed like a hour we sand and sand and sand to get to this..
    Some times the littlest things take the most time....:(:
    And some times you just nail it...:bmwrider
    We will fill the back in with the mig now ..Almost looks like it was made that way...:wink:
    A little more bracket grinding, Oh boy more grinding...
    OK it official.. I"m sick of grinding...:umph
    #57
    shinyribs and 65matt like this.
  18. larryboy
    Jan 9, 2005
    25,263
    9.8:1 compression with 60 HP on the 650 engine. Drop the compression down to 7.8:1 and put 7 psi of boost to her for about 90 HP. :freaky Noticed in the specs that they had the accelerator pump CV carbs on these things, they do well with boosting. :deal
    Looking good, waylongway!! :clap
    #58
  19. SloMo228
    Sep 22, 2012
    1,882
    SE Michigan
    Forgot to ask - did you have any problems with mating the driveshaft from the single-sided swinger to the 650's output shaft? I believe you can swap the CX500 output shaft into the 650 case without much trouble if necessary.
    #59
  20. waylongway
    Dec 16, 2009
    3,992
    NorCal
    :confused
    Thanks,Larryboy!
    I found this thread on the CX and the turbo...
    http://www.advrider.com/forums/showthread.php?t=917601
    Lots, of opinions and I would Love the HP :wings ..What concerns me is the lack of new spare parts Like main bearings for these bikes,That I have found on the CX 500 forums...
    And I'm not crazy about all hoses tubes boxes the thingies that will be no way to hide..:cry
    I like a very clean and striped look.(wheres all the stuff?) look..:confused
    But I'm not ruling it out yet...Thats just too far out just yet..SO keep bugging me about it!:lol3
    #60
