CX 650 Custom/ Stupid is as stupid dose ... till it's black and blue
Discussion in 'Some Assembly Required' started by waylongway, Nov 26, 2014.
  1. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,236
    Arizona, Alaska
    Whadaya mean grind?
    If it is within 1/4 inch, use the gap rod !!!!!!!!!!!!!
    Don
  2. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    3,968
    NorCal
    You the man larryboy!..:thumb That is one of those instant ,:doh Why didn't I think of that?...:fpalm
    A inmate told me about this starter kit...
    http://www.tcbroschoppers.com/yamah...inch-diameter.html?utm_source=google_shopping
    We will see??.....
    Ahh... porosity??:dunno
    https://www.youtube.com/watch?v=ML-n51O3h6o
  3. waylongway
    Dec 16, 2009
    3,968
    NorCal
    Had to drive the wife to her annual 50% off x-mas crack run, As her idea on a vacation is having carpal tunnel surgery done...:rofl
    Hey I need thase...
    I could make some but why?? We know these fit....:1drink
    Extraction...
    All cleaned up....:D
    Now,,,About larryboy's brilliant Tube idea....Got me thinking that you can make any tube size with some craft paper??
    This is really ruff but I just wanted to try this new trick (love those)...:clap
    Insta tube..
    pattern check....
    [​IMG][​IMG]
    I looked at a pattern maker down load before but I'm out of ink again!! :cry.
    But it looked something like this...
    Now it's easy :doh to cut and adjust the pattern....:wink:
    Thanks ! Larryboy :rilla
    One more look....
    Me thinks me needs to go for a ride and see some old friends....
    No grinding.:beer
  4. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    25,009
    Über Alles,California
  5. rodteague
    rodteague Enjoying the ride
    Apr 12, 2013
    761
    Franklin,TN
    Very impressive; I would re-examine your front rake. Looks a little steep to me. This bike is begin' for a little more rake to lengthen the wheel base a little. What is your current head angle BTW? If I missed it, my apologies:D
    Best regards
    Rod
  6. waylongway
    Dec 16, 2009
    3,968
    NorCal
    Thanks, Rod!
    It looks smaller and tighter in the picture for some reason.??
    24* rake 56" +or- WB with about 39" from grip to seat back.....I could push it to 57"
    I went off a 06 R1 54.5 ....:huh
    My guzzi is a 27* with a 58" WB, It kinda feels like a freight train ...:yikes
    I would like to actually ride this one around town, Maybe cause some wrecks...:rofl
    I hope you guys went riding today!!! Dose a stupid GOOD....:clap
    250 miles but my friends got tired of hanging around...??
  7. larryboy
    Jan 9, 2005
    25,009
    I do dirt bikes at 25°, it looks good to me, but I've had a Buell with 22° of rake and 54" of wheel base.
    :beer
  8. waylongway
    Dec 16, 2009
    3,968
    NorCal
    Dam, I thought those Buells always looked snubby...
    The new R1 wheelbase is almost half of an inch longer than last year’s, at 55.7 inches.
    I think 56" sounds good ....:thumb
    We will play with some patterns tomorrow, maybe get something taced up for real !!!!..:thwak
  9. waylongway
    Dec 16, 2009
    3,968
    NorCal
    OK, grab a beer or some coffee ,This is going to take a bit,,
    We start with the new tube patten....:deal
    Then we transfer oid pattern and start to cut...
    We find the centers both ways ,so now we can fold both ways and make each side the same... Freakin brilliant....:clap
    Then I get even smarter and use the sander....:wink:
    This was like the 2nd try I think......:D
    Little more in the back...
    A few more tweaks and we have this....
    Transfer to tube....
    Fricken,, AAAAA...
    Broke down and bought a good band saw blade...$53.
    Much better w/the 3/4 wide.....
    Cuts the pipe no prob, First:huh pass....
    Hit it with the grinder..:clap And the cut wheel...
    Like I said first try!!....:wings
    Little tight still...Better then loose....:viking
    We SLOWLY grind and use the mortis sander.....:1drink
    Things are going good then the on/off on the sander falls apart#$%&*@@#
    So we jerry it and back to work....
    And this is a hard angle....
    Better....:evil
    Bad picture...? But we sand the canfer back and inside of pipe as per pipe welding...
    Forks off, and use the cones and true rod to set things as they were ...24* and 15* dead center....
    Bad light again but we sand all the parts clean and looks like this....:eek1
    Pull things together,Check ,Check ,Check......all good...:thumb
    Put some tacs all round...Its hard to get in there but we take your time and get propped up on each one with whatever we can find...
    Remember ,we are not to worried about the back right now... we will work our way back....
    Take it all back apart to weld the rest...Tomorrow, That was all day...:norton
    My first born....:raabia This will get boxed up too, for the motor mounts...
    brstar and 65matt like this.
  10. Fubars
    Fubars What would Scoobydo?
    Aug 20, 2003
    2,170
    Ventuna, CommieFornia
    Question on the brace:
    The rear section where it connects onto the backbone--are you going to start your weld towards the steering head or the rear of the tubing?
    In other (easier) words, left to right, or right to left as shown in your picture.
  11. waylongway
    Dec 16, 2009
    3,968
    NorCal
    Left to right.. back and forth ? Yes? :ear Center motor, then frame carriage...As that will need to be lengthened on one side to keep things in line ...If that makes sense ?
  12. Chris K
    Chris K Been here awhile
    Dec 10, 2006
    920
    Northumberland, UK.
    As someone who struggles to assemble IKEA furniture, I'm really enjoying this.
    :freaky
  13. waylongway
    Dec 16, 2009
    3,968
    NorCal
    I think we are all challenged here...:webers
    Off to wayne's to see about a gas tank vent and more sanding discs ....Oh boy..:clap
  14. zerohype
    zerohype Long timer
    Jun 24, 2007
    1,418
    Flatlands of the Midwest
    I'm all in. Suscribed, I should say.
  15. Te Hopo
    Te Hopo Nomad
    Sep 25, 2007
    2,429
    Marlborough, New Zealand
    I was dubious about the plans at the start but now I am wholeheartedly cheering you on and following this after seeing your work. :clap
  16. waylongway
    Dec 16, 2009
    3,968
    NorCal
    Welcome aboard the SPECIAL bus.....:lol3
    Stay tuned for a new update at six...:deal
  17. Scubawerx
    Scubawerx Scubawerx
    Dec 19, 2012
    757
    North Georgia
    Your patience is admirable, as this project will be in the end. Thanks for setting a good example during fabrication/mock-up. Good Job!
  18. waylongway
    Dec 16, 2009
    3,968
    NorCal
    To not go bonkers, we divert to a little side trip to wayne's and parts for the gas tank I have been thinking about..
    Every body say hi to wayne and his wife...:wave
    This was sitting inside...:evil
    Me wants it!!
    HO, looky here...:eek1
    What we are after....
    Wayne say take it ,,He's awesome!!...
    Stop at the weld store....flapper disks and silicon bronze rod 35$ more....:cry
    Cutting....For all of you that wondered what the inside of a gixer tank looks like??...
    What we are after...Oh dear...Think some water got in here??...
    Bits that we may need....:wink:
    Will go here....
    I know some of you are saying it would be Stupid to cut up that nice tank....:lol3
    Now we left off here last night.....
    As you can see this side ended up w/a big gap that I did not see till it was like F it...
    Thats what the bronze is for...First one too hot....:annie
    Turn it down a bit...better..
    And so it goes ,inch or so at a time one side then the other ...Let it cool down ...More inches....
    Like I said.... I'm no welder, we do the best we can...
    Prop things up to get the right angle...Hey remember the cones?
    I knew those would come in handy....:clap:clap
    [​IMG][​IMG]
    The key is to get the right position....Old computers are good for something...
    We work our way round inch or so at a time,one side then the other....
    Cool down....Again....
    get things all welded up ,A little sand ,grind...:clap
    Slap things back together with out really trying and holy crap ...:pope Its dead on....:freaky
    I told you the sandblaster sacrifice would pay off!!!:clap
    Now we move to the motor mounts...Get things in place....
    make the marks....This is EXCITING !! WE are moving now....:rilla
    the mounts that we cut out of the old frame.....
    Small holes , then bigger ones....
    After almost breaking my wrist twenty times w/the drill because when it grabs you can not let off the trigger....:fishie If you know what thats like...
    Helps to go backwards....:1drink
    I thought the bottom hole would be a bugger ....but not to bad,As you can see.....
    One more,,,
    The rest will be done w/the rotozip and carbide tip...That just quit working......:hack: :fpalm Really?
  19. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,063
    mena, Ar
    you cant stop here, come on we have to atleast see the mount finished. Use a hand file :D
    brstar likes this.
  20. jon_b
    jon_b Been here awhile
    Oct 16, 2011
    127
    Vancouver
    That's....heaven.
    You're insane, please don't stop.
