Cycleworks breather valve removal tool
Discussion in 'Airheads' started by CafeDude, Feb 14, 2017.
  1. CafeDude
    CafeDude Ride to eat.....
    Sep 15, 2014
    6,417
    Westchester County, NY
    Anyone happen to have a photo of how the tool attaches to the breather before adding the collar and washer/nut? I'm curious before I go ahead and purchase one.
    Thanks in advance.
  2. Big Bamboo
    Big Bamboo Aircooled & Sunbaked Supporter
    Sep 29, 2010
    16,497
    Big Island of Hawaii
    From the looks of it, the bolt is inserted into the holes and rotated to catch in the notches. Then the cap is tightened down. Will only work on the old style breather with three holes...[​IMG]
  3. CafeDude
    Sep 15, 2014
    6,417
    Oh now that makes sense! Thanks BB. Yeah I have a couple of old turkeys making noise in the shop that need fixing. My caveman style of removing the breathers is a pain. This appears to make the task much easier. Thanks!
  4. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,842
    CafeDude, you need a cheap dent puller kit. I bought one 40 years ago to do bodywork and have found more uses than you can imagine. Some come with a hook, but I made one from a 1/4 bolt. I slip the hook through one of the windows of the valve, turn it so it's under metal, then give it a couple of shots with the slide hammer. It takes longer to get the thing out of the drawer than it does to pull the valve.
  5. CafeDude
    Sep 15, 2014
    6,417
    Thanks, Bud! I'll give this a try. Sure would beat my old pry-bar routine and all the cussin!
  6. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    4,516
    Fort Collins, CO
    The tool I made is similar to the one from Cycle Works. At least it works the same way.
    CafeDude likes this.
  7. scrapper
    scrapper Been here awhile
    Jul 27, 2007
    582
    Wisconsin
    The tools shown are for pulling the original flat disk breather?
  8. Big Bamboo
    Sep 29, 2010
    16,497
    Yep
    #8
  9. Texer
    Texer Been here awhile Supporter
    Jun 5, 2015
    714
    Seattle
    Did the same thing- worked great.
    #9
  10. Big John Sny
    Big John Sny Long timer
    Jul 3, 2009
    1,643
    Irving, Tx
    You'll end up using it for other things too, like pulling "hard to get to" seals, pilot bushings, ect.
    #10
  11. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    16,299
    Silver Spring, Md
    Using a hook puller on a slide hammer will work. Since it is pulling on one side you may have to reposition the hook a couple of times but that is not a big deal. Another most useful tool is a blind hole puller. I have a Chinese one that works just fine and a blind hole puller has the slide hammer. But I do not have a single hook attachment that fits it. If one could get the attachment to fit say the slide hammer in the OTC blind hole puller then you would be killing two birds with one stone.
    When acquiring pullers a common problem is that if you mix different brands you end up with pullers that use different threads and sometimes different size attachments. A big reason for why I try to stay with OTC. I mostly do but I also have a couple of odd ball items. More antiques than Chinese.
    #11
