Cyclops Raider Canbus Install
Discussion in 'GS Boxers' started by Spongehead, Jun 26, 2020.
  1. Spongehead
    Spongehead Been here awhile
    Dec 7, 2014
    155
    Peoria, AZ
    I'm trying to install the Cyclops LED aux light kit and Raider canbus controller and ran into an issue. Naturally, it's Friday night so I probably won't be able to get a hold of them until Monday.
    The only images I can find in their documentation and website show this under the seat:
    Easy, enough, the controller goes behind the TPMS unit. But on my 2018 GSA it looks like this:
    Mine has the TPMS unit in the rear portion and something else in front. Anyone know that that other component is? I looked through the manual and can't find it. Wondering if I should try to relocate that or find a different spot for the canbus controller. It's kind of big and I can't wedge it in there.
  2. Kewwig
    Kewwig Adventurer
    Feb 14, 2017
    54
    Wellington, New Zealand
    That smaller unit detects lean angle and is an Inertial Measurement Unit (IMU) that is oart of your ABS Pro.
    ExodusRider likes this.
  3. ExodusRider
    ExodusRider ExodusRider
    Jun 9, 2015
    2,033
    Houston, Texas
    If I had to guess, I believe that is the emergency keyless sensor where you place your key / plastic key under the wheel well to start the bike up if your key is out of battery.
    Reach under your rear wheel well and find the circle indentation and see if it's directly under the second sensor you are talking about..
    There's probably enough room directly under the rider's seat instead of the pinion.
    If you take off ride seat and plastic cover of pillion frame.. you might be able to rearrange the tpms sensor and cyclops closer under ride seat..
  4. Spongehead
    Dec 7, 2014
    155
    Peoria, AZ
    Damn, guess I won’t mess with that. Thanks.
  5. Spongehead
    Dec 7, 2014
    155
    Peoria, AZ
    I’ll play around with it and see where I can cram it.
  6. Spongehead
    Dec 7, 2014
    155
    Peoria, AZ
    Just in case anyone else installs this kit, this is how I did it. I just turned the TPMS unit sideways.
  7. Jetskifast
    Jetskifast Adventurer
    Jul 4, 2019
    83
    San Franciso
    Cyclopes makes quality products.
    Installed Aurora 2 inch with amber halo, on my F650GS.
    Spongehead likes this.
  8. Thomas_Beemer
    Thomas_Beemer Adventurer
    Apr 12, 2017
    35
    Denmark
    Unplug everything and rearrange it as on the picture. Then connect everything with everything. That is my advice. If it is not on the picture you will probably not need it. So just throw it in the bin.
    #8
    handensco likes this.
