Damaged tire bead - safe to reinstall?
Discussion in 'Equipment' started by nasawhy, Jul 31, 2020.
Tags:
  1. nasawhy
    nasawhy n00b
    Jul 11, 2017
    4
    I needed to replace a front tube today on a Heidenau K60 so I took off the tire and noticed this gouge along the outer wall of the bead. You can see the metal wire inside, but they don't appear to be broken, just exposed. I'm thinking this isn't a good idea to put back on? I'm going to put about 1,400 miles on my bike in a few days. This tire has a few hundred miles on it. I must have gouged it when I installed it or today when I took it off.
    I have an old tire that still has some tread, so that would be the safer option, right? If I get a new tire, then I'll want to try to break that one in and not sure if I will have time for that.
    What should I do? :becca damaged-bead.jpg
  2. Dan Lorenze
    Dan Lorenze Been here awhile
    May 26, 2005
    235
    Ventura County, California
    I can only speak for myself and what I would do, and I would run it without thinking twice..
  3. motu
    motu Loose Pre Unit
    Dec 28, 2001
    7,089
    New Zealand
    Yeah, it's not a tubeless, not badly damaged, I''d be happy to use that too.
    shinyribs likes this.
  4. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,761
    Mill Spring, NC
    Run it!
  5. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    10,105
    Kentucky-Eastern that is!
    The bead wire affair is a multi-strand circle of seriously strong steel wire, coated with rubber, then wrapped within the tire carcass plies as they are folded over each "end" of the tire during the build process. You are seeing the fibers in the tire carcass as folded, not the wires. The chuink missing is sidewall rubber that forms the rim seal which keeps out debris in a tubeless tire or keeps air in for a tubeless. Tubeless or not, that's no big deal, as the strength's still there-> ride it as said.
  6. CopaMundial
    CopaMundial Wow, that broke easy
    Jun 27, 2008
    1,918
    US, SE PA & Central ME
    1,400 mile trip in a few days?
    1) Get a new tire. (Don’t worry about break-in, that will obviously happen in the first day of the trip)
    2) Later after you get back, and the tires from the trip are worn out you can switch back to this suspect tire for local riding no problem.
  7. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    6,376
    The South
    That tire isn't hurt at all. Run it and enjoy your trip!
  8. ozmoses
    ozmoses persona non grata
    Jul 3, 2009
    45,052
    Blo,ME
    5 go ride/ 1 no ride. :hmmmmm
    This ain't rocket surgery @nasawhy .
    #8
    nasawhy likes this.
  9. markk53
    markk53 jack of all trades... Super Supporter
    Dec 20, 2007
    20,629
    Delaware Ohio
    Heck, mark the spot on the sidewall with some yellow crayon, a piece of tape on the rim, or the like, then look at it a couple times a day. If you see movement of the tire at the bead, indicating an issue with the tire, then fix/replace it. Otherwise keep going.
    Personally I doubt if that damage is enough to cause an issue, but if you mark it you can look to make sure. After all, it's your butt in the seat, not ours.
    #9
  10. nasawhy
    nasawhy n00b
    Jul 11, 2017
    4
    Thanks everyone, I brought it to a mechanic today and everyone in the shop agreed it was nothing to worry about. It's mounted and ready to go!
    #10
    shinyribs and ozmoses like this.
