Dead 1 year old battery?
Discussion in 'Airheads' started by edgeoftheworld, Jun 10, 2019.
  1. edgeoftheworld
    edgeoftheworld Been here awhile
    Nov 6, 2017
    282
    CT, USA
    My battery is a year old. My 1987 R65 hasn't gotten much use so far this season and the last few times, I couldn't start it. I put it on a battery tender for a few days and tried to start it yesterday and it wouldn't start. Tried to turn over weakly then just clicking.
    I have one of those power packs that you can jump start with so I connected that and it started right up. I put it on a different battery tender and connected it to an SAE plug instead of the accessory port to see if the other tender or the port is an issue.
    Seems odd that a 1 year old battery would be completely dead. Any thoughts or ideas on what else I could look at before buying a new battery?
  2. Big Bamboo
    Big Bamboo Aircooled & Sunbaked Supporter
    Sep 29, 2010
    14,771
    Big Island of Hawaii
    What type of battery?
  3. edgeoftheworld
    Nov 6, 2017
    282
    CT, USA
    Westco sealed battery
  4. Uke
    Uke visualist Super Supporter
    Oct 9, 2013
    3,900
    HouTex USA
    Perhaps use the Battery Tender continuously when not riding, I prefer using a Battery Minder which has integral desulfation, which I use continuously when not riding.
    sperz1 and JeepDawg like this.
  5. edgeoftheworld
    Nov 6, 2017
    282
    CT, USA
    That's what I did for the winter. It was stored on the battery tender and started right up when I took it out of storage. I don't have a garage where I live so it's outside under a cover. I just bought a long extension cord so I could keep it on the battery tender when its not being ridden. Had it on for 3-4 days and it still wouldn't start. I took it out of storage mid April but it hasn't been ridden in about a month due to weather, it not starting and having a GS that has been getting ridden more :)
  6. Uke
    Oct 9, 2013
    3,900
    HouTex USA
    If an AGM battery is discharged below a certain level, even when connected to a charger they won't take a charge, one trick for such a situation is to connect both the discharged battery and a battery known to be adequately charged, at least 12.7 volts, connected parallel to the charger.
    Do you have an accurate volt meter to determine the change level of the Westco?
    mrclubike and SmittyBlackstone like this.
  7. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    10,844
    Shoreline, WA
    I found that the battery tender I used to run was not correct for the Odyssey batteries, and didn't provide a hot enough charge.
    Odyssey maintains a list of approved changers, Westco may as well
    Texer likes this.
  8. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    3,356
    Fort Collins, CO
    Remember, a battery tender is not a battery charger. A tender is designed to keep a battery touched up on charge, often won't bring up a very discharged battery. Use a battery charger to bring up the battery then use a battery tender to keep it maintained.
    #8
  9. edgeoftheworld
    Nov 6, 2017
    282
    CT, USA
    ugh. something else to buy :(
    #9
  10. MrBob
    MrBob Rabbitbrush Ranger Supporter
    Oct 27, 2005
    17,207
    Boulder county, Colorado
    Somewhere around here is a recent thread on maintaining and charging batteries - very informative. After reading the links, I’m less impressed with Battery Tenders.
    I bought my Westco from EME in Denver.
    #10
  11. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    6,537
    I've found that Westco batteries vary wildly in durability and cranking power. However, long-term battery storage is surprisingly tricky. I have a lot of bikes in the shop, some of them for long periods, and I lose a few batteries to failure every year. I've decided that Peter Pickett may have been on to something when he said, years ago, that "A battery is like a muscle. If you don't exercise it, it dies." Now before I charge them on their three week rotation, I discharge them by turning the bikes lights on, or weather permitting, start it and run it for ten minute or so. It seems to help, and makes Vermont winters easier to bear. :)
    #11
    spokester, tsADV, Uke and 2 others like this.
  12. 190e
    190e Long timer
    Feb 20, 2013
    1,889
    England
    I am not a fan of battery tenders because unless the voltage is just right they can do more harm than good. In particular a sealed battery of the AGM type has a self discharge rate so low it really doesn't need a battery tender. It's far safer to give them an occasional charge every 2 or 3 months than leave them permanently hooked up.
    #12
    ozmoses likes this.
  13. edgeoftheworld
    Nov 6, 2017
    282
    CT, USA
    there is so much conflicting info around. I had it on the tender for the winter and it started right up no problem. It was off for a month and now its dead.
    #13
  14. tsADV
    tsADV Been here awhile
    May 28, 2014
    426
    Telemark, Norway
    Not only Westco AGMs, from what I've read. I've seen several reports on Odyssey batteries dying after a year or two recently, enough to put me off buying one, instead of a cheap generic mobility "sealed" one. Build quality may not be the same today as 10 years ago.
    FWIW, I have 53030 sized Westco in one of my boxers. It is 11 years old, was in my K100 two years until it got written off, then 9 years in a boxer that has sat unused at least 7 months every winter, without any charging. Only two years ago it started struggling when I needed to start a 190 PSI comp pressure engine at minus 2 centigrades, but it still is in the bike, and working.
    #14
    edgeoftheworld likes this.
  15. Warin
    Warin Retired
    Aug 30, 2012
    7,283
    Either;
    the bike is draining the battery
    or
    the battery is draining itself.
    Measure the drain from battery to bike to check the bikes rate of discharging the battery. May be there is a leak on the bike.
    #15
  16. Texer
    Texer Been here awhile
    Jun 5, 2015
    530
    Seattle
    My battery experience and mileage for my 75/5 with Panasonic SWB (thin line) battery is that I plug it in after every ride as if it was a kids video game charger. Ten years, Battery Tender, no issues yet. I may be lucky though.
    #16
  17. boxerboy81
    boxerboy81 Stay Horizontal
    Jul 22, 2009
    3,719
    Melbourne, Oz
    One of these would be handy to have in the shed. I know the smaller ones also work and can be carried on a bike, but these don't rely on a charge in the device. Maybe good for a shop or dealer?
    https://startwarrior.com/models/
    #17
  18. 190e
    190e Long timer
    Feb 20, 2013
    1,889
    England
    I think it's accepted that AGM's are more prone to sudden death failure than wet cells so it may not always be the charging regime that's at fault but it's a fact that with an AGM in good condition and no discharge on the bike, it simply isn't necessary to keep them continuously on float. Anyone who "knows their battery" i.e. takes rested voltage measurements occasionally will have discovered that AGM's hold their charge incredibly well compared to the old wet cells. My approach is don't take the risk of float charging, charge it only when necessary and then any failure cannot be due to the charging regime.
    #18
  19. edgeoftheworld
    Nov 6, 2017
    282
    CT, USA
    I had a usb port plugged in which was always on. So I expect that was draining the battery. I didn't think it was enough to completely discharge it. My next step is to get the battery charged and then keep it on the tender when not riding like I did all winter. that worked the last two winters
    #19
  20. 190e
    190e Long timer
    Feb 20, 2013
    1,889
    England
    I wonder does anyone consider the economics of float charging. Even if the battery isn't accepting much charge there will still be losses and power consumed depending on the size of the charger.
    I measured the power consumed by my old bench charger on the float setting at 10W watts. That doesn't seem much until I calculated that in a little over 3 months the energy consumed would cost more than I paid for the battery. If my battery costs £37 to replace and it's already 5 years old what do you think it's value is ? Lets say £10 which means I would be as well off buying a new battery as charging it for more than 1 month.
    Modern chargers perhaps use less than 10 watts and electricity is no doubt much cheaper in the US but the same principles apply in that it will at some point become uneconomic to float charge a battery towards the end of it's life.
    #20
    nothing likes this.
