Deep water crossing prep?
Discussion in 'GS Boxers' started by TBob, Oct 30, 2009.
  1. TBob
    TBob Offroad Fab Guy
    Sep 12, 2005
    736
    Mesa, AZ
    problem is getting to the damn thing - man I threw in the towel, more than i was willing to do to get to a breather. If the air box would have came out w/o havint to split the bike in two I had a good idea for the trans breather.
    That was to run a tube up into the airbox. Drill a hole in the bottom of the air box and use a rubber grommet then use a long section of tube from the breather though the grommet and up into the air box.
  2. seabee1
    seabee1 we build, we fight
    Aug 9, 2008
    2,477
    Scottsdale, Arizona
    now, that is a good idea. i'd still stick the breather valve thingy on, even though it's in the air box. justin case.
  3. bananaman
    bananaman transcontimental
    Jun 20, 2007
    7,892
    Why you might need to cross water- here's a reason:
    http://www.advrider.com/forums/showpost.php?p=8704886&postcount=52
  4. bananaman
    Jun 20, 2007
    7,892
    Bump for Skyrubber.
  5. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,174
    Anchorage, formerly Spenard (hub of the universe)
    On page 9 richoman posted about how to cross... good stuff, and in that post is the only place I've seen in this thread what I think is the possibly the most important part of the crossing technique... the bit about the direction of the current. Crossing even slightly against the current is much harder than if you can keep it behind you. The bottom feels "looser" & moves around more because you are churning more water, and the bow wake is bigger. You will be pushed to the downstream side which moves your landing point and you need to adjust for that... otherwise you might do a successful crossing only to dead end into an unclimbable bank. The effect is magnified as the current speed goes up. The only other thing I can think of is that it is a skill that needs practice like any other outdoor skill. Do easy crossings close to home where rescue is easy... then try harder ones.
  6. OzRob
    OzRob Been here awhile
    Jul 28, 2003
    723
    Australia, Snowy mountains NSW
    The R1100 does have a gearbox breather...located on top just under the battery tray.....
  7. bananaman
    Jun 20, 2007
    7,892
    You're right, but 205d. I was wrong, but I changed my tranny fluid anyway.
  8. r1200mike
    r1200mike Govt.Adventurer
    Aug 30, 2006
    329
    FT.Benning
    Prepare for a water crosssing. If it was any deeper than the footpegs...BUY A BOAT.
  9. zenriding
    zenriding Traveler
    Apr 26, 2010
    18
    San Jose
    This is fantastic news. I'm going to prep my GS for the upcoming sheetiron 300. Expect a few creek crossings. I'll post photos.
  10. Toe - Cutter
    Toe - Cutter 666
    Sep 3, 2010
    827
    S/Coast NSW Oz Planet of the apes.
    I,m with ya tbob.........
    plan for the worst,,,, hope for the best.........
    my best advice re; deep but doable
    1- walk a few lines pre attempt
    2- keep that finger hard up against kill switch ,,and shut her down if/ when you submarine......cheers
    3- amalgamating tape for sealing, snorkel joints.
