Designated GPS unit vs. Smart Phone
Discussion in 'GPS 101 - Which GPS For Me' started by NJDirtRiders, Nov 24, 2013.
  1. ohgood
    Sep 21, 2010
    10,245
    alabama
    another quick trip for gas...
    red track is Duraforce, purple is Oregon 450. I stopped at a gas station briefly, and both units were recording tracks.
    when I remembered they were recording, I created waypoints where I sat. they weren't too far apart, so I won't fault either one for being so wrong that I couldn't navigate to them. I created 3m radius circles around those points with my phones geocaching plugin, I don't think it's possible to do it on Garmin devices....
    red circle Duraforce, purple circle Oregon:
    upon downloading the Oregon's track at home ( it can't be used with usb-otg cables and none Wi-Fi isn't available, or Bluetooth, gah!) I saw something odd.
    the green (highlighted) track shows the Garmin is very poor at "GPS bounce" or "GPS hop" that happens when sitting still for a moment/minute. its firmware isn't smart enough to realize it's just sitting still, and instead of recording a smooth track, records every change in GPS coordinates, even though they are inside it's error range. this track could still be followed of course, but if you're going to share tracks, you'll probably rib into the "my Garmin has track point count limits" and of course have to screw with the point count in basecamp to fix the errors and reduce count. sigh.
    the phone, however, didn't record extra points. the frequency settings for the Garmin were "auto" and for the Duraforce "3m and 3 sec".
    next up, a uturn.
    the highlighted track is the Duraforce, the purple track is the Oregon. I know everyone talks about poor accuracy in cities with Garmins, but dang, it really went off reservation. in not sure why it recorded all those hops for a two second uturn, but it did. it was between two tallish buildings, so maybe the multi path interference isn't handled very well in the Garmin firmware, or they just don't consider it an issue. either way, I'm curious to see how bad this becomes in the woods when I'm trying to record good gpx tracks riding single track. I'm betting it won't be usable if this is the result of a uturn.
    Eatmore Mudd and White Raven like this.
  2. portablevcb
    portablevcb Long timer
    Apr 25, 2015
    1,484
    nm usa
    Are you using Locus for all this?
  3. ohgood
    Sep 21, 2010
    10,245
    alabama
    yup.
    well, no that's not entirely true. I have to plug the Garmin into a desktop computer with basecamp (ugh) to get the waypoints and tracks off it, but finally after that I can use modern transfers like Wi-Fi and Bluetooth, to display both sets of tracks/waypoints on locus.
    White Raven likes this.
  4. portablevcb
    Apr 25, 2015
    1,484
    nm usa
    Understand the Garmin thing. A necessary evil with Garmin is Basecamp.
  5. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    Up. And to the right.
    Not entirely sure where to post this, but OSM+ has been taking longer and longer to find my location when I start OSM. I have a trip tomorrow and started it tonight to check the route out. Its been taking about 10m now and still doesn't have my location yet.
  6. MrMac
    MrMac Long timer Supporter
    Aug 19, 2007
    2,756
    Dacula, Ga.
    Try a different app. Something like GPS Essentials will give you lots of information about your gps connection. Maybe the device and not software..?
  7. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    Rebooted the phone and it worked. I hate doing that. I have it all saved onto an SD card, and last time I restarted the phone, I lost all my maps. I got an error that read something that wouldn't allow me to open the folder on the SD card. So I had to redownload everything.
    Worked this time though. phew
    DittyBag and MrMac like this.
  8. ohgood
    Sep 21, 2010
    10,245
    alabama
    long times to location calculation usually mean the constellation is out of date. do an a-gps refresh with gps essentials / gps status / etc and it will pick up to half a second or so.
    assuming you aren't under a mine ;-)
  9. SCPancho
    SCPancho Old farts riding club. Supporter
    Oct 27, 2005
    35,034
    Upstate SC
    Not really. There are many route designers that create GPX files.
    Trips.furkot.com
    V-Tom and sans4ver like this.
  10. ixab
    ixab just Aaron, really Supporter
    Oct 31, 2006
    410
    USA, PNW, LOLKTHX
    I'm getting back into doing a little 'real' riding after a year or two off ... yay 4 kids ... plus that Harley wasn't going to drive itself to coffee shop. Anyway, my 8 year old O.G. Zumo went away when I sold my F800GS, and now I'm thinking a smartphone should be enough for my needs. I did have some questions about that, and as usual ADV has come to the rescue. Also, as usual, there's 133 pages of jawing on the topic, with the typical ADV method; mix a few Ph.D dissertations on splitting molecules with a bit of HURR DURR DURR, add some hardware from Home Depot, let steep for 1-8 years, shake, strain into chilled glass, and garnish with some borate. Yay. I wanna add some hurr durr myself and skip ahead to the one answer I have left; is everyone just taking a glove (or two (or three? (yikes))) off when they need access to the screen? Glove-friendly is maybe a quality to miss about dedicated GPS thingers. Then again, remember browsing a map on my Zumo was something like trying to get sand out of your eye with a pipe wrench. Plus, anything easy for me to use while driving usually leads to me submitting my Darwin awards application ahead of plan ... I'm looking at you, triple-digit selfies ... and as such I'm banned from even having a tank bag. So, are there alternative control methods besides holding one glove in your armpit so it doesn't fall off or putting it on the the bars but it still falls off just out of reach and you have to put the bike on the kickstand and walk around to the other side to pick it up while everyone laughs at you? Are we attaching a stylus to our bars with velcro? Getting all Frankenstein with spare finger stashed in that stupid pocket on our jacket sleeve that nobody uses? Has Gore invented SwipeTex? Someone want to halp me out, assuage my curiosity, and enable my thread parsing lazies? Or, do I have to get all Tomb Raider on this thread to reveal the wisdom? Thx. Ps. I missed all you FFs muchly.
    Argus16, ADVQuest228 and MrMac like this.
  11. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    8,514
    Providence, RI
    So many wurdz...
    My Samsung phones S6, S8, S9 all have had a sensitivity mode that allows the glove to work.
    ixab likes this.
  12. AdvNener
    AdvNener Long timer
    May 29, 2013
    3,064
    Marseille, France
    Convenient location for a stylus here.
  13. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,088
    East Med, Greece
    Kyoceras are getting expensive and obsolete.
  14. Shawnee Bill
    Shawnee Bill Long timer Supporter
    Feb 25, 2006
    5,689
    Oklahoma
    Search Amazon for gloves that work on touch screens. I have a pair that works OK, not quite as good as Garmin touch screen but ok.
  15. White Raven
    White Raven Been here awhile
    Apr 3, 2016
    162
    Saturn
    Read my review to help decision. Have fun...
  16. ohgood
    Sep 21, 2010
    10,245
    alabama
    See the ultra rugged smartphone thread
  17. Overanalyze
    Overanalyze because when given the option, I will overthink it
    Mar 3, 2017
    155
    I believe in system redundancy i.e. just in case. I have a Garmin V for my bike and as well I carry a cell phone. I have seen instances where the Garmin has a better map or more complete map than that offered on the cellphone not to mention cell coverage.
  18. AdvNener
    AdvNener Long timer
    May 29, 2013
    3,064
    Marseille, France
    Mentioning cell coverage on this thread may be a call for violence.
  19. Shawnee Bill
    Feb 25, 2006
    5,689
    Oklahoma
    If by Garmin V you mean BMW Nav 5 I have many miles looking at both Nav 5 and Locus and/or Osmand, I will say they all display the same navigation information but each has it's own "personality", hard to say that one is "better" than the others. As for other info, distances to points, time to points and other info the cell phone apps have it all over Garmin for that type of info.
    I will say that I love the BMW 'wonder wheel' interface, if not for that I would not bother with anything Garmin.
    For cell coverage I have a cell phone, rarely use it for navigation, however I do use it to find commercial POIs, it is much more complete than anything Garmin at that.
    Overanalyze likes this.
  20. SCPancho
    Oct 27, 2005
    35,034
    Upstate SC
    One comment I have is, I find the Nav screen much easier to read than cell phone apps. The street names are bigger and upcoming cross streets are displayed. I haven’t found an iPhone app with names big enough to read on a phone a few feet away. I have no problem following tracks on my iPhone using pocket earth pro, but routes have never worked well.i love the wheel too. Zooming in and out is easy. Trying to pinch a touchscreen with gloves is a disaster.
