Designated GPS unit vs. Smart Phone
Discussion in 'GPS 101 - Which GPS For Me' started by NJDirtRiders, Nov 24, 2013.
  1. portablevcb
    portablevcb Long timer
    Apr 25, 2015
    1,484
    nm usa
    I am another who uses my Samsung S5 in direct sunlight. I think the sunlight here at 7000ft is a bit brighter than down near sea level (at least a lot more UV). :)
    Yes, use auto brightness. I also mount mine so it is not 'flat' to my eyes. Angle it 'down' a little and the direct glare is not an issue. Reflected glare, like from a silver or yellow jacket, can make almost any device unreadable (including an instrument panel :) ).
    I also pick different color schemes to get the best contrast in direct sunlight. For my old Magellan unit it worked better in 'night' mode.
    And, yes, multiple backups is good. I also have a Garmin mounted next to my phone. And I do keep a map and compass around just cause that's how I did things 30 years ago. :)
    A Stelvio and complaining about electronics? I hope you have sealed up your computer on that thing :) Do you have a backup if it stops sparking? :D
    And there is nothing wrong with old bikes. Mine has even been 'modernized' with one of those newfangled ignition modules. But, I still carry a plate with the dual points in case the new bit of electronic wizardry goes belly up.
  2. filterx
    filterx Been here awhile
    Dec 4, 2012
    206
    Sḵwx̱wú7mesh
    You as well my friend.
    I recently gotten some good PDF base maps for an area I like to ride. They work great in Avezna PDF Map reader but I'm trying to figure out how to use a PDF map as an off-line base map in Oruxmaps and think I'm missing something. I don't need all topo features of a Garmin off-line topo. If your into it and want to download Avenza on your phone, I can send you the PDF map and you can look at it. At this point I can run both Oruxmaps and Avenza but.
    Anyone input would be awesome and feel free to send me a PM here or at TT if you want
  3. ohgood
    Sep 21, 2010
    10,248
    alabama
    the only way I've found to use pdf files in orux/locus/etc is to convert them to jpg /JPEG and then use Google earth or locus (depending on preference) to make an image overlay (kmz) out the jpeg. i don't have a GREAT solution for converting the pdf, and only use the built in image handling in Mac OS called "Preview". it usually pixilates the image or lowers the quality to a poor enough level that I'm not entirely pleased with the results.
    this website has me interested in the process again:
    http://petapixel.com/2016/08/06/nat-geo-launches-free-website-printing-detailed-topographical-maps/
  4. MrMac
    MrMac Long timer Supporter
    Aug 19, 2007
    2,816
    Dacula, Ga.
    One option for converting from GeoPDF is G-raster. I haven't tried this in awhile, so not sure if it still works:
    http://moagu.com/?page_id=155
    http://freegeographytools.com/2011/cheap-geopdf-to-geotiff-converter-for-garmin-custom-map-imagery
    I believe it will export to .kmz files directly. I may install it again if I get some free time..
    Here is the recommendation from the USGS:
    http://nationalmap.gov/ustopo/documents/ustopo2gtif_current.pdf
    Globalmapper really has the best conversion tools for just about any geodata format I've ever used. But alas, I no longer have a license for that either and it is a little pricey for occasional use!
    ohgood likes this.
  5. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    Up. And to the right.
    So I'm completely stupid when it comes to phones. I still use a flip phone actually.
    So, I can buy an S5 for ~$150, install a GPS app, and I'm good to go? Do I need to actually pay per month for the service? Does it need to be connected to a network? Or just turn it on and that's it?
  6. Bruincounselor
    Bruincounselor North Plains Drifter Supporter
    Apr 1, 2006
    2,222
    Northen Plain
    No service needed to use an S5 for GPS. I will mention that the screen on that GPS is one that won't work with standard gloves on. I encourage you to go back 10 pages and read through the thread - you'll learn what you need to know to get started without having to read the whole thing.
  7. Dolly Sod
    Dolly Sod I want to do right, but not right now
    Aug 18, 2003
    18,875
    Richmond, Va
    You'll need to buy the apps as well. I think osmand is $10 as well as locus and copilot. After that, the map updates are free.
    I think I spent around $30 or $40 for the various apps that I use. There are lots of free versions, but I hate ads and like to contribute to the development of these apps that I rely on.
  8. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    I gotcha. Makes sense. And I don't need connectivity to maintain a GPS position? I can just set it to airplane mode and I'm good?
  9. ohgood
    Sep 21, 2010
    10,248
    alabama
    the only phone I've used that didn't allow for gps antenna usage while in airplane mode was my kyocera hydro air. it actuallty disabled the GPS antenna on that phone. to use the GPS antenna and Dave battery, i just turned off cellular data and it worked fine. every other device I've seen prior to and after that works just fine in airplane mode.
    you are correct, you do not need data/contact service on the phone ever, to use its gps/Bluetooth/wifi capabilities.
    it's a good idea to update its GPS almanacs if you do a fly n ride, at the airport but mooching of their wifi. otherwise it might take five minutes for the initial GPS triangulation.
  10. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    Been a terrific help. I'll keep an eye out for a cheap Numo or S5. Thanks man.
    ohgood likes this.
  11. garzan
    garzan Been here awhile
    Jan 26, 2014
    651
    Udon Thani, Thailand
    Just read that again, and see the "standard" :-) I use an S5 as well, and use Rev'it gloves, but they are made to work with a touchscreen (so not standard.)
    ohgood likes this.
  12. worwig
    worwig Long timer
    Nov 30, 2009
    2,097
    Hog Mountain
    You do NOT need to pay for a connection. You WILL need WiFi to set it up, to load the apps and the maps. You WILL almost have to have a Google account to do that (though that can be bypassed to somewhat).
    The S5 if a good device, but you may want to look for a really cheap Android to see if it looks like the thing for you. Maybe someone you know has an old one in a drawer collecting dust. I wouldn't drop $150 on one just to find you don't like it.
    ohgood likes this.
  13. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
  14. Albie
    Albie Kool Aid poisoner
    Mar 31, 2004
    16,184
    NWA
    That's odd considering I use regular gloves with my S5 all the time.
    levain likes this.
  15. BikerBobber
    BikerBobber Trying to get lost
    Feb 28, 2011
    1,308
    Seeleys Bay, Ontario
    S5 works worth gives. Just turn on " increase screen sensitivity" in display settings.
    Apps can be had for free as well as maps. I however, paid the wapping fee of $2 to get OsmAnd pro....
    Bob
  16. BikerBobber
    Feb 28, 2011
    1,308
    I have a "like new" S4 with spare battery, for $40 US if anyone's looking to try.
    Bob
    ohgood likes this.
  17. Bruincounselor
    Apr 1, 2006
    2,222
    Northen Plain
    Wow - I wish I had found that a couple of years ago. BINGO! Thank You.
    ohgood likes this.
  18. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    This something I could use solely for GPS and perhaps MP3 w/ a Bluetooth Headset?
  19. ohgood
    Sep 21, 2010
    10,248
    alabama
    it might, but the alcatel /tracfone branded units are usually lower spec processor/screen, in a much lower league than the typical Samsung phones. i would grab that s4 that was offered above and try it out instead. generally speaking the Samsung mud to high end flagships are always a safe bet, from my experience.
  20. ohgood
    Sep 21, 2010
    10,248
    alabama
    side note, you guys are making this thread ROCK!
