Designated GPS unit vs. Smart Phone
Discussion in 'GPS 101 - Which GPS For Me' started by NJDirtRiders, Nov 24, 2013.
  1. Bruincounselor
    Bruincounselor North Plains Drifter Supporter
    Apr 1, 2006
    2,187
    ohgood likes this.
  2. BikerBobber
    BikerBobber Trying to get lost
    Feb 28, 2011
    1,308
    Seeleys Bay, Ontario
    I use the Ram Quick Grip for off-road:
    http://www.rammount.com/part/RAM-HOL-PD3U
    And a Slip Grip for car and street bike.
    http://www.slipgripcarmounts.com/Sl...-i9600-Using-LifeProof-FRE-Case_p_145263.html
    I think the Quick Grip is the ultimate hold, just barely fits my S5 with a Lifeproof case, and is crash tested multiple times .
    The Slip Grip is easier on and off but the phone rattles in it a bit. I wouldn't trust it in an off. Fine for street or light off road duty.
    I use the Lifeproof case, even though the phone is already water resistant, to add another level of protection. I fall down alot and am VERY hard on my stuff.
    With this case I have taken underwater video with my phone while swimming. It also protects the screen from sand, dust scratches.
    Bob
  3. ohgood
    Sep 21, 2010
    10,245
    alabama
    broken record time (me)
    after buying the RAM mount and realizingg how flimsy it was, and then finding a rubber band in the packaging that was intended to help hold my phone in their $70 mount... i cut up an innertube similar to the finn bike mount and started using it. simple, fast, fits every phone I've seen.
    if someone wanted the most secure mount ever, that perfect squeeze is the one to get
  4. scootertrog
    scootertrog Jedi Fart Master
    Mar 26, 2011
    1,648
    Springfield, MO
    Bob,
    Are you using the correct SlipGrip cradle? I have quite a few SlipGrip cradles and not one has ever been a loose or sloppy fit.
  5. BikerBobber
    Feb 28, 2011
    1,308
    Yep. Right one.
    Not sloppy loose but not a tight fit either.
    Slip Grip
    And Ram Quick Grip
    If I could only have one it would be the Ram. A lot cheaper too....
    Bob
  6. Dolly Sod
    Dolly Sod I want to do right, but not right now
    Aug 18, 2003
    18,875
    Richmond, Va
    I am a big fan of that RAM mount. I have run hundreds of miles of rough jeep trails and tons of jumps and wheelies plus the general constant vibration of my 640 Adv and the phone hasn't moved.
    There are other rams mounts, the X and the springy finger one that I don't put much stock in.
  7. DingDangKid
    DingDangKid El Lechero
    May 27, 2009
    4,361
    Tioga County, PA
    By far the best phone option. I've used it with my iphone 4s and Galaxy S4 both with otter boxes. I've run it on the TW, Wee and Mt Bike with it never losing the phone.
  8. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    Up. And to the right.
    Been looking at S5. They seem to be in the $150/$200 range. There any other phone that is comparable? I punched in HTC (Desire?) into CraigsList and they can be had all day long for $40. Would those work?
    To add to this, how'bout Kyocer Hydro Air? They're like $40 new. Read a few places of folks using them as a GPS as well.
    Heh, whoops. Forgot you posted this. So this phone will work as well?
  9. HLK
    HLK aka Hielke
    Nov 25, 2008
    165
    The Netherlands
    Guys, here's my setup. It's an Xperia Z Ultra 6.4" phablet mounted on a piece of cutting board, RAM-mounted to the handlebars. The posts are M5 bolts double wrapped with silicon tubing that thread directly into the cutting board. I basically lay the phone on the cutting board and drill the holes in such a way that the phone is jammed in between the posts. I don't run the tap all the way so holes are slightly conical and the bolts fit nice and tight. It has held well for over 7000km on a trip to the Balkans.
    Apart from the RAM mount that I had laying around (they've pretty much doubled in price here in euro land) it's dirt cheap.
    I use Locus with BRouter to create tracks on the spot and then ride the tracks with Locus in guidance mode. I don't bother with instructions.....it's more fun to read the map and it's more flexible when taking a detour. I send the track to my buddy's phone over WiFi with ES File Explorer so we can both navigate. Combined with intercomms it's just awesome.
    When I just want to go from A to B I'll use Sygic.
    I picked the Xperia Z Ultra because it's waterproof and has a nifty magnetic charge port. All the Xperia Z's have that....but I just had to have the big one. I tested this setup on a 4 day road trip and it worked amazingly well, fully charging with the screen on full brightness all the time and music streaming to my intercom. It doesn't seem to suffer from the heat like my iPhone.
    The only cons: on our Balkans trip it developed a problem where it wouldn't take a charge, which is apparently a common problem. I'm looking into somehow hard-wiring it. Maybe a new battery will help as well. And it is a bit of a hassle to take on and off the bike with the cable and the USB 12v outlet thing. The touchscreen goes berserk in the rain.
    I got my inspiration from...Garmin. Figuring I needed 'real' navigation for our ride in the Balkans I got myself a second-hand Zumo 660. The device is 2009 tech which is bad enough, but I just couldn't bring myself to learn Basecamp. Maybe it's my short attention span, but if I can't get results with a piece of tech within the first 20-30 minutes of tinkering I lose interest. I'm not taking a fucking 4 hour DVD course from some old guy to learn how to draw lines on a map.
    I did take the Zumo as a backup to the Balkans. It proudly served as trip recorder and speedometer. Where the Zumo shines: take it on/off the bike in seconds, no charging cables to worry about, the touch screen keeps working well in the rain (although it doesn't work well to begin with). It's really good for "It's fucking raining, take me to a gas station then the nearest hotel".
    I say the time is more than ripe for rugged 6" android device with a couple of chunky physical buttons (handlebar mounted buttons for zooming the map would be awesome). Make it open source, open everything. Leave the software development to the community.
  10. Dolly Sod
    Aug 18, 2003
    18,875
    Richmond, Va
    S5 active is basically the same phone but usually cheaper. I'm not sure why.
  11. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
  12. Dolly Sod
    Aug 18, 2003
    18,875
    Richmond, Va
  13. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    Ah, I see. S5 is the same as the S5 Active. I gotcha.
    I have two PM's out to folks on the Kyocera. See what their input is on that device.
  14. AdvNener
    AdvNener Long timer
    May 29, 2013
    3,064
    Marseille, France
    I had the same problem with charging on my Z2... so i could test and copilot+full brightness takes about 15% of battery capacity per hour. But i think my problem was that the cord was somehow pushing the magnetic plug away (but not completely so the device was "trying" to charge). It happened 2h before the end of a riding day... i could charge the phone at the hotel room and had no problem after that.
    The screen goes berserk in rain indeed, but both copilot and locus have a locking feature.
    HLK likes this.
  15. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    10,975
    vermont
    I've been using one as my GPS phone for a few years now. It's just about perfect. If it died tomorrow, I'd find another.
  16. ohgood
    Sep 21, 2010
    10,245
    alabama
    seriously good write up of how to do things. looks like you're one step away from making your own (or buying) a perfect squeeze mount for your phone. really enjoy the inginuity happening here !!
  17. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    So I pretty much have it nailed down to what phone I'm going to use. My last concern right now is RAM. The Kyocera only has 1GB. Will that be enough to handle OsmAnd and music playing in the background? The S5 Active has 2GB. As someone with 32GB of RAM on their PC, I'm skeptical on the 1GB in the Kyo.
  18. HLK
    HLK aka Hielke
    Nov 25, 2008
    165
    The Netherlands
    Thanks! To be honest I came close to buying the Perfect Squeeze. Looks like a great product and if you're in the US it's a good deal compared to the alternatives. It's just that it doesn't quite fit my Xperia Z Ultra. I also wanted something that gave a little bit more protection since the phone is made out of friggin glass.
    I bought the cutting board because the HDPE plastic is indestructible, cheap and easy to work on, but I couldn't quite decide on how to build a mount out of it. The night before departure I had to cobble something up and discovered that tapping threads directly in the board worked surprisingly well. 20 minutes later...and it was sitting on the bike. Definitely one my more successful last minute creations.
    Possible improvements:
    - make the posts conically shaped so the phone is even more secure. The silicon rubber is a bit too soft and slippery by the way, but it's what I had lying around.
    - make the posts sliding or spring-loaded. Hm. Lots of ideas there.
    - integrate the magnetic charge cable so the mount basically becomes a powered dock for the phone
    - maybe a sun shade. The screen was easy to read even in sunlight, and when I bend forward slightly the sun shade on my helmet covers it nicely
    - make it purdier with thicker edges....though I like the ghetto 'yes it's a cutting board' look
    Yeah there is something weird going on there. It also seems like the USB connector on my Z Ultra is unreliable. Plus I couldn't resist putting Cyanogen mod on it, maybe I should have stuck with the stock Sony firmware for best battery performance. I will look into making a solid dock for it or even soldering a bunch of wires onto the power connector. I'm not using it for anything else anyway.
  19. worwig
    worwig Long timer
    Nov 30, 2009
    2,079
    Hog Mountain
    I just fired up OSMand+, and the setting show that it is using 733KB of RAM. Of course I have about 2GB of storage rom used for maps. I then zoomed way out and had it plan a 400 milers trip. It jumped 'up' to 7.9MB.
    Planning a long trip in CoPilot used 2.2MB.
    I think 1GB is fine.
  20. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,699
    Excellent.
    Alright. I'm over analyzing (Schmokeling) the shit out of this.
    AT&T Kyocera Hydro Air - $40
    OsmAnd+ Maps & Navigation -$7
    Ram Mount Cradle Holder - $24
    Kyocera Hydro Air Case - $10
    SoundPEATS Bluetooth Headphones - $20
    Will this setup get me a running GPS and music player for my DR? I hate stopping to take pictures, I don't need to read forums, I don't need to watch YouTube. Just GPS and music. Nothing more. With those listed things above, I should be on my way, correct?
