Details on 2014 690 enduro r?
Discussion in 'Thumpers' started by BigTony, Jul 3, 2013.
  1. itnanti
    itnanti aka "cautious cotta"
    Nov 29, 2012
    1,102
    Pismo Beach
    Just ordered a couple of more from the aussie site this morning on my phone. 75$ for two shipped to Lynnwood Wa.
  2. ChuckHazzard
    ChuckHazzard Registered Lurker
    Mar 27, 2005
    1,860
    The corn state,11 curves in 318 miles (Iafalls IA)
    I just ordered one from them as well.
    $42 bucks USD shipped if the conversion rate is correct.
    Over $100 USD from touratech!?!
    (Which is on back order anyway)
    :hide
  3. xathor
    xathor Not actually Gnarly
    Aug 2, 2009
    449
    Huntsville, Alabama
    You know, when I replaced the battery I spent like five minutes staring at this cable that I swore I got off the positive side but I connected to the ground because it was black...
    Does that mean that we could put a large amp relay in line with that cable and turn ABS on and off with the flick of a button?
    I'll swap cables when I get home and see if it fixes my issue.
  4. ttime4four
    ttime4four JZ
    Aug 16, 2011
    527
    West Linn, OR
    690 Enduro 08-15 AU 1417
    I got mine directly from Australia - easy. Just select the country / state and you are good to go. And yes - the US version bottoms out on the '14+ because the airbox is smaller to accommodate the ABS brain. It would also be incrementally harder to clean vs the AUS version. I had the US filter but returned it.
  5. ChuckHazzard
    Mar 27, 2005
    1,860
    Yep. That's what mine looked like an hour ago.
    Ordered it the same.
    I can't believe the U.S. Dollar is worth more than another country. :deal
  6. sweetlou
    sweetlou small body, big balls
    Jun 22, 2008
    2,570
    Melville, NY
    Do you need a new map with the unifilter and stock air box?
  7. itnanti
    Nov 29, 2012
    1,102
    Pismo Beach
    I dont think so since you are still using the cover.
    I run a wings with this filter and didn't remap, not sure if I should or not.
  8. Dan950ser
    Dan950ser Two Wheeled Addict
    Sep 24, 2010
    2,550
    Olympia, WA
    I'm going to do a new map regardless. A new open exhaust with the European map is supposed to help a bit.
  9. moto74
    moto74 displaced
    Sep 18, 2012
    1,043
    BOP, NZ
    I looked at the Aussie Uni Filter site a while back, and the # 1417 said "690 Enduro 08-11" (or 10 or 12, can't remember), I see it's now "690 Enduro 08-15". So they're saying it fits the ABS models. Have just ordered one, and picked up some 'No Toil' rim grease locally. Will see soon enough if it drops straight in.
  10. sethc06
    sethc06 Been here awhile
    Mar 5, 2014
    243
    North Idaho
    Can somebody with the Aussie Uni go through the process of getting them air tight? Any grinding of the air box lid? Cutting down the foam lip of the Uni? Or just drop in and apply some grease?
    Pics?
  11. ttime4four
    ttime4four JZ
    Aug 16, 2011
    527
    West Linn, OR
    For the AU Unit, I don't have any pics handy, but I did do the airbox "edge squeeze cleanup" that was discussed here. This is where the slop of plastic squeezes out in the corners/edges. Involves taking the airbox out but no modification. Dremel, file or exacto knife are suitable. From here mine just dropped in - no drama - added some grease for a better seal and done.
    With the US Uni, I was fighting it to go in.
  12. sethc06
    Mar 5, 2014
    243
    North Idaho
    Awesome, I went ahead and donated my US Uni that was still in the packaging to a pre 2014.
    So basically, disassemble the airbox, and clean it up to the standards that any other motorcycle company would have shipped it with, then adding some grease to the top surface of the Uni after dropping it in?
    My 2015 comes in a couple of weeks, but I'm trying to get my parts lined out in the garage before hand, exhaust, seat, and all the other goodies are waiting, but the filter/airbox was my main priority.
  13. seeking
    seeking Adventurer
    Apr 21, 2014
    63
    Montreal, Qc
    Hi, I went and started my bike last week after it's three month hybernation period in a heated garage. The bike had a little trouble starting but I expected that, what i didn't expect is that the front brake feels like the clutch! I can pull it all the way to the grip and it only brakes a little, do i just have to bleed it? If it helps it was in a heated garage and off its wheels on a jack stand, oh and I tried pumping it for like 5 minutes and nothing changed.
    :freaky
  14. Capt CF
    Capt CF Pontificating Nobody
    Jul 1, 2013
    1,493
    Northern Virginia
    That's definitely where I would start.
  15. Beeners
    Beeners Been here awhile
    Apr 14, 2014
    100
    Placitas, NM
    This one has me stumped. I've noticed that whenever I ride my 2014 690 Enduro R, my right foot and lower pant leg gets a spray of some dark residue on it. It happens even when riding on-road. The left side does not get this residue.
    I don't see anywhere on the bike that seems to be spraying anything out.
    Has anyone else noticed a residue spraying on their right boot and lower pants leg?
  16. THop
    THop Adventurer
    May 29, 2012
    95
    Newfie fun Land
    I call oil bro. Check your covers and engine over good. Alot of people have been having oil leakage problems from the cable gland going to the stator through the engine case.
  17. MotoPundit
    MotoPundit MacGyver
    Jul 23, 2009
    3,440
    Ottawa, Canada
    For the first few hundred miles on mine, I was getting some engine coolant on my right foot/lower leg. Mixed with some dusty roads, it looked a bit like your pant leg.
  18. Beeners
    Apr 14, 2014
    100
    Placitas, NM
    I'm pretty sure the residue is from the bottom fitting on the charcoal canister. Is there supposed to be a plug or vent hose attached to the bottom?
    I added a PVC hose to vent it into the plastic slip plate under the engine.
  19. sweetlou
    Jun 22, 2008
    2,570
    Melville, NY
    I ripped mine off :)
  20. itnanti
    Nov 29, 2012
    1,102
    Pismo Beach
    Anybody get blinking FI codes on their 14s yet. Rolled out of the drive way this morning and it was struggling to idle and I was getting an FI blink. Didn't have time to check out the code running late for work. I'll have work on it tonight. Hopefully its a bad connection and not a pump at 6000miles
