Details on 2014 690 enduro r?
Discussion in 'Thumpers' started by BigTony, Jul 3, 2013.
  1. Simonhantler
    Simonhantler waiheke simon
    Jun 11, 2013
    557
    Waiheke island New Zealand
    yep i put that kouba link on and shortened the side stand 30mm (1") and put big footprint on stand while it was off.
    but the kouba link 1 5/8 needed to be ground down on inside top get past a bolt on ktm swingarm.
  2. ToeDown
    ToeDown n00b
    Sep 8, 2014
    7
    I've gone with the .75 inch drop on the forks and all seems well. Happy days:thumb
  3. finbarr
    finbarr Would be adventurer
    Feb 13, 2010
    327
    London, UK
    Saw a post on here tens of pages back on lowering the foot pegs - so had a go at doing it. I have long legs and have as much bar rise as I'm willing to put in, but still needed to drop the pegs a bit more to be properly comfortable when standing. This mod has worked really well - I'm very happy with it.
    I used 2x 10mm bolts, 100mm long and chopped about 5mm off the length. I've got rally pegs on the bike and wanted to get the springs back in there - this was easy on the left, but the right spring needed a slight tweak so that it would sit flat.
    I also moved the rear brake bracket rearwards to its maximum, and adjusted the plunger length to minimum so that the brake lever would sit in the right position. The stop bolt was replaced with a longer version and this all works perfectly. It meant I didn't need to flip the brake tip over to get everything sitting correctly.
    The gear shift was dropped by two splines to compensate. The nuts on both bolts are threadlocked and will be marked with paint to show any movement - hence, nuts at the top, rather than underneath.
    roespan likes this.
  4. Wansfel
    Wansfel I'm not lost! The world is just a bit misplaced.
    Sep 10, 2009
    3,033
    Bitterroot Valley
    I used nylock nuts rather than thread locker. But, been working fine for several months now.
  5. mrwwwhite
    mrwwwhite Been here awhile
    Jun 14, 2010
    990
    Bucharest, Rallying or RTW
    Personally, I would not risk with this method. The two footrest brackets are cast aluminum so not that tough. I know just like that, they look fine but you don't want to drop it since that bracket is ~150E and will fracture easily. If you really fancy this at least put a big spacer where the peg was before so that when you tighten the bolt you don't deform the cast brackets.
    On a different note cutting and welding the pegs is much safer since a good TIG welder would make them as strong as before. I did exactly that to my pivotpegz and you can see some pics on my build thread here. Love the lowered position and combined with ~30mm risers gives a perfect standing position. (I'm ~180cm tall)
    There's also lots of other mods which fit the newer models and for people researching about adventurising the 690 or rally kits here's a post with my thoughts about them and the beginning of building one of these which will fit the 14-15 models as well:
  6. finbarr
    Feb 13, 2010
    327
    London, UK
    I've had a few comments in another location about the inherent weakness of this mod, so will probably take your advice and do something a little stronger. The nut isn't done up very tight at all, there's about 1mm of play in there as I didn't want to stress the brackets, but it is threadlocked. Additionally, any tighter and the pegs no longer fold up/drop back down. So loose is good.
    I'm looking forward to reading your build thread later today.
    Thanks for your comments - much appreciated.
  7. Motomochila
    Motomochila Moto Scientist and time traveler
    Sep 30, 2007
    1,702
    N 34 22.573' W 118 34.328'
    That lowering mod looks sketchy to me. Standing would be a gamble . :huh
    Wouldn't a re weld of the foot pegs be a much better option?
  8. TheGearDude
    TheGearDude Long timer Supporter
    Apr 25, 2015
    1,178
    Everett, Washington
    Ya I would have to agree that lowering method looks sketchy. I went with the Black Dog Cycle Works pegs low version and they aren't much lower but you can notice a slight difference.
    <a href="http://s1273.photobucket.com/user/clara_pellar2b/media/IMG_0377_zpsvti8rwku.jpg.html" target="_blank"><img src="https://s3.amazonaws.com/advrider-photobucket-images/images/c/clara_pellar2b_IMG_0377_zpsvti8rwku.jpg" border="0" alt=" photo IMG_0377_zpsvti8rwku.jpg"/></a>
    <a href="http://s1273.photobucket.com/user/clara_pellar2b/media/IMG_0381_zps2prt4fsk.jpg.html" target="_blank"><img src="https://s3.amazonaws.com/advrider-photobucket-images/images/c/clara_pellar2b_IMG_0381_zps2prt4fsk.jpg" border="0" alt=" photo IMG_0381_zps2prt4fsk.jpg"/></a>
  9. finbarr
    Feb 13, 2010
    327
    London, UK
    Thanks for the replies - I'm having a chat with a local machine shop to see if I can get them to fab something that works. Most of the off-the-shelf pegs only offer 2 or 3 cm lowering - which is about half of what I need. The problem with having long legs...
  10. mrwwwhite
    Jun 14, 2010
    990
    With the bolt method you probably get 35mm and with the weld method I went for 25mm.
    If you need more than that I would not lower the pegs that much but rise the HB as well. Now I have about 60mm offset from OEM: 25mm in the pegs and 35mm in the HB risers.
  11. Motomochila
    Sep 30, 2007
    1,702
    Mods almost finished on my 2014. 300 mm Tractive rally shock and SX fork swap for suspension makes for a VERY tall ride. On toes I can touch without sag corrected-no fuel or gear on, but I'm 6'1". This mod is not for the vertically challenged or those worried about tipping in ruts.
  12. THop
    THop Adventurer
    May 29, 2012
    92
    Newfie fun Land
    Ouch thats a tall girl, I can flat foot both feet on my complete stocker 2014 with no luggage and I'm comfortable with that. What are you planning on riding over mountains? lol
  13. Motomochila
    Sep 30, 2007
    1,702
    Actually, yes! The 690 will be my BDR bike. My first ride on her will be the COBDR in August, and then finish off by riding back on the continental divide. From there I'm doing the UTBDR, south to north, then finally the IDBDR. Based on my calculations, I figure about 12 mountains to be exact.
    I am considering packing a small step stool.....just in case. :D
  14. THop
    THop Adventurer
    May 29, 2012
    92
    Newfie fun Land
    I have heard those root names before, i have to look them up and if they fit into my ride across the TAT or are close maybe il poke over for a look. As for the step stool, i suguest retractable stilts or go go gadet legs more usefull when you really need em lol
  15. mrwwwhite
    Jun 14, 2010
    990
    You will love it no matter what people are babbling!
    Did you swapped the triples with reduced offset?
  16. Abersouth
    Abersouth misadventurer
    Aug 31, 2014
    268
    Fort Collins, Colorado
    Concerning the Rally Raid shocks.
    Are there any big differences in performance between the RR Rally and the Adventure shocks? I know about the adjustable height of the adventure. Is the RR rally shock more bombproof or something?
    I'm going to get one or the other, just trying to figure which one might be right for me. I'm tall enough that the 300mm is going to work good. I won't be racing the bike, but I will get on it for fun. Dreams of doing multi month travel with it.
  17. Motomochila
    Sep 30, 2007
    1,702
    In the box and ready to mount this week.
  18. Motomochila
    Sep 30, 2007
    1,702
    I've got zero time on the bike so far. Parts and the death of my dad last October has kept me from completing a bike I bought new in May of last year. The offset triples just showed up from Austria last week. From what I've been told from a few who have gone the rally versus the adventure is; much better performance when hard use, and the fact that it has more adjustments. Doing it again I'd go with the 275 mm adventure shock for a bit lower seat height.
  19. mrwwwhite
    Jun 14, 2010
    990
    The biggest difference between Rallye and Adventure or Overland is the PDS addition for the Rallye. Position Damping System will basically ensure a bottoming free shock and will allow different settings compared to Adventure or Overland.
    :D Looking ace!
    Sorry for your loss! Been through that 7y. ago :(.
    Hard use means bottoming hence the PDS. You don't have to be Coma to bottom this heavy bike so if money is not an issue, I'll go with Rallye anytime no matter the riding style (unless one uses the 690 as a daily commuter on tarmac, but then you don't think the 690 OEM suspension sucks big time). To lower it a bit, you could get a new seat which although with reduced amount of foam will be much more comfortable than the stocker.
  20. Motomochila
    Sep 30, 2007
    1,702
    I rode the piss out of my 2009 with a revalved stock shock and new heavier spring. Did Baja...on the race course, twice and Copper canyon, Death Valley, and numerous other rough offroad tracks. When the whoops got any deeper than about 18 inches, the stock/modified suspensions wallowed and began to squat after only a few bumps. It was Blias Racing that originally convinced me to go with a Race type shock instead of an "adventure/travel" shock. Now that I've got some serious cash wrapped up in my 2014 Rally Build, I'm not interested in tossing her on the trail due to suspension shortcomings. Besides, since I'm getting to be an old F*@k, I need all the help I can get. I'll post up pics and results as soon as possible. Next up I need to get that triple mounted.
