Dickin Around in Doug's Garage
Discussion in 'Old's Cool' started by rtwdoug, Oct 16, 2009.
  1. knybanjo
    knybanjo kinda slow
    May 8, 2006
    36,696
    out in the clover patch
    I think you should convert that FXR into a racing bagger.
    ullukk, AZbiker, villageidiot and 8 others like this.
  2. rtwdoug
    rtwdoug prominent underachiever Supporter
    Dec 7, 2004
    5,511
    Alabamski Oblast, Redneckistan
    Went for a ride on the 35 VL today, made it about 1/4 mile, and hit the rear brake, and the wheel locked up. Everytime I hit the brake, it locked. So I came home and jumped on the 48 chief instead.
    I just tore into the rear wheel, and one of the bearing cages inside the brake hub had broke, I have no idea how or why. It looks like it had been broken for awhile, by the wear on the break. I just had it apart when I installed new tires in Colorado, and have maybe put 3 or 400 miles on it. Everything looked OK then.
    I have a spare VL wheel, but of course its a front, and the bearings inside the brake drum are different....
    zookster, ullukk, SmilinJoe and 7 others like this.
  3. rtwdoug
    Dec 7, 2004
    5,511
    inner axle was a little pitted and had some light wear ridges, but its better now.
    zookster, ullukk, roadcapDen and 9 others like this.
  4. riggpigg
    riggpigg Known,but not famous Super Supporter
    Feb 6, 2008
    1,681
    Kansas 54/281
    Looks as though that sprocket mighta been used too much when it was new............:lol3
  5. DJones
    DJones Been here awhile
    Mar 25, 2008
    193
    Dalton, GA
    Classic line!
    I've got lots of stuff that was used to much when it was new, or maybe I just kept it to long.
    Honda-50 and riggpigg like this.
  6. riggpigg
    Feb 6, 2008
    1,681
    Kansas 54/281
    We missed ya in Arkansas man!!!!....was a good time!!!
  7. rtwdoug
    Dec 7, 2004
    5,511
    I picked up this '45 Chief last month, and want to get it tuned up and pretty before I send it down the road. It looks like over the last 15 years of sitting, the gas leached past the petcock threads and raised the paint on the tanks. A local friend is going to repaint them as a partial trade towards an old Penton I found back in the spring.
    Unfortunately tho, some DPO had lined the tanks with Kreme, which as we all know, is Krap, ands its lifting off. So I have to get the old liner out, and reline them with either Redkote or Caswells. Im going to try to get them cleaned out with acetone first, if that doesn't work, ill have to have them hot dipped at a radiator shop.
    Fun Fun!
    20201030_061622.jpg 20201030_061640.jpg 20201030_061717.jpg 20201030_061703.jpg
    zookster, ullukk, roadcapDen and 7 others like this.
  8. eldomike
    eldomike Who Cares Supporter
    Aug 6, 2009
    1,649
    Southern Illinois
    I've heard MEK works but never tried it...I hate that Kreem Krap
    koh kood, MZRider and Oilleaker like this.
  9. Oilleaker
    Oilleaker Ne’er do well tinkerer Supporter
    Nov 20, 2019
    302
    Bronx NY
    If you’re repainting anyway, MEK will take it right out. Add a few pieces of chain in the tank to loosen up any stubborn areas. If you’re real careful you can do it without damaging the paint but mine cracked around the filler cap from the fumes.
    Plug any petcock opening with wine corks and fill the tank. Keep it in a garbage bag outside to hold the fumes in and let them work. The fumes are pretty nasty so do not attempt indoors
  10. ShOqUePoT
    ShOqUePoT GS Pot
    Mar 22, 2009
    8,546
    The VT of MA
    Do you know who you're talking to? Doug could probably give classes on this stuff, as long as OSHA's not around. The only reason he's trying Acetone first is because he probably got a drum of it free with the purchase of a vintage Harley. :lol3
    villageidiot and Oilleaker like this.
  11. r60man
    r60man Long timer
    Mar 14, 2013
    2,205
    Centralish PA
    That Buick is sweet, and having the book is icing on the cake. A steal at $500.
    ShOqUePoT likes this.
  12. Oilleaker
    Nov 20, 2019
    302
    Bronx NY
    Always a good idea to start with the least expensive/ life threatening option. Just sharing personal experience of what worked for me
    hound dogger and ShOqUePoT like this.
  13. rtwdoug
    Dec 7, 2004
    5,511
    I already have acetone, but if that doesn't cut it I will try mek.
    I havent used it before to remove Kreme.
    Bad thing with these tanks is the steel baffles inside, so its hard to get all the krap out
    AZbiker, Oilleaker, JagLite and 2 others like this.
  14. Oilleaker
    Nov 20, 2019
    302
    Bronx NY
    If you can get some lengths of chain in and shake it, they’ll help and are easier to get out than nuts and bolts. I had the “genius” idea of using cut up chain saw blades, which was very effective but took some creativity to remove once they got tangled up inside the tank.
    Also it may flash rust almost immediately after pouring off the mek, so keep a bit of motor oil handy to shake around and coat the bare steel til its ready for gas
    JagLite likes this.
  15. rtwdoug
    Dec 7, 2004
    5,511
    Polly has been working on restoring the broken indian clock sign from Colorado. Just have to figure a way to replace the few missing bits, but its looking much better
    Cogswell, Cloud-9, zookster and 21 others like this.
  16. Center-stand
    Center-stand Long timer
    Nov 7, 2008
    1,951
    Well I learned two things about Polly. She has an eye for detail, and she is patient.
    Maybe you'll run across a busted up sign with enough good edge to cut out some pieces and glue them in.
  17. rtwdoug
    Dec 7, 2004
    5,511
    Terry got this last week, and I put 100 miles on it today in the mountain roads of N Arkansas.
    I shouldn't have done that.
    I may have to go get one. Ive never had a new motorsickle before.
  18. vee2win
    vee2win oldnwiser
    Dec 24, 2006
    687
    Nor-Cal, USA
    New bikes spoil. Old bikes toil.
    JagLite and panhead_dan like this.
  19. 2WhldZEN
    2WhldZEN If it don't go-chrome it! Supporter
    Jul 17, 2006
    131
    Central PA, USofA
    Go ride an FTR...you’ll either forget about the Triumph or need to make room for two modern bikes.
  20. rtwdoug
    Dec 7, 2004
    5,511
    I was hot n heavy for an ftr until I sat on one. The scrambler fits me damn near perfect.
    gulfcoaster, JagLite and villageidiot like this.
