DisTech's 2021.5 FSE450R
Discussion in 'Thumpers' started by DisTech, Mar 6, 2021.
  1. DisTech
    DisTech Been here awhile Supporter
    Sep 3, 2008
    695
    Seattle
    Yup, I got one.
    It's a good thing the crate frame was metal!
    I like the look of it. Teardown for grease check and loctite.
    Huh, one plastic lug not working for ECU mount.
    Don't like the white plastic frame guards. Ha! but that void under there is even uglier!
  2. Navin
    Navin Long timer
    Sep 22, 2009
    29,517
    Polisport can fix that.
    Be sure to torque yah spokes!
    loganlexow and Bitingdog like this.
  3. DisTech
    Sep 3, 2008
    695
    Seattle
    Ha! Already ordered same black guards!
    Checked the spokes. Some almost loose, but overall not too bad.
    Speedo sensor mount as shown is a couple inches from magnet. Does it matter? Does it work?
    I can rotate the mount to bring the sensor closer but then the cable is pointing down, not good.
    Sensor bracket does not fit between fork tube and caliper on top caliper bolt.
  4. DisTech
    Sep 3, 2008
    695
    Seattle
    ***EDIT*** This modified mount did not work, see this post for the revision.
    Modified the sensor bracket.
    Sensor is half inch from magnet and cable is not hanging down as far.
    Installed battery, dielectric greased and routed wiring.
  5. DisTech
    Sep 3, 2008
    695
    Seattle
    All those connectors and wires have to route under the top tube. I sacrificed many zip ties in failed attempts.
    Came out ok. The big black 12 wire connector is the dual sport lighting and it wouldn't lock together. Had to cut a sliver off the barb to get it to click.
    Figured out the rest of the dual sport wiring, headlight, horn and blinkers. Not used to the wire color of loom continuing past last connector all the way to the blinkers, made blinker testing super easy.
  6. DisTech
    Sep 3, 2008
    695
    Seattle
    Tonights progress consists of wrestling with an AXP skidplate and a heat gun. I like it and think I can make it work but it is by no means plug and play. Oh and a UNI filter, that was plug an play.
    loganlexow, Navin and JDUBinCO like this.
  7. DisTech
    Sep 3, 2008
    695
    Seattle
    Wondering if the baffle retaining bolt can fall down inside the muffler endcap while trying to install it?
    Yes, yes it can.
    Navin likes this.
  8. Navin
    Navin Long timer
    Sep 22, 2009
    29,517
    Good idea to aerate the packing pre-ride anyway.... :doh
    #8
    DisTech likes this.
  9. DisTech
    Sep 3, 2008
    695
    Seattle
    Polisport headlight with blinkers mounted, need to add the horn. It looks ok but the quality is bare minimum, I got what I paid for. Once it's plated, I'll probably go full Highway Dirt Bikes.
    #9
    Navin likes this.
  10. Navin
    Navin Long timer
    Sep 22, 2009
    29,517
    Light, lite and legal. Nuff said.
    #10
    yeroc40 and DisTech like this.
  11. DisTech
    Sep 3, 2008
    695
    Seattle
    Went with the Tusk taillight because it has integrated license plate light, but kept the GPX blinkers.
    Replaced the bullet connectors.
    #11
  12. lakai2380
    lakai2380 Adventurer
    Sep 9, 2014
    26
    Palmer, MA
    Hi i am in the same boat trying to find a skid plate that will fit my 450. what AXP model are you starting with. I have been looking at the MOLECULE ones for a 16-21 sx-f450 thinking that they might be close to start with and bend and cut what i need to. cant wait to see your final product and how it fits.
    #12
  13. DisTech
    Sep 3, 2008
    695
    Seattle
    That Molecule plate looks nice! I wish I'd seen it. You might have an easier time mounting it than the AXP. This is what I ordered "AXP RACING XTREM HDPE SKID PLATE, Part# 1893200014, Mfg Part# AX1501" from Rocky Mountain ATV. I matched it to 2021 450 XC-F, but it also works for 2020 450 SX-F (according to the site).***Edit***the AXP plate could be made to work, but I got a Molecule. No cutting (just drill two holes) and all hardware included. See this post for details.
    #13
  14. DisTech
    Sep 3, 2008
    695
    Seattle
    First start!
    #14
  15. DisTech
    Sep 3, 2008
    695
    Seattle
    Bill of Sale, check!
    MSO, check!
    Orange and red reflectors scotch taped on in order to pass inspection, check!
    Safety inspection, check!
    Time to head to licensing to get title, registration and plate!
    #15
    GlennR likes this.
  16. DisTech
    Sep 3, 2008
    695
    Seattle
    Plated!
    Aside from tax being a bitch, the process wasn't to bad.
    #16
  17. TwoTrackMind
    TwoTrackMind Strange Magic
    Aug 15, 2008
    453
    Grand Haven
    Looks great DisTech. How does the power compare to your DR440?
    #17
  18. DisTech
    Sep 3, 2008
    695
    Seattle
    Don't know yet. The bikes are techno era's apart, should be fun to compare!
    #18
  19. afordableperformance
    afordableperformance Been here awhile
    Jul 22, 2010
    803
    You might want to put a license plate frame on your tag those edges are sharp and can cut, I've seen it many times. Looks good though!
    #19
    DisTech likes this.
  20. DisTech
    Sep 3, 2008
    695
    Seattle
    Got a TrueNorthMotos XABR RACK for KTM. Rugged, light, pretty nice! What does it take to fit it to the GPX?
    On KTM's the subframe has holes on top to allow through bolting for the end bolt inserts.
    Gotta add a couple holes.
    After that the left side
    and back end bolt right up.
    The right side on the GPX is different. The XABR strut is a little less than 1/2 inch too short. Think it's because the GPX subframe jacks the tail up a little more than then the KTM.
    Also the the GPX rear brake master cylinder sticks out farther and will not allow the XABR flange to sit flat against the frame. So I am adding a plate to serve as a spacer.
    Spacer plate and XABR flange in place, just gotta tack the strut then re-weld it. The rear brake pivot bolt will have to be replaced***edit*** bolt from TrueNorth is fine, hole through frame was not round, cleaned it up and it worked.
    More to come.
    #20
    Ginger Beard, Navin and massholejim like this.
