DisTech's DR650 rebuild
Discussion in 'Thumpers' started by DisTech, Dec 13, 2008.
  1. Mezo
    Mezo Banned
    Nov 17, 2008
    2,129
    Brisbane,Australia.
    I was reading another forum on a guy with water in his DR electrics, another member had posted a link to a thread about Dielectric Grease,
    he swore using it on all his bikes "first thing he does with all his new bikes" another DR rider.
    Worth it whilst the bikes at this stage of the build :getiton
    Great thread. :clap
    Looking forward to fire up day. :lurk
  2. plugeye
    plugeye MC rescue
    May 11, 2007
    6,987
    Garland, Texas USA
    some of them are for foreign models lighting
  3. YnotJP?
    YnotJP? Long timer
    Dec 26, 2007
    5,616
    Philippines and Seattle
    I have looked, but am unable to find what the fork angle is on a DR650. Can anyone help me out?
  4. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    17,312
    Tri- Cities TN
  5. YnotJP?
    YnotJP? Long timer
    Dec 26, 2007
    5,616
    Thank you, yous a gooder finder than me.
  6. DisTech
    DisTech Been here awhile Supporter
    Sep 3, 2008
    658
    Seattle
    Thanks, I guess I'll find out soon enough if there is a problem with the forks.
    Interesting tip and the time would be now, I'll check it out.
    Thanks, I should have thought of that. There is even a wiring diagram in the manual listed as "For the others". All but one are identified.
  7. Rusty Rocket
    Dec 22, 2005
    17,312
    Tri- Cities TN
    Throttle switch bad! Passing light cool!
    How did you do that changing diagram trick. I have all I can do to post a picture.
  8. itsforrest
    itsforrest Ugly bag of mostly water
    May 23, 2008
    380
    Jamestown, NC
    I always grease up connectors with dielectric grease when I have anything apart. It keeps the moisture out and keeps them from corroding together, too.
    I also use it on bulb bases which can get dirty and corroded. My theory is that it not only keeps corrosion out but dampens a bit of vibration in bulbs, too.
    I've noticed many new cars come with greased up bulb bases and connectors too. If the factories see some merit there, it can't be a bad thing.
  9. Fubars
    Fubars What would Scoobydo?
    Aug 20, 2003
    2,249
    Ventuna, CommieFornia
    Yeah, what he says.....
  10. Mezo
    Mezo Banned
    Nov 17, 2008
    2,129
    Brisbane,Australia.
    Its a moving gif, right click the image & go to properties & it says its an 8 frame animated gif. :D
  11. JStory
    JStory Long timer Supporter
    Dec 21, 2004
    4,576
    Dixon, CA
    Excellent thread, DisTech. You've got me wanting to sell my XL600 and grab a DR.
  12. GODSPEED
    GODSPEED finger lickin' good
    May 29, 2003
    2,082
    Port Angeles
    Mezo and all, this is a great tip that I employ. Clean them out with a little contact cleaner and a little air, then apply the grease. Works like a charm.
  13. DisTech
    Sep 3, 2008
    658
    Seattle
    Yea it its interesting the same(?) harness has different options.
    I used Photoshop to scale and align the the images then used ImageReady to fade the euro wiring diagram in and out. Then saved it as a .gif. Once it's a .gif it's the same to post as any other picture. I also tried saving as a .swf, but it appears advrider.com doesn't support flash yet.
    Thanks, why not both!
  14. DisTech
    Sep 3, 2008
    658
    Seattle
    Mezo, itsforrest and GODSPEED thanks for the tip. I searched around and read about what a good idea Dielectric Grease is and went and bought some.
    I greased up all the connectors and pretty much have all the stock wiring back together (except for lights). You can see my new 10ga wiring that will be going to my alternate fuse panel in the cockpit.
  15. DisTech
    Sep 3, 2008
    658
    Seattle
    Exhaust guards reinstalled. Straighten the brake lever and remounted. New IMS foot peg.
    Straighten the shifter and remounted. New IMS foot peg.
  16. DisTech
    Sep 3, 2008
    658
    Seattle
    What a PITA!
    Am I going to have to shave the rib at the end off for regular grips?
  17. neepuk
    neepuk Such a drag...
    Jun 9, 2005
    1,677
    Redstone, CO
    Belt Sander...:D
  18. AWM
    AWM Beard Bros Racing
    Mar 21, 2007
    11,415
    Your Mom's house
    I used a die grinder with a wire wheel.:wink: Just don't push down to hard.
  19. bitterjoe
    bitterjoe killing the fatted calf
    Jan 23, 2006
    2,054
    New Hampshire
    :lurk good stuff.
  20. Fubars
    Aug 20, 2003
    2,249
    Yeah, it sucks alright. Buy a new one from Motion Pro.
    joenuclear likes this.
