DIY “Rally” fairings
Discussion in 'Parallel World (790/890)' started by dewey405, Apr 27, 2021.
  1. dewey405
    dewey405 Been here awhile Supporter
    Feb 4, 2010
    567
    OKC, OK, USA
    So I recently made some fairings for my 790 since I’ve always hated the praying mantis look through KTM has adopted, )should’ve never went away from the stacked look). I posted some pictures and some people have asked what I did so I figured I’d post some pics, it’s super simple and it has made the ride so much quieter and with some other DIY, in 25+ MPH gusting winds I had almost zero head buffeting. I used 2 .0125 12x24” kydex v sheets I found on Amazon but you can source them however you want and I’d recommend 3 so if you make a mistake you have a spare.
    The first thing I did was make a cardboard template, this is made with the Rade garage screen in mind so YMMV. I also plastidipped the inside of the RG screen so it matches the black kydex better. I poked the 3 screws per side through and screwed it in, and designed it so there was a “wing” that would fold under for some wind deflection. So enough talking, it’s picture time.
    How it looks all put together, notice the theme.
    DA8623F6-D7D1-4A43-A6DB-C718712548D7.jpeg DDF16E2E-F3CA-47A9-9898-7F803C28522F.jpeg
    The template, mind you this is designed for my aux light bracket. The big curve on the bottom doesn’t “need” to be there.
    Shaped by a heat gun, I screwed the top screw in then used a heat gun to slowly shape in as I worked down. Too much heat and it will show melting spots (ask me how I know). Also I don’t like this blinker, it’s useless.
    I used industrial Velcro to mount this part to the tank. I also used the heat gun to shape the curve here, it kind of makes it’s own curve I just used the heat gun to allow it reshape so it’s not under constant stress.
    FCDD636A-610F-400D-8A86-D084BA5383D3.jpeg CE92709E-187E-45C2-B560-9F1733BCAF2B.jpeg
    the wings under screw into the holes that the awful lower wing used.
    Also, for buffeting I was using the Amazon spoiler but the clamps caused some stress damage to the top so I made some basic clamps using angle aluminum. I used fender washers on the inside to again, reduce stress.
    43B7AE5E-55E2-4EFE-A498-B853B590D643.jpeg 2EC23E30-5BBC-4E43-B353-FFBB019D9C70.jpeg
    kirill_k, lithodave, SFC_Ren and 4 others like this.
  2. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    13,973
    s.e. mass
    If you’re happy, I’m happy.
    sims159914, dewey405 and Fathead890R like this.
  3. grace
    grace Long timer Supporter
    Aug 22, 2006
    1,802
    denver co usa
    curiouser and curiouser...
  4. dewey405
    Feb 4, 2010
    567
    OKC, OK, USA
    Meh I was asked to share the info so I did, take it or leave it.
    lithodave and Fathead890R like this.
  5. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    7,204
    Planet Fucking Earth
    Some guys bolts stuff on, while other fabricate their own thing. Good for you for being the latter, and good on you for taking the time to share.
  6. braaap!
    braaap! Long timer
    Mar 16, 2005
    5,662
    Melbourne - AU
    Hey @dewey405
    Well done, I reckon you’ve done a great ‘low tech’ job in fabricating the custom side fairing panels!
    Any pics from the rider’s view. Cheers, :thumb
  7. roookie1
    roookie1 Been here awhile
    Jun 15, 2009
    845
    Denmark
    Clean and simple. Keeps the bike looking slim. I like it...
  8. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,886
    Fruita, center of the Dirt Bike Universe.
    I didn't care for the buffeting I experienced from the Rade Garage windscreen at first, but removing the stock wind deflectors fixed everything, as far as I'm concerned, and cruising at 80-90 mph is a pleasant experience now.
    #8
  9. Matrace
    Matrace Been here awhile
    Jun 17, 2020
    215
    Marseille France
    Your great job confirms my trails , two side wings reduce consistently the buffeting coming from the narrow prow of this “praying mantis”, (logical posture for a fight against the air...);
    I’ve just added two cheapo uppers deflectors on the OEM side winds, by this way it’s easy to find the right place, upper or lower , spread or slightly bend ,
    At now the best position looks like this, 0D7893CC-C583-4A4E-83CA-0F261041A5D0.jpeg 7A01AAB9-9FB8-4F17-8830-EA9793BA9E15.jpeg
    #9
  10. comradecasey
    comradecasey Long timer
    Jun 5, 2018
    1,069
    Oregon / Tennessee
    I think you may need a fifth windshield dude.
    #10
  11. c-m
    c-m Long timer
    Apr 14, 2008
    1,923
    Spain
    Matrace is on the right track. For aero you tend to want a bulbous front and a skinny behind. Think of the water droplet/tear drop, it's one of the most aerodynamic streamlined shapes for sub sonic travel with about 5% resistance.
    If your bike travels at super sonic speeds you need a long thin design like a missile.
    #11
  12. theDoktor
    theDoktor Husky Racer
    Feb 2, 2011
    1,035
    Buffalo, NY area
    @AdvRonski, the Rade Garage windscreen is at the top of my list for consideration, but some have complained that it has too much wind noise. These complaints give me pause, although hearing from others who made it work for them helps offset my concerns. Your solution is both easy & reversible, which is a big plus, IMHO. Have you made any other mods, like mirrors, handguards, seating position, etc. to address wind & or ergonomic issues?
    Just out of curiosity, what are your height & inseam dimensions?
    #12
  13. kzeb
    kzeb Been here quite some time
    Oct 22, 2006
    475
    Scandinavia
    @Dan D.
    You stay out of this !
    :lol3
    #13
    theDoktor and Dan D. like this.
  14. AdvRonski
    Feb 4, 2007
    1,886
    I'm 5-11, 33 inseam. I have a rally seat, MX bars, Cycra handguards, and run a single folding mirror. But, those are all ergonomic mods, and never really had any impact on my buffeting issues. It was the removal of the air deflectors that made the most difference for me, and I have heard similar reports from others. There doesn't seem to be any universal remedy, though, since it is really a personal preference issue.
    #14
  15. dewey405
    Feb 4, 2010
    567
    OKC, OK, USA
    I am 6’1” with a 34” inseam, in addition to the following I went with the Highway dirt bike handguards with mirrors (helped a little with buffeting), Flexx ADV bars and a seat comfort tall comfort seat for ergo.
    I went with the RG screen for the looks and the severe neck pain the OEM gave me in OK winds. It did nothing except give me space for the tablet mount. I then added the spoiler on the top of the RG screen and it helped a lot but it was still loud and I’d get weird harmonics with the helmet that would cause headaches fairly often, standing helped alleviate it this when I felt it coming on. I then removed the lower wind deflector and it made the long highway rides in OK much more tolerable but it was still loud in the seat and I’d get head shake more often than not.
    With all that being said, this alleviated ALL of that on the one ride I was able to go on before I took a sharp rock to my front sidewall and trashed the tire. At interstate speeds I was able to lower my headset music volume, and country highway speeds I could understand everyone in comms for the first time. The wind issues were almost gone (obviously cross winds still have issues). I still have the upper spoiler I bought but I hard mounted them instead of the crappy clamps so I can’t say if they still make a big difference.
    Hope this helps.
    #15
  16. theDoktor
    Feb 2, 2011
    1,035
    Buffalo, NY area
    Thanks. I'm 5'-11 with a 32" inseam, so our ergos should be pretty close. I probably will end up with the Husky Evo bars or something similar- I hate a lot of sweep.
    #16
