    Dismiss Notice
DIY & Inexpensive Tiger Mods and Farkles
Discussion in 'Triumph Tigers' started by skylerhager1, Sep 20, 2016.
  1. Black Rhino
    Black Rhino Closer to Dairy Queen than Steve McQueen.
    Dec 7, 2012
    5,720
    West of Atlanta , Ga.
    It does sound a little vague. The bank of injectors is on the back side of the head and that stepper motor and its components are tucked in between 2 & 3. It helps to have a longer straw on whatever spray you are using. You are sort of "flying blind" spraying it in there , because you can in no way see the area you are trying to hit. But I took my tank off the first time and made a mental note of what I would need to hit in event it was needed. I've helped 2 other riders just knowing the area , and spraying what looks like randomly in the area. That make any more sense? You will/would be spraying in an upward direction , but more like you're trying to hit the the back of the head and slightly toward the tank than directly at the bottom of the tank.
    #61
  2. Boats313
    Boats313 Adventurer
    Sep 11, 2012
    48
    Severna Park, MD
    You inspired me to give it a try. Mine's a 2015 XCX with the stock non-adjustable screen. I rummaged through my shed and found some 1" spacers, a few random bolts and screws, and cut the plastic out of the plastic storage container for some wall anchors. Went together surprisingly fast and without any of my usual first try issues.
    After a test ride, I stopped by the hardware store and picked up the right screws and a stainless bracket to make a permanent mod. The holes in the side bracket are an inch apart and I found a bracket with the holes already drilled and countersunk in the right spots, I just had to cut them to length and round the corners. I wrapped the spacers in electrical tape to hide the white. The whole thing cost me about $8 (counting what I used from my supplies). As a bonus, it is now adjustable. At highway speeds, it's best with the bracket level to the ground, about the middle setting. For back roads I pushed it all the way down. I can adjust it without tools and while riding, if it loosens up, I'll swap out the nuts with knobs.
    I did notice some headlight glare on the windscreen, so I tucked electrical tape along the top of the headlight ( just the horizontal strip) and it seemed to take care of it. I won't know for sure until the next night ride.
    It's about an 80-90% solution for 8 bucks and about an hour of time, not counting test rides.
    #62
    Graybush likes this.
  3. Leo90au
    Leo90au Adventurer
    May 5, 2016
    64
    Australia
    Yea it makes sense mate, thanks. You say you installed a 675 stepper? I found one on ebay that's quite cheap, is it a simple install?
    Sent from my SM-G935F using Tapatalk
    #63
  4. Black Rhino
    Dec 7, 2012
    5,720
    Yes , I did. Frankly , it's was not easy to install , but it is simple. It is essentially just a spring loaded screw. There is some stuff that needs to be removed , and the easiest way to do it would have been to pull the fuel injection bank out and install it , then replace everything as it was. I tried (successfully) to do it leaving everything in place. If I had it to do over , I'd pull the FI. Works fine , only a little "cold" idling on cold mornings , which I just give it a quick rev and it settles in fine. You can see the adjuster in this pic right behind the oil fill plug.
    #64
    dinkydonuts likes this.
  5. alpina
    alpina God looks after drunks and fools. Supporter
    Sep 24, 2007
    479
    Denver
    #65
    travisn000 and XRman like this.
  6. jml141
    jml141 Been here awhile Supporter
    Jan 26, 2016
    329
    Leland, MS
    I fabbed a GPS mount for my Garmin 590 out of a piece of sheet aluminum. I bolted the I used a plasma cutter, but a hacksaw and a hand drill would work. You need a vice to clamp it in to make the bends for strength. You could also use a hammer and a sturdy corner of a work bench or counter. I've since added a Madstad so I mounted it to the support frame, and I don't need this one. I'm putting it in the Flea Market.
    [​IMG] [​IMG]
    #66
  7. jml141
    Jan 26, 2016
    329
    Leland, MS
    I did my best to draw a template.
    #67
  8. Emmett
    Emmett Been here awhile Supporter
    Mar 9, 2017
    475
    New Orleans
    Headlight Cowl to counter Madstad reflection. [​IMG][​IMG][​IMG]
    Made from left over roof flashing. Very thin and malleable material. Simply cut it with tin snips. Cut out two tabs and bend them down and make holes in the tabs and mount them on the headlight screws. Best to spray them black with any outdoor spray.
    Total cost to me $0. The flashing came from a friend, so did the paint.
    Sent from my iPhone using Tapatalk Pro
    #68
    Siorc likes this.
  9. Emmett
    Mar 9, 2017
    475
    New Orleans
    Note on the above; the unpainted cowl above was my first cowl. I decided to make another cowl and not cut away the excess material between the two tabs so that the cowl would cover light coming from further back, I also decided to make the cowl wider so that it would extend further in front of the headlight shield. The cowl you see mounted on Tiger is the second cowl.
    #69
  10. ride4321
    ride4321 Long timer
    Dec 21, 2009
    4,793
    Binghamton, NY
    My remedy for the screen glare was to paint the bottom of my wind screen black. Bottom edge and about 4 inches up on the back side of the screen.
    #70
  11. Piston Slap
    Piston Slap Been here awhile
    Aug 7, 2017
    142
    Idhao
    I did the UNI pre filter. I plan on doing a lot of off road trips with this bike so I want to protect it from the dust and dirt! Heres a video of the install I put together
    #71
    Azturbomini, S4Wrangler and sans4ver like this.
  12. ewaugh
    ewaugh Adventurer
    Sep 24, 2012
    48
    I love my LED bulbs. I work on a military installation and the gate guards do not love my LED bulbs. If they don't accuse me of running my brights they at least give me mean looks. It's a price I am willing to pay though.
    #72
  13. Quinn Otte
    Quinn Otte Wrenching > Riding
    Aug 31, 2015
    318
    Huntsville, AL
    Good thread. I've done a few little DIYs. If anyone has any questions about any of them, PM me.
    Micro-USB hardline and low-invasiveness phone mount.
    I gutted the powerlet port but retained the spring-loaded door. Soldered in a 12V to 5V regulator and a micro-USB cable.
    For the mount, I hacked up a cheap phone holder and epoxied the other side to the back of my phone's lifeproof case. Very fast to slip the phone in, very clean and non-cluttered cockpit.
    Had to replace the powerlet, though, so I could still used heated gear. Used the place under the seat. Pigtail for trickle charger too.
    Used a dremel and sandpaper, and cut out all the tabs from under the passenger seat. I can now comfortably fit both spare tubes under there.
    Tool tube. I had access to free carbon fiber, but PVC is fine. Re-useable zip ties make it look not so clunky, but still be detachable.
    A little eyeliner... just used black acrylic paint on the edges of the windscreen and headlight guard. Works like a charm, totally unnoticeable, unlike some other fixes I've seen.
    This one was free to me, but I understand not everyone has access to a 3D printer or free carbon fiber. But if you're smart, you can source some cheap materials that will work.
    Made a little shock cover to prevent crap from the rear wheel getting flung in there.
    Finally, I spent way too much on this dumb thing. I should have just hacked up the factory one. But I wanted to be able to see my countershaft sprocket after I got in there for something else and noticed how horribly worn it was. I may have never had noticed if not for dumb luck... but yea. Cut down the factory sprocket guard.
    #73
  14. n2deep1901
    n2deep1901 Been here awhile
    Dec 7, 2010
    419
    Hebron, ky
    Saw the cyclops leds somebody have a link to some leds that are good that don't cost over $100?
    #74
  15. ridin gaijin
    ridin gaijin riding > posting Supporter
    Nov 30, 2004
    1,064
    NM, AZ, but now, DC >.<
    I bought these $11 LEDs off AMZN to see if they'd work on my Barkbusters as auxiliary turn signals + running lights, to replace the crappy Storm LED set. But in the sunshine the LEDs weren't bright enough for me. I'm going to mount some Skene Photon Blasters up there instead.
    Meanwhile, the $11 strips got stuck to the front end. Positives are Posi-Tapped into the horn positive, and the negatives are wired to a lead that's screwed into one of the frame bolts.
    Not exactly awe-inspiring but hey, it was just $11 + 20 minutes.
    #75
  16. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    15,325
    Out in the NM Dez somewhere
    I recently tried to buy a front fender lift kit but couldn't find on that was available so I decided to made up a kit. My time to make these was worth more then what they cost but you know how that goes sometimes, I got a Rivnut tool awhile back and this seemed like a good project to try it out on.
    I kept it small at 15mm.
    #76
  17. Black Rhino
    Dec 7, 2012
    5,720
    15mm is likely all you will ever need. I've had mine on for 3 years , and run it regularly through difficult environments (mud , rock , etc...) , and it is still holding up.:thumb
    #77
  18. XRman
    XRman Long timer
    Dec 9, 2006
    8,174
    SW Victoria Oz
    20 mm works but eventually either the riser will break or the fender. Lifecubed.com makes ABS fender risers. They will break if hit hard enough with rocks caught inthe side wall knobs. The riser is cheaper than a new fender. If you can fabricate your own metal risers make sure the surface area is greater and use two bolts to attach to the fender,otherwise the Oem fender breaks at the attachment point.
    #78
  19. RideFreak
    Apr 17, 2009
    15,325
    Looks like Lifecubed is no longer, I just get a GoDaddy signup page when I search it. I bolted the fender on in 8 places instead of the normal 6, very solid. Too much at stake to risk a failure which can be catastrophic.
    Jump to 40 seconds in.
    #79
  20. K1200LT
    K1200LT Been here awhile
    Nov 12, 2006
    196
    Olympia, WA
    Still there - you left off the.au http://lifecubed.com.au/bikebits/
    Steve
    #80
