[DIY] LED Headlight Setup
Discussion in 'Hard. Core. (1090/1190/1290)' started by Cyberon, Apr 12, 2020.
  1. Cyberon
    Cyberon Been here awhile
    Dec 30, 2019
    221
    Portugal
    After reading a couple of threads here on the forum I believe some users have already cracked this "LED Headlight Setup" on there KTM's.
    I propose that you "smart guys" help us "newbies" setting up this really important upgrade.
    Please add as much info as possible, motorcycle, bulbs, resistors, etc.
    All good/tested solutions will be posted here, giving the deserved credits.
    Edit: Some info for those that don't want to read all the thread.
    Both me and @Bart20170 have this combo working flawlessly on a KTM 1090 and a KTM 1290T:
    LED Bulbs:https://a.aliexpress.com/_dSP33MC
    1 watt 2.2 kohm resistors: https//a.aliexpress.com/_dYjea8o
  2. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    7,808
    West of the West, Oregon
    I like to keep the stock headlight(s) alone and just add LED lights as needed. I put a single wide angle 6 led on my dirt bikes. I've installed a 10" LED bar below the head light on a 1190R. It had about narrow 8 leds and about 12 wide angle.
    These lights are about the only reason to have an upper crash bar.
    Cyberon likes this.
  3. Cyberon
    Dec 30, 2019
    221
    Portugal
    Auxiliary lights are a great upgrade, the problem is that they are not legal in a lot of county's, including mine.
  4. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    12,902
    Southern Louisiana or Southern England or ...
    I bought some fanless LED lamps and modified them to work with the KTM's lamp checker function. I opened the LED control box and cut out some small capacitors from the power supply. Also added a 1K-ohmm resistor across the power plug for the LED's. What I ended up with was a much brighter headlamp with a reliable, fanless, cooing system (unlike the expensive kit) and no bulky, hot ballast resistors. This was almost three years and 30,000 miles ago. All still working fine.
  5. Cyberon
    Dec 30, 2019
    221
    Portugal
    The skill level in this is awesome, congrats!
  6. Bart20170
    Bart20170 Been here awhile
    Feb 4, 2017
    214
    Aliexpress nighteye, cheap and great output. Just 2 small resistors needed. 20200413_112935.jpg
    kokos79 and Cyberon like this.
  7. Cyberon
    Dec 30, 2019
    221
    Portugal
    Awesome, have you installed them yet?
  8. Bart20170
    Feb 4, 2017
    214
    Yes, almost 2 years now and no issues.
    #8
    Cyberon and kokos79 like this.
  9. kokos79
    kokos79 Nomad
    Apr 13, 2009
    1,620
    Greece
    Same here, along with a couple of CANBUS resistors, all from ebay. Total for two LED H11 and two CANBUS resistors with H11 connectors, around 30€. Been working great since 2017 on my 1090R.
    #9
    Cyberon likes this.
  10. Cyberon
    Dec 30, 2019
    221
    Portugal
    Can you guys please elaborate on the assembly?
    Photos and schemes would be great to add to the OP.
    Maybe we can get this post "sticky" to help others.
    #10
  11. Bart20170
    Feb 4, 2017
    214
    I own 2016 sat, I just put the 2k2 resistors parallel over the led
    #11
    Cyberon likes this.
  12. Cyberon
    Dec 30, 2019
    221
    Portugal
    #12
  13. kokos79
    kokos79 Nomad
    Apr 13, 2009
    1,620
    Greece
  14. Cyberon
    Dec 30, 2019
    221
    Portugal
    I have read some of them, lots of amazing info, but the objective of this thread is to create a non technical discussion with only a couple of working combos so anyone can replicate them on their bikes.
    We "newbies" could really use your help on that! :)
    #14
  15. slartidbartfast
    Dec 23, 2003
    12,902
    The only way to tell for sure is to try them. Not much to lose at that price. I'm a little skeptical that the cooling will be enough but no great loss if they eventually fail.
    I tried a super-cheap lamp with much less finning than that in my Triumph Tiger. It got really hot and eventually cooked itself but was a great "proof of concept" for some rewiring I was tinkering with. I replaced the failed LED with one using the flexible straps for cooling (like my 1290) and they've survived about 5K miles so far, including traffic-jamming in 110F (ugh!)
    #15
    Cyberon likes this.
  16. Cyberon
    Dec 30, 2019
    221
    Portugal
    Awesome, can you send a link of the ones you bought and the resistors you used?
    #16
  17. slartidbartfast
    Dec 23, 2003
    12,902
    It was three years ago so I doubt the exact same lamps are still available. I used standard 1Kohm resistors (probably 1 Watt rated or something like that.)
    If you just search for fanless LED's (H11 if I remember correctly) and keep scrolling down, you'll eventually find some with the flexible strap cooling. I just came across some for about $20.
    #17
    Cyberon likes this.
  18. Bart20170
    Feb 4, 2017
    214
    #18
  19. Cyberon
    Dec 30, 2019
    221
    Portugal
    Are these the ones your using?
    #Aliexpress € 19,17 54%de desconto | Nighteye led h4 h7 h8 h9 h11 8000lm 50 w 6500 k carro faróis led branco nevoeiro lâmpadas 9005 hb3 9006 hb4 luz de nevoeiro lâmpadas
    Which version should I order?
    #19
  20. Bart20170
    Feb 4, 2017
    214
    Yes, which model of ktm do you own?
    #20
