DIY Make a Lexan Headlight guard/bracket step by step Walk thru
Discussion in 'Equipment' started by klm4755, Sep 23, 2008.
  1. klm4755
    klm4755 Been here awhile
    Jun 19, 2006
    577
    Enclosed is a step by step walk thru to make a Headlight guard for the KLR650. The intent of the guard is to protect the bikes headlight from impact damage. The guard should not impede or degrade the brightness cast from the stock headlight system.
    First thing is to develop a concept. I ended up with 3x designs before I converged to the final product. Since I did not desire to use mess with my bikes cowling/headlight, I make a mock-up of the front bracket, cowling, and turn signal assembly.
    front end components on DIY mount.
    This mock-up allowed quick, easy access, and efficient design changes. All parts from e-bay
    Some al sheet stock and Clear Lexan. I ended up trying various gages of sheet Aluminum (.050", .063" and .10") and a 2x Lexon gages (.118" and .215”).
    Bending brake to form the Al angles.
    need to be carful as to not exceed the cold formed MBR (minimum Bend Radii). This chart shows the min inner radii allowable for brake bend. The concern is a too sharp radii will cause outer radii failure
    failure like this
    Radii gages
    eyeball checking the inner radii, need a smaller gage, I’ll mount the bracket where the mirrors attach
    need to also make 2x align holes to accept the small tabs
    depth of tab = .114" from depth gage
    get out design templates
    use this template to make parallel lines
    outline taking shape
    off to band saw
    rough sander
    break edge with de-burr tool
    check faring turn signal mounting hole size with adjustable ball gage
    check ball gage diameter with micrometer
    mark and drill
    check fit...A-ok
    quick fit on bike
    sketch trim line
    trim and sand
    since opposite is mirror image, a single master template can be used on both sides
    drill lightning hole, to take out some weight
    place in brake, clamp down
    make 90 degree bend
    check MBR
    use this type of step drill for thin materials
    quick mount
    Lexan gage .118 inch
    trim line
    de-burr tool
    goto fastener bin to select correct Stainless steel fastener
    fastener tools and hardware
    KLR fastener tip sheet
    align Lexan holes
    as installed
    on mock-up
    side view
    cleaner for marks
    as installed on Bike
    headlight on
    gap needed to clean head light
    Review:
    1. Bracket kinda shield light from side
    2. Lexan too thin, needs to be thicker
    3. Al bracket at .063" ok
    Final iteration now shown:
    master template design
    The master templates
    as mounted on Mock-up
    another view
    revised gage...perfect
    as installed
    closer view
    headlight on...better visibility
    front view
    outside view
    side view
    room to clean
    ready to ride!
    Review:
    1. Works as described.
    2. Thicker Lexan functions better.
    3. Semi easy mod...once template is developed
    4. Easy install.
    5. Robust design
    Keithm
  2. NJ Moto
    NJ Moto Glory Bound
    Aug 27, 2005
    10,294
    Bergen County, NJ
    Bravo!:clap
    You could have a decent side job with that...
  3. klm4755
    Jun 19, 2006
    577
    Thanks. Only took ~4 hours to design and ~1 hour to fabracate the assembly. sanding Lexan and Al makes a mess in the garage though.
    Keithm
  4. bkowal
    bkowal Been here awhile
    May 5, 2003
    284
    Oakville, Ontario, Canada
    Why didn't you just glue a piece of lexan to headlight with a bead of clear silicon around the top?
    Or just use small metal clips that screw into the fairing to hold the lexan?
    Or just some pretty stainless steel screws at the corner of the Lexan that goes right through the fairing?
    Also there is a 3M product that you stick on the front light. Basically a thick plastic film. I have used it and it works very well.
    What is to stop all that stuff from rattling around the turn signal mounts where it will pivot? If that bracketry moves at all, it will fall off in a few hundred miles after the aluminum cracks from fatigue.
    I just don't understand why you need all that bracketry.
  5. peterman
    peterman cop magnet
    Jan 2, 2006
    18,433
    Springfield,,,,like the Simpsons,,,orygun
    did you know that you could make the bends in the Lexan the same way you bent the aluminum? The whole thing could be one solid piece of Lexan. Looks good. I cut out a piece slightly larger than the headlight on an F650 GS, and curved it to fit using a heat gun. Then I secured it to the lens with 3M Dual lock "buttons" in 3 corners. Pops right off for cleaning.
  6. JimVonBaden
    Feb 11, 2005
    83,785
    Alexandria, VA
    I did the same thing for my R1200GS. Worked great!
    Jim :brow
  7. klm4755
    Jun 19, 2006
    577
    Thanks for the tip! I would have to find another mounting location.
    Keithm
  8. SLUGGO
    SLUGGO A Lone Drifter
    Feb 11, 2004
    219
    SF Bay Area, Taxnfeeafornia
    Nice piece of work! :clap
    #8
  9. Bollocks
    Bollocks Farts with an Accent™
    Oct 14, 2005
    7,054
    Watauga lake, 10-E-C
    Why? Cus he's got the skills.[​IMG]
    Nice job mate.:thumb
    #9
  10. BlackBeast
    BlackBeast Been here awhile
    Jul 7, 2006
    990
    Ontario, CANADA
    #10
  11. VStromTom
    VStromTom Long timer
    Aug 26, 2004
    1,579
    Part of having a bike is tinkering and coming up with stuff we like. If I had that kind of skill and the tools I would probably be making all sort of things for my bikes. In this case, Great Job. For my needs though excessive. But you did a great job.
    #11
  12. NJ Moto
    NJ Moto Glory Bound
    Aug 27, 2005
    10,294
    Bergen County, NJ
    What kind of auxiliary LED lights are those?:ear
    #12
  13. andmoon
    andmoon Long timer
    Oct 28, 2004
    3,219
    NJ exit 10
    Now could you make me some similar brackets that bolt to the stock R1100gs stock screen mount holes on the inside and a big ass Harley type shield on the outside (winter screen and headlight guard in one)?
    Put your skills to make luggage carriers and make some $.
    #13
  14. Jumile
    Jumile Adventurer
    Aug 26, 2008
    23
    Berkshire, UK
    Nice work. :thumbup
    My only thought would be the temperature of the headlight (I thought that's why steel grilles were more commonly used) - does the Lexan shield affect that at all?
    #14
  15. Mercury264
    Mercury264 Once you go Triple...
    Nov 7, 2005
    24,500
    Masshole
    He's more likely to get his bike dirty than answer :lol3
    #15
  16. g®eg
    g®eg Canadian living in exile
    Jul 13, 2004
    8,071
    48.8436788,-122.599317
    clean?
    looks like it's never been dirty.....
    :D
    #16
  17. Dirtgeek
    Dirtgeek Guest
    A+:freaky
    al:1drink
    #17
  18. klm4755
    Jun 19, 2006
    577
    You would not believe how many tough, rugged trials that bike and I have blazed...hehehe
    Keithm
    #18
  19. g®eg
    Jul 13, 2004
    8,071
    trials?
    :scratch
    #19
  20. Mercury264
    Nov 7, 2005
    24,500
    Masshole
    You're right. I wouldn't.
    #20
