1. ADVRIDER Print Magazine!
    We're doing two more print magazines year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
DIY Motorcycle Lift
Discussion in 'The Garage' started by Ricardo Kuhn, Jun 25, 2011.
  1. Ricardo Kuhn
    Ricardo Kuhn a.k.a. Mr Rico Suave
    Sep 20, 2001
    17,315
    Minneapolis (don't even ask how i end up here.
    Note: I was sure is a long posting about DIY tables but I was unable to find it.
    Ingredients
    *4x4 in lengths and also small scraps.
    *3/4 plywood or whatever you can find
    *wood screws & Glue
    *Some kind of "Shaft's" for the pivots.
    *Skillsaw, radial saw, table saw or whatever you can find and also a drill.
    This is a very simple design, Everything works on "Interference" so is no need for a "Locking mechanisms" of any kind in fact the more weight you put on the ramp the more wedged it becomes.
    Like a gentle Camel waiting to be loaded
    So far I just load the bike in this position and then place a jack under until I can deploy the "Back" legs since I don't really have space for a extra ramp (inside the garage) but a extra plank of wood can be use to bring the bike up on the flat table.
    Very simple construction and structure cut freehand with a "Skillsaw" but I'm sure will be even more precise with a table saw, in any case it works just fine.
    The bottom detail.
    It folds pretty small when not in use.
    Is kind of difficult to see but i use two "Outriggers" (about 18" long aluminum tubes) to hold the end of the tyedowns with great results.
    Well enjoy and John if you can find the proper posting please move this where it belongs.
    slime and Shivanshu like this.
  2. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    15,592
    the hills
    Nice.
  3. kubiak
    kubiak Long timer
    Nov 25, 2007
    4,837
    madera california
    great idea! i made a wood and steel plateform for my 1150gs and have trouble pushing it up the ramp by myself. maybe i can modify mine now!
  4. FatherX
    FatherX Hood Ornament Supporter
    Nov 20, 2007
    11,623
    NE Ohio,USA
    based on what I have seen come from your shop...... I am sure you'll muddle through OK :lol3
  5. kubiak
    kubiak Long timer
    Nov 25, 2007
    4,837
    madera california
    i just lucked out today and my neighbor was giving away a motorcycle atv lift, its just the small one you slide under the bike not a table type though. i still want to modify the wood one though!
  6. Motorrad
    Motorrad Been here awhile
    Dec 28, 2005
    240
    SoCal
    Blue Leg Kx500 Forks?
  7. Ricardo Kuhn
    Sep 20, 2001
    17,315
    Yeap, Part of a GS project that never happen.:cry
  8. VStromTom
    VStromTom Long timer
    Aug 26, 2004
    1,579
    How do you get the thing to stand up on the rear legs? How many people does it take to get the bike up and secured? Looks like a good idea. Your garage makes me feel better about my garage!!!:rofl
    #8
    Bar None and Rockred like this.
  9. Ricardo Kuhn
    Sep 20, 2001
    17,315
    Good question is actually very easy, I can do it everything by my self even if is a little treacherous, I do the lift in two stages using a big floor jack, First I lift the table as high as the jack will go and then using a "prop box" (two boxes, one to hold it, one as a spacer) I re use the jack to bring it up all the way to the top.
    I need to do some work on my 640 pretty soon (After I fix my power washer and clean the floor) and I promise I take pictures of the whole process.
    Oh you need to see it Today is so much cleaner since We just install a Attic ladder and I move a bunch of things up there.
    Ps: You will laugh (well more like cry) about my old apartment (400 square feet) where I used to have all this things plus a ton of bicycles, motorcycle parts, tools and even more crap.
    #9
  10. Desert Skies
    Desert Skies One brick shy...
    Mar 2, 2004
    2,614
    Tejas
    Pretty clever Ricardo. :thumb
    Been wanting to build one out of square tubing. This looks like a great start.
    #10
  11. Ricardo Kuhn
    Sep 20, 2001
    17,315
    Thanks Senor
    My next version (just because I get bored, not because this one does not work) is based on a "Treadmill" platform (Base) in this case one with a "angle/Inclination" feature that will mechanically lift the "Aft" legs using the already existing feature thanks to a really Strong motor and reduction gearbox.
    This wooden structure is very simple and base on a "Low need for tolerance" approach, So you can be sloppy in the fabrication and account for wear and tear and still works as intended, With No possibility of a "Mistake/Failure"
    If you guys want I can take more specific pictures and measurements "A La Martha steward" but sincerely don't see the need.
    #11
  12. Desert Skies
    Mar 2, 2004
    2,614
    Tejas
    The one thing I am thinking is to have the front leg position adjustable via a series of holes in the frame to be able to change the CG. The addition of a removable leaver/handle would give more leverage to lift the ass-end then detached after the rear legs were set.
    This design of yours looks like a great platform to get started. :D
    #12
  13. Ricardo Kuhn
    Sep 20, 2001
    17,315
    I try to have a "Positive CG effect" By locating the front legs closer to the center of the platform, That way the whole platform acts like a "Tiddler todder" (The kiddo balance toy) So you are not lifting the whole weight of the bike like when you have the legs at the very end of the table, In fact next time I will located the front legs even closer to the center for added center of mass advantage.
    #13
    Rockred likes this.
  14. samaza
    samaza intercontinental
    Apr 21, 2009
    71
    Bogota, Colombia
    very nice, a cheap and creative option :freaky
    #14
  15. vanislejay
    vanislejay Been here awhile
    Jun 19, 2012
    599
    Monteal, QC, Canada
    I have been planning to build a lift for a few years and I just got given enough scrap from work that this winter it is going to happen. We just scrapped (aka gave to me) a hopper dumpster and a bunch of 2" square steel framing from a machine we bought and repurposed, so I have more than enough material to do almost anything I want. I even got a small but strong hydraulic ram and power pack to lift it!
    My garage is tight so I am planning on sinking it into the floor so it is out of the way when it's not in use (as if it ever will be)
    I have only used a couple lifts in the past but what do you like/hate about your lift? Has anyone built a lift before? Anything to avoid doing/trying?
    It will be a couple weeks before I get started, but I'll update this thread with photos and design stuff so people can reuse my design work.
    #15
  16. kenstone
    kenstone worn out
    Mar 3, 2013
    1,993
    Boysee
    I did a lot of research on DIY lifts and found many good designs on the net, some with detailed drawings.
    I have the means to build a lift, but not the free material, and ended up buying an HF lift table and have modified it to suit my needs.
    This guy just extended a motorcycle jack:D
    And here's a site with 34 different DIY lifts
    http://www.homemadetools.net/site/search?q=motorcycle+lift&Search=
    #16
  17. kenstone
    kenstone worn out
    Mar 3, 2013
    1,993
    Boysee
  18. vanislejay
    Jun 19, 2012
    599
    Monteal, QC, Canada
    Thanks for the links, but I am looking for specific likes/dislikes of people's lifts, or lift features, not full designs. Like a "I hate this strap positioning because it's always in the way" or "Don't put the support bars too close to the front/middle/side because you will hit your knee on them" or "Don't bother trying to make that back hole to change your tire through" kinda thing.
    Here we are getting somewhere. What did you modify on it and why?
    #18
  19. lynch180
    lynch180 Adventurer
    Apr 5, 2011
    65
    Ireland
    I am in for this one:wink:
    #19
  20. tvpierce
    tvpierce Long timer
    Sep 5, 2011
    1,022
    Maine
    I'm in too. This looks interesting!:clap
    #20
