1. ADVRIDER Print Magazine!
    We're doing two more print magazines year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
DIY Oil seal press?
Discussion in 'The Garage' started by hyland770, Apr 22, 2013.
  1. hyland770
    hyland770 Adventurer
    Mar 22, 2013
    30
    London
    Hi All,
    Im having trouble installing a final drive oil seal behind the front sprocket on a honda xl 250s.
    I wondered if anyone has ever made a home-made oil seal press or has any ideas on how to fit really tight oil seals.
    I tried freezing the seal over night but when i went to hammer it in the lip around the OD of the seal just sheered off, ive also tried heating them up to make them more workable and plain brute force (socket and lump hammer) but its being tricky to get in.
    Its a pretty tight fit but i thought i might try and make some kind of seal press to fit it in, anyone had a go at this before!?
  2. victor441
    victor441 Long timer
    Jul 27, 2009
    3,112
    Sonoma Co., Calif.
    check out www.homemadetools.net, there are a few bearing and seal presses there though most are for automotive work.
    The search engine there is not great, Google site search often works better (here too sometimes)
  3. gsweave
    gsweave Yinz, blinkers are on, JACKWAD! Super Supporter
    Apr 2, 2005
    23,805
    The Paris of Appalachia
    use a plastic bottle, cut open to hold rubber seal lips in...
    use a socket of proper dimension to drive home.
    slip bottle out.
    freezing will only work on a metal bearing.
  4. seniorasi
    seniorasi Banned
    Mar 23, 2009
    816
    Edge of the light
    What an awesome website! Thanks for sharing that one!:clap
  5. bwringer
    bwringer Gimpy, Yet Alacritous
    Jan 22, 2008
    3,322
    Indianapolis
    If the shaft has a threaded hole (like a crankshaft) I use a long bolt and an arrangement of assorted sockets, washers, and nuts to push the seal into place gently.
  6. Laconic
    Laconic .
    Sep 28, 2007
    29,238
    NCNC
    Correct diameter/length PVC pipe over the countershaft with a big washer, use countershaft nut to press in the seal?
  7. wos
    wos Long timer
    Aug 14, 2008
    1,918
    beside the cool pool
    All of the above. use a thin bottle or tin can to protect the inside of the seal and a piece of pvc pipe with a slit in the side, and a hose clamp to tighten it down to the right circumference if necessary. A little grease or oil on the contact points might be necessary.
