DIY storage tube write-up, with locking interface! Vstrom
Discussion in 'Japanese polycylindered adventure bikes' started by zed88, Jul 2, 2007.
  1. zed88
    zed88 n00bilicious
    May 4, 2006
    1,308
    Pingree grove il nw chicago
    Materials needed:
    1 Stanley ¾” double hinge clasp lock 1 2” Section of 4” pipe (either normal, or thinwall)
    1 Waterproof lock
    1 4” End cap for drinking water (you can also use a flat end)
    1 4” female end
    1 4” screw on Male cap
    1 PVC Primer
    1 PVC Cement
    1 can of Krylon black fusion
    1 caulk or other waterproofing agent
    Tools
    Hacksaw
    File
    Screwgun with 1/8th drill bit
    Rag
    Sorry for the poor pictures, I don’t have a digital camera.
    Go ahead and cut the pipe to a desired length (I used 17”) with a hacksaw, and then use a file to remove the burred edges. Wipe all dust off with water. After you have done that sandpaper the edges to get it roughed up a bit and apply PVC primer to both pieces. Then apply Cement to both the inside, and outside of both pipes. Twist the end cap on with a ¾ turn and let dry for 5-15 minutes.
    Repeat this for securing the other end (male/female end).
    Now attach the latch as shown. You will need to drill pilot holes with a 1/8th drill. Make sure to apply some caulk to the back of the screws to maintain a waterproof seal when done. The latch also doubles as a lever if the lid should the lid get stuck. Make sure you have the lid screwed down all the way before installing the hinge. Otherwise it won’t line up!
    After screwing it down and caulking, let it dry for awhile. If you feel like it, you can cut off the screws before you caulk over them. I didn’t mind the little bumps so I left them in.
    Now you can paint it with your desired color. I use krylon fusion because its supposed to bond to plastic good. After it has finished mount it on the bike. Don’t forget to loctite your screws so they don’t vibrate off. I used some steel L brackets, rubber offsets, and hose clamps. I’m partial to how JBH painted his:
    http://www.twtex.com/forums/showpost.php?p=209926&postcount=352
    You can also run a bungee around the lock to keep it from vibrating, and banging against things.
    Congrats, you now have a secure, durable, waterproof, connection that distributes weight low on the bike, and is an efficient use of space. It’s tough enough to get ejected from the bike, and keep all your tools intact. If you are going off-road you can throw your phone and wallet in it. Best of all it was less than $40!
    Eric :jkam
  2. Mr. Ray
    Mr. Ray Glistening Shaft Supporter
    Mar 18, 2006
    5,156
    Pisgah Forest, NC
    Wow!
    I like it.
  3. ADAMD
    ADAMD Been here awhile
    Feb 28, 2006
    208
    Montreal, QC
    That lock is too big for my liking, but a great idea! What about one of those combination lock biners?
  4. RicH2
    RicH2 Ric H2
    Jan 18, 2007
    4,720
    North Alabama
    Huhhh...nice work...now lets see a picture of it mounted on the bike....Please...
  5. zed88
    zed88 n00bilicious
    May 4, 2006
    1,308
    Thanks for the suggestions guys. I will be mounting the givi racks tonight, so I will post pictures when I'm done.
    I think I'm also going to add a piece of foam to the bottom end to decrease rattling and vibrations.
    You can definitely use a smaller lock, I just had this one laying around. A smaller hasp, and smaller lock would blend in better :)
  6. wibby
    wibby BrotherFromAnotherMother
    Mar 20, 2005
    10,971
    Grass Pants Orygun
    Painting it black?
    You do know they make black pipe? :wink:
  7. sbdep
    sbdep Adventurer
    Feb 6, 2007
    15
    Ottawa, Ontario
    The black pipe is the ABS pipe which has a much thicker wall, and is significantly more expensive than PVC pipe. At least around here in Ottawa. 3 feet of 4" ABS pipe for $13 vs 10 feet of 4" PVC for $10. All prices in Canadian dollars.
  8. DrEvil
    DrEvil Been here awhile
    Aug 23, 2006
    245
    right between baltimore and DC
    3$ more? umm, i think a can of black spray paint would be that much, and not look as clean.
    #8
  9. jdub
    jdub Dawg bytes reel gud Supporter
    Jan 7, 2004
    4,215
    S. Central PA
    Must be a regional thing. I've gone to four different plumber supply places in my area (Lowe's, Home Depot, and two small been-around-for-50-years kind of places) looking for the black stuff and they all told me the same thing - "They stopped using that black ABS stuff around here 10 or 15 years ago". Looks like I have no choice but to use black paint too.
    #9
    RedEX likes this.
  10. ddlewis
    ddlewis Long timer
    Oct 27, 2004
    2,489
    South/central Va
    :thumb
    I've been wanting to take advantage of that blank space behind my givi rack too. The piece of pipe with end caps is a no-brainer. As a potato gun smith, I could whip that out in no time..
    Mounting it to the rack in a clean looking secure way is the tricky part. I'll be interested to see what you come up with for that.
    #10
  11. SQD8R
    SQD8R Eat squids and be merry
    Jun 16, 2004
    7,484
    The Village: 52.9144° N, -4.09615° E
    :freaky
    Smart, saw a similar mod done on the 650GS before. Also a good idea is a fake exhaust, there's a company that sells them for the F650. A discarded 1000 exhaust would make an ideal secret compartment. Good job. :thumb
    #11
  12. wibby
    Mar 20, 2005
    10,971
    Grass Pants Orygun
    Mine's pretty low tech, couple strips of UHMW
    It's held so far for over 30,000 miles
    #12
  13. GillaFunk
    GillaFunk I use profanities
    Jan 8, 2005
    4,404
    Penngrove, California (Sonoma County)
    HA.. I was thinking of doing something JUST like this. However, since I took my can off thousands and thousands of miles ago, I was gonna look into installing a false muffler and using it to store all my shit, yet it would look JUST like a muffler, so the cops wouldnt NEVER even look at me. Maybe I can fit a small...eh...."adventure handgun" in there. You know.. for all the big ass Grizzly bears out here in coastal California! LOL
    Sweet write up!
    #13
  14. zed88
    zed88 n00bilicious
    May 4, 2006
    1,308
    I finished painting it tonight. After much head scratching (mounting it is difficult), I figured I was making it too complicated and looked around the garage to see what I had laying around. Lo and behold I found some nice U Bolts, washers and lock nuts lying around. Drill a few holes, and it pops right on. The pictures show the front U Bolt, and then on the rear of the can I used a pipe clamp, with rubber insulator.
    Has anyone ever had the pipe smack the chain guard if you really hit a bump? I tried to retain maximum clearance but I still wonder.
    Painted:
    Bike with my new luggage:
    Looking down from the back:
    U-bolt:
    No pics of the pipe clamp. Sorry
    #14
  15. Stretch67
    Stretch67 Mad Scientist Supporter
    Mar 22, 2006
    24,234
    Bent, But Not Broken
    Now you're talkin'! :D
    I put one together for my cousin a couple weeks back. A large time was had by all.
    #15
  16. wibby
    Mar 20, 2005
    10,971
    Grass Pants Orygun
    I ditched the chain guard the first time I tried doing chain maitenance
    #16
  17. GillaFunk
    Jan 8, 2005
    4,404
    Finally got mine build this week. Turned out not tooo shabby! Painted and mounted. Its a bit snug for all my tools and tire repair crap, but its good enough for me!!
    #17
  18. clawspawn
    clawspawn Adventurer
    Jun 30, 2007
    96
    LAS CRUCES NM
    I like it:clap anny extra space find a use for it:lol3
    #18
  19. Jamie Z
    Jamie Z I'm serious. Supporter
    Oct 17, 2006
    11,012
    Around Denver
    Nice write-up. I have mine mounted on the Caribou rack, totally secure.
    I debated a locking mechanism, but finally decided that the extra complexity wasn't worth it. My view is that if you lock something, people wonder what's inside. I spent two months through Mexico and Central America without a lock and never had a problem.
    Jamie
    #19
    RedEX likes this.
  20. Lobby
    Lobby Viel Spass, Vato!
    Nov 30, 2003
    30,231
    San Antonio, Tx
    Bumping, cause it's a good thread. :evil
    #20
