do i need to refurb my 550 unit (and splash screen)
Discussion in 'Mapping & Navigation' started by hotwheels22, Jun 23, 2017.
  1. hotwheels22
    hotwheels22 motorradRP
    May 29, 2015
    4,112
    austin
    can't use my garmin 550
    1. i can't scroll or zoom on the screen with an accuracy or reliability. is this normal? is there a way to clean it? is the screen trashed and needs to go in for refurb?
    2. after charging at AC outlet the splash screen showing rj garmin plugged into a computer stays on for a very long time. it is hard to know if this is draining battery and i have tried to power it down either the power button but this does not work.
    3. anyone got a tutorial for getting gpx to the unit? i am now putting them on an 4 gb SD card with an SD reader in my mac laptop and using "Garmin" and "GPX" for file structure to put the files in. the card is not mounted i the desktop when it is in the garmin. then i put the SD in the unit.
    should this work?! i can't find them on the unit and had been using a 8gb card.
  2. Quietus
    Quietus Mariner
    Oct 7, 2007
    581
    N.Smirni - Athens - Greece
    1) I have the same issue some times, you can try a screen calibration (press the power button and power on the gps and don't let the button until the calibration screen appears (about 20 seconds or so)
    2) I don't use the ac charger so sorry but no idea.
    3) I think in the past I could also add gpx file in the garmin folder of the SD card and then the zumo could recognise them as routes but nowadays I just open the gpx with mapsource, connect the zumo and use the upload feature of mapsource. Works great everytime.
    hotwheels22 likes this.
  3. hotwheels22
    May 29, 2015
    4,112
    austin
    thanks a lot.
    i will check out mapsource. i'm on a mac but hopefully i can get it to work.
    so, you charge the zumo on the bike with a charging cord of some kind? the only one i found had a "naked" end which i guess you hooked up a cigarette male or SAE or even USB to i guess.
    also, thanks for the tip on calibration. any thoughts on my needing to press about 25 - 30 times for each dot? i keep thinking i need to press harder and then i start to wonder if the screen is busted somehow. super aggravating.
    THANK YOU
  4. mcnut
    mcnut Long timer
    Apr 26, 2006
    1,699
    Bakersfield CA
    As I recall (it's been a while) there is no Mac version of MapSource.
    Bruce
    Quietus likes this.
  5. Quietus
    Quietus Mariner
    Oct 7, 2007
    581
    Mapsource is not availabe on Mac but there is Basecamp that's the new software from Garmin. Works fine too..
    If you need to press 25-30 times each dot seems that something's not right with your digitizer. If you are familiar with repairs you could open the gps and check the connections or you could also replace the digitizer, you can get one from ebay for about $10-20.
    As for charging I'm using the following cable that is connected to the motorcycles electrical system and gives power to the the motorcycle cradle that comes with the bike
    Hi-De-Ho and hotwheels22 like this.
  6. hotwheels22
    May 29, 2015
    4,112
    austin
    ok. thanks for all the good advice.
    i think the digitizer must be messed up. i tried the recalibration and it is different but still bad.
    also thanks for the image. i see nwo that it connects to the battery. for some dumb reason i though i was swing bare wires and thought i had to fabricate my own connection.
    looks like i for another project when i get home and the garmin won't be coming with me on my trip...
  7. cruiser58
    cruiser58 Cranky
    Jun 14, 2009
    29
    Broke in Illinois
    Ogre_fl and hotwheels22 like this.
  8. hotwheels22
    May 29, 2015
    4,112
    austin
    thanks man. i was going to have to go on a deep dive to find those guys. appreciate the link...
    #8
  9. hotwheels22
    May 29, 2015
    4,112
    austin
    hi guys
    tried palmdr last week and haven't heard back.
    any options for other places in case i don't hear from them?
    thanks
    #9
  10. Ogre_fl
    Ogre_fl Long timer
    Oct 13, 2004
    4,030
    Cook Bayou, FL
    He answers his phone.
    Short Tronics, INC.
    51612 US Highway 169
    Mankato, MN 56001-6584
    Phone: (612)326-4364
    #10
  11. hotwheels22
    May 29, 2015
    4,112
    austin
    thanks for the heads up. for some reason i thought i was reading on his site that he isn't doing zumo's and then i must have missed an email.
    thanks a lot. seems like a very easy guy to work with which always helps...
    #11
  12. JR356
    JR356 Long timer
    May 4, 2005
    6,193
    Way out West
  13. hotwheels22
    May 29, 2015
    4,112
    austin
    hmm. wonder what they charge for that...
    #13
  14. hotwheels22
    May 29, 2015
    4,112
    austin
    thanks man. very nice. just so i am sure (and for others needing this) - is this the link...?
    #14
  15. HarveyM
    HarveyM Been here awhile
    Sep 10, 2010
    342
    Ottawa, Canada
    #15
    Hi-De-Ho and Ogre_fl like this.
  16. Twohondas
    Twohondas Long timer
    Aug 25, 2005
    1,282
    San Diego
    I was a Zumo 550 first adopter back in 2006. The screen got a little weird on me in 2010 so I went with a refurbished unit from Garmin for about $150. In 2017 my unit was starting to suffer with buttons falling out and screen degradation. It was working but the Duct tape over the remaining buttons and jury rig button substitutes were starting to wear on me even though I could explain it all by saying heck it is on a KLR!
    Garmin no longer fixes/refurbishes the 550. So I called Chris Short (PalmDr) and talked it over with him. He sent me an estimate. I hit the "I believe this guy" button and sent the unit and a check to him. About a week later I have my unit back and it is working like new! Cost about a $100 including postage.
    So I am believer and I have my trusty 550 back on line. Maybe in a few years I will get another Zumo series but not right now as I went with the economical and effective SHORT solution.
    Edit to add color coordinated Duct tape on Zumo...not considered a feature by many!
    #16
    elmontanero, ohgood, JR356 and 2 others like this.
