Does anybody know of a plug and play battery replacement for the Nav V?
Discussion in 'Mapping & Navigation' started by flybigjet, Apr 21, 2019.
  1. flybigjet
    flybigjet Remove Before Flight Supporter
    May 11, 2016
    1,405
    Denver, CO
    The Nav V works fine, but the battery's not holding a great charge if it's off the bike.
    Any solutions other than paying ludicrous prices at the dealer?
    Plug and play only. Solder guns and I don't get along well.
    TIA.
  2. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    11,409
    central USA
    my local battery outlet has cells and a spot welder, can usually open and replace cells is most packs. They also carry a lot of packs that have worked well for me.
    And ebay, watch the ratings.
    rod
  3. t6pilot
    t6pilot Been here awhile
    Feb 15, 2011
    665
    huntington beach
    Amazon my be your friend
    Type in battery number
    Motorius likes this.
  4. t6pilot
    Feb 15, 2011
    665
    huntington beach
    EBay has them $39.95
  5. flybigjet
    May 11, 2016
    1,405
    Denver, CO
    Model number for eBay or Amazon? I tried a quick search, but I got several different ones. And I'm not home to take the Nav V apart on my bike.
  6. hammick
    hammick Long timer
    Dec 2, 2007
    4,525
    Kansas City, Missouri
    That seems steep. Surly you can find these for $5 shipped from China.
    JimVonBaden likes this.
  7. Blissed
    Blissed Been here awhile
    Dec 6, 2014
    396
    PNW
    Did you try googling “bmw navigator v battery” ?
  8. flybigjet
    May 11, 2016
    1,405
    Denver, CO
    I did-- I didn't have much luck.
    #8
  9. Blissed
    Dec 6, 2014
    396
    PNW
    Tried calling/emailing Garmin support?
    #9
  10. flybigjet
    May 11, 2016
    1,405
    Denver, CO
    On Easter Sunday?
    #10
  11. East End
    East End Bilge Rat
    Sep 19, 2018
    37
    St.Croix, Virgin Island
    I unplug the battery on my Nav VI if it's off the bike for any amount of time. You think it's off but it's just sleeping, as I recall. There's a way to kill it but I can disconnect the battery in about two minutes.....
    #11
  12. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    8,822
    Zer0-Zer0-Zer0-Zer0
    #12
  13. Blissed
    Dec 6, 2014
    396
    PNW
    :-) You could try, but may wait on hold too long.
    My apologies, I assumed you have been looking into it for a while. Seriously, I’d try contacting them. I’d expect that Nav V battery will be identical to those used in other Garmin units.
    #13
  14. Longrider9
    Longrider9 Been here awhile
    Dec 30, 2015
    141
    ONTARIO, CANADA
    #14
  15. Norduro
    Norduro Thumping
    Nov 30, 2013
    372
    Switzerland
    This is true, if you simply switch off the device by pressing the power button it actually only enters "sleep" mode and continues draining the battery. Even if you hold the power button until the menu pops up to "turn off the device" it will still continue to flatten the battery.
    The battery will be drained at a slow rate, but eventually it will be completely depleted - which Lithium ion batteries do not really like much at all. This can permanently damage the battery.
    So, two things to consider:
    1. If you store the Nav 5 for a couple of weeks or even months, make sure to unplug the battery as mentioned by user East End or to charge it from time to time via USB.
    2. Your battery might actually still be fine, try charging it fully and then using it off the bike.
    #15
  16. Lead Wrist
    May 26, 2007
    8,822
    Zer0-Zer0-Zer0-Zer0
    Hmm... I wasn't aware of what original battery was rated as I don't have my V with me... 3.7V vs 7.4V should be ok but I couldn't confirm...:dunno
    #16
  17. BMWGSA
    BMWGSA Geländefahrer
    Jun 26, 2015
    686
    Virginia, Blue Ridge Mountains
    Perhaps you can post pictures as you go along replacing this as I might be needing of one as well
    #17
  18. bikermd
    bikermd Been here awhile
    May 30, 2014
    217
    I too was interested in a Nav 5 battery. Opened up the one in my unit. It is two 3.7v batteries back to back attached to a very tiny circuit board. I have yet to find a replacement battery that you can buy that fits. Garmins part number is # 361-00063-00. 920mah and 6.8Wh. The batteries appear to have 4 connections to the computer board but it also appears that at least one + and - are attached together which confuses me. I did not take it apart further as it is still working (5 yrs old). digi-key part number is 1568-1492-ND. You would need two of them. They are 403040 batteries. All the garmin replacement batteries I found were just 3.7v and not for the nav5. Digi-key has another part number that is two of these batteries together but the wrong connector - it is #1568-1876-ND. Good luck and keep us posted.
    #18
  19. hammick
    hammick Long timer
    Dec 2, 2007
    4,525
    If + and - are truly connected that is a series connection which doubles the voltage of the batteries.
    #19
  20. Blissed
    Dec 6, 2014
    396
    PNW
    I wanted to close this loop, so yesterday I contacted Garmin through their support website asking:
    Please provide info about replacement battery for Nav VI:
    1. What type/model of battery can it be replaced with?
    2. Where can I purchase replacement battery, and what is the price?
    3. Is the same type of battery used in other BMW Navigators, or other Garmin GPS units?
    Today I got an official Garmin email response saying:
    If you are looking to purchase a spare battery for the BMW Navigator VI, you'll need to contact your local BMW motorcycle dealership to do so.
    1. The Garmin part number for a replacement battery is 010-11274-22.
    2. This part can be purchased through you local BMW motorcycle dealership.
    3. The battery for the BMW Navigator VI is a proprietary battery designed specifically for the Navigator V's and VI's.
    If you have any further questions, please reply or call 1-800-800-1020.
    I googled the part number, and found just a couple of hits. In this long-winded video, starting at ~5:30 min, the bloke states that he got his battery replaced by Garmin for free, as the unit was still within 5 years warranty period since activation:
    So, if you think your Nav V is less than 5 years in use you may try calling Garmin. Have the serial number ready. Good luck, let us know!
    #20
