Does the traction control make the bike pull out from a start slower?
Discussion in 'Parallel World (790/890)' started by JohnRansom, Feb 4, 2020.
  1. JohnRansom
    JohnRansom Been here awhile
    Apr 22, 2014
    117
    No. UT
    Pretty much the title. I noticed suddenly the other day that in Rally mode, with Rally throttle, and a slip of 8, it seems like getting started is quite slow. Once going the bike rips, but perhaps the TC is trying to stop me from slipping out at start?
  2. TimC63
    TimC63 BDR Addict Supporter
    Dec 5, 2013
    68
    Seattle Area
    Wouldn't the TC light be blinking if it were intervening?
    TC
  3. JohnRansom
    Apr 22, 2014
    117
    No. UT
    This is true. Maybe its a me thing. I can start the bike fine, it just seems to be a little slow to pull away. Then again, after I moved I had to wait over a year before I got this bike, so maybe I have just forgotten what its like...
  4. Mountainhound
    Mountainhound Long timer
    Sep 25, 2015
    1,808
    New Hampshire
    Could be like in my 19 f350 it controls the massive amount of power differently than my 11 that have the same motor. Actually the 19 is more like the 11 with the programmer and deletes. Anyway the way the power is delivered is much differant much tamer. My 11 would spin the tires at drop of the hat but not the 19. Anyway maybe it has something to do with the ecu controlling the way the power is delivered.
  5. Bamboo Baby
    Bamboo Baby Been here awhile
    Aug 4, 2010
    307
    Port Elizabeth South Africa.
    If you are talking about being on a dirt road, standing still, and pulling away with a handfull of throttle, yes of course it will slow you down. The TC light will flash like crazy.
    Even on a public road, my 790 lights up the TC until 3rd gear. It cuts power, so you can feel it aint moving like its suppose to.
    The ECU wont give, lets say only 60% power, because you are starting to move..
    It will ONLY cut power if the TC light comes on. And that you must control with your wrist :-)
    You are suppose to have 100% power all the time.
  6. TimC63
    Dec 5, 2013
    68
    Seattle Area
    Could also be what you were accustomed to, the 790 is geared a lot different (lower numerically) than most dirt bikes. 16/45 sprockets if I recall? You feel that in 1st gear...
  7. BobcatSig
    BobcatSig They call me... Huckajawea
    Aug 15, 2014
    2,663
    Protestlandia, OR
    I think you mean to say that bike is geared taller?
  8. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,506
    Here and There
    I might be wrong but, the TC light is simply slave to the ECU program (TC) setting... With TC set high (7-9), grab a handful of throttle on a loose gravel / dirt surface and the ECU will cut power (drive) when it senses crazy wheel speed differential between the rear and front wheel speeds.
    Yes indeed, slow(er) to take off...
    The TC flashing madly just draws your attention so that when it does permit hook up, you look up, just as yer heading off into the sticks! :nod
    DAMHIK.
    The TC will not give you 100% ‘power’ unless set to (maybe nearly off) 1 in Rally Mode...
    Is 1 off - 100%?
    #8
  9. Bamboo Baby
    Aug 4, 2010
    307
    When the TC light flashes, it means it is busy cutting power to the rear wheel. It starts to flash when it activates.
    If you dont see it flash, it means you have 100% power to the rear wheel.
    #9
  10. TimC63
    Dec 5, 2013
    68
    Seattle Area
    I believe you are absolutely correct!
    TC
    #10
  11. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    4,781
    Ontario .. Superior
    0 = off. But a key cycle later, and it will no longer be at 0 TC.
    #11
  12. TimC63
    Dec 5, 2013
    68
    Seattle Area
    Hey BobcatSig,
    I think you mean to say my verbiage is incorrect or are you affirming what I said?
    I really did mean lower numerically. Perhaps I could have said the GEAR RATIO is lower numerically. The average D/S GEAR RATIO runs something close to a 15t front and 45t rear sprockets, a 3:1 ratio. Dirt bikes even higher numerically, like 14t/52t or 3.7:1.
    The 790R is lower numerically about 2.8:1, less gear reduction, more top speed, slower acceleration - comparatively. Anyway, my point was simple and yes, taller works!
    Peace!
    TC
    #12
  13. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,048
    SC
    Could it just be the throttle map? I think the default in rally mode is the offroad map which is a good bit less aggressive than the street map. I normally run the street map while in rally mode myself.
    #13
  14. kubcat
    kubcat Been here awhile Supporter
    Sep 22, 2016
    714
    Upstate NY
    Don’t even need to cycle the key. Hitting the start button after a stall resets it even if the key stayed in the on position. I’ve never hit the starter button while the engine was running (duh), but I bet that would reset the MTC and grind the starter gear as a bonus.
    #14
  15. TrailTrauma
    Jan 17, 2012
    4,781
    Ontario .. Superior
    If I wasn't such a master of brevity I'd have included that, and the several other conditions, under which TC0 is expunged. :lol2
    #15
    kubcat likes this.
  16. BobcatSig
    Aug 15, 2014
    2,663
    Protestlandia, OR
    Could be. That's a rather fine point you put on it.
    When I think 'geared taller,' I think bikes with a bigger than necessary countershaft sprocket and a smaller than necessary reach chain wheel. All of which means that the rider really needs to wrap out the throttle or that the rider can't use the higher gears because the gearing is too tall. Hence, tall gearing.
    So... maybe? :D
    #16
  17. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    1,815
    Denver, CO
    If the 790 electric throttle is tuned the same as a 1290 it won't open the throttle 100% until hit 4000 RPM
    #17
  18. TimC63
    Dec 5, 2013
    68
    Seattle Area
    YES! Ultimately, with the 790R, you want to Gear UP (put on your riding gear and go!)
    That was pretty bad, sorry...
    TC
    #18
    BobcatSig likes this.
  19. octagonpilot
    octagonpilot _________________
    Dec 3, 2009
    423
    36.0N 115.08W
    To the OP,
    How much free play does your clutch have?
    #19
  20. JohnRansom
    Apr 22, 2014
    117
    No. UT
    It has the 5mm its supposed to.
    #20
