Dog Ate My Fuel Pump Connector
Discussion in 'Dakar champion (950/990)' started by stageracer, Apr 22, 2020.
  1. stageracer
    stageracer To err is human, to forgive is not company policy
    Sep 23, 2017
    99
    Leucadia, CA
    No joke. I looked out the kitchen window this morning and found that my dog ate the connector for the fuel pump on my 2012 99R ADV. I'm ok with a wrench but really prefer plug and play at this stage in life but I'm ok with rebuilding it if that makes the most sense. There are a few YouTube videos that look pretty easy to do.
    I've looked online and found a used full-assembly on eBay from a 2010 990 with 23,xxx miles on it. Will it work on the 2012? Also, I've looked at some OEM replacements and they list the assembly "without" the fuel reserve sensor. Is there a separate part number for that or is it still in the tank without removal?
    Thanks in advance for the help and please have fun with some jokes at my expense on the title and nature of the post. :ear
  2. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    15,985
    Mill Spring, NC
    Is there a reason you don't want to just replace the connector?
    And yeah,, right,,, dog ate the connector.... :rofl
    braaap! likes this.
  3. stageracer
    Sep 23, 2017
    99
    Leucadia, CA
  4. stageracer
    Sep 23, 2017
    99
    Leucadia, CA
    Not opposed to it if it's not too complicated
  5. GPD323
    GPD323 Been here awhile
    Jul 11, 2012
    457
    Spanaway WA
  6. Boatman
    Mar 9, 2005
    15,985
    Mill Spring, NC
    The connector is "AR". If the dog didn't damage the electrical pins then it would be an easy fix. Remove the pins from the old connector and snap them in the new connector.
    426john likes this.
  7. Boatman
    Mar 9, 2005
    15,985
    Mill Spring, NC
    And as mentioned above Eastern Beaver has it too.
  8. Rharr
    Rharr Long timer
    Apr 5, 2014
    1,093
    Tucson Az
    You can also just buy 3 pin weather Pak male and female connector at the auto parts store, cut the old one off and use the weather pack connector setup.
    If you are lazy any shop can crimp wires and put a plug on. Should be enough slack that losing a 1/2" won't hurt.
    #8
  9. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,891
    SWEDEN, Norsjö
    Replace with Deutsch 2 pin connectors alot easier to work with.
    Done that on some of my bikes.
    /Johan
    #9
  10. charlie264
    charlie264 Long timer
    Oct 27, 2007
    12,070
    Blighty
    Feed your dog........:dukegirl
    #10
    Whodatschrome and stageracer like this.
  11. stageracer
    Sep 23, 2017
    99
    Leucadia, CA
    Thanks for the reference. Which diameter size are the wires? L or R?
    #11
  12. stageracer
    Sep 23, 2017
    99
    Leucadia, CA
    She also chewed the Antigravity Start Battery Harness was next to the fuel pump connector. I guess in her defense, the harness being red, black and blue in color being some of the same colors of her various chew toys probaby didn't help
    #12
  13. Boatman
    Mar 9, 2005
    15,985
    Mill Spring, NC
    Wire size is 0.5mm so either one would work. Like I said above, if the pins aren't damaged, it's just a matter of switching the plastic part of the connector. The plastic part is the same for either wire size.
    #13
  14. Salzig
    Salzig Comfortably dumb
    Oct 17, 2008
    3,168
    Cremona, Italy
    Bet you misplaced the dot, it's 0.5mm.
    We all agree KTM uses the thinnest wires possible, but not that thin :lol3
    #14
  15. Boatman
    Mar 9, 2005
    15,985
    Mill Spring, NC
    Thanks for pointing thar out! Yeah that would have been pretty thin wire.
    #15
  16. my6
    my6 Long LongTimer...
    Sep 11, 2005
    875
    Houston,Texas
    Bringing this thread back to life for a bit. Had to pull my left tank to replace my fuel line and noticed the fuel pump connectors are pretty beat up after three owners. Thanks for the info gentlemen, replacement connectors ordered.
    #16
  17. my6
    Sep 11, 2005
    875
    Houston,Texas
    Well hell. Received an email to night that the shipping charges were going to more then quadruple the price of the connectors. Uh NO! Cancelled and will source a connector locally.
    #17
  18. Boatman
    Mar 9, 2005
    15,985
    Mill Spring, NC
    Eastern Beaver?
    #18
  19. my6
    Sep 11, 2005
    875
    Houston,Texas
    Yes sir. Just found one on Fleabay....WAAAAAAY overpriced. But when you need one, you need ONE.
    #19
  20. Boatman
    Mar 9, 2005
    15,985
    Mill Spring, NC
