Downsizing To A Garagedominium !
Discussion in 'Shiny Things' started by dlrides, Mar 9, 2019.
  1. HapHazard
    HapHazard Be Kind - Rewind
    Dec 30, 2009
    5,754
    Central CT
    ^it seems to me that the impermeable steel would give you an outside vapor barrier, and that putting an interior barrier up as well would cause moisture problems, no?
    I guess those that make the rules always know better...
    plumber mike and villageidiot like this.
  2. GP640
    GP640 Long timer
    Sep 30, 2006
    4,708
    NW AB
    The exterior sheeting probably isn't sealed at the top and bottom.
    :dunno
    interceptor4 likes this.
  3. dlrides
    dlrides 1:1.618 Supporter
    Jul 21, 2005
    9,523
    Cranial Perfection
    Exterior has barrier, interior barrier required supposedly has the ability to breath in one direction, not allowing moisture to be trapped in walls.
    Davidprej and Cogswell like this.
  4. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    14,691
    Orange County, CA
    Interesting. I’m not sure I like that either.
  5. RidingDonkeys
    RidingDonkeys Purveyor of Awesome Supporter
    Oct 23, 2009
    15,238
    Santiago, Chile
    I think it is a high humidity thing. Exterion/interior wasn't code when I was in California. But it most certainly is in NC. I can understand it though. With high humidity in the southeast US, you will almost certainly get some moisture in a wall. Outside temperatures clash with wall temperatures. Internal wall temperatures clash with interior temperatures. If you aren't religiously running a dehumidifier, then that condensation will likely happen inside the wall. This setup minimizes that, and allows what condensation does accumulate to escape in a controlled manner.
    ontrip likes this.
  6. GP640
    GP640 Long timer
    Sep 30, 2006
    4,708
    NW AB
    I guess we do it backward to what's shown.
  7. Cogswell
    Cogswell Now living the new normal.
    Jan 3, 2005
    10,765
    Riding with my pal Richard Cranium
    Yes, allows moisture to exit the wall cavity.
    Looking good :thumb
    dlrides likes this.
  8. dlrides
    Jul 21, 2005
    9,523
    Cranial Perfection
    15 gallon into what looks to be a 30 gallon job this weekend ....................
    ontrip, Laconic and Hannda like this.
  9. HapHazard
    Dec 30, 2009
    5,754
    Central CT
    It really soaks it up, don't it?
    Good idea painting it before loading up the interior.
    Half of my garage is still unpainted (after 38 years).:fpalm
  10. dlrides
    Jul 21, 2005
    9,523
    Cranial Perfection
    Putting OSB in garage (except firewall), and it soaks up primer like a sponge !
  11. Spam16v
    Spam16v Squid Rocket Supporter
    Jan 3, 2006
    1,559
    B-lo, NY
    I opted for 1/2 plywood in my last shop vs OSB. I hate that flaky crap & the cost difference was only a dollar or two ea sheet.
    Maggot12, imnothng and FLYING EYEBALL like this.
  12. pnhd65
    pnhd65 renaissance man
    Oct 15, 2007
    1,166
    central pa
    Sorry, I don't remember seeing you post anything about using OSB prior to seeing this picture.
    I'd have given you a couple of tips.
    Since yours is already up, anybody else reading this, if you're going to use OSB, prepaint it, including edges, prior to installation.
    DL, or anybody watching, the paint to use for a primer is, KILZ Original Formula. It's in a white can, red letters, oil based, it does an excellent job sealing this stuff up.
    I did my shop with OSB, but used white metal roofing, actually liner panel, on the ceiling.
    Prepainted panels, installed, caulked seams, and final paint.
    Looks really good so far, what are you doing for a driveway, pave, concrete, gravel?
    Good luck with the rest of your project.
  13. greenohawk69
    greenohawk69 Adventurer
    Jan 27, 2014
    88
    Yes, the sheetrock needs to be primed before painting. Oil based Kilz works well.
    It's a waste of time pre-painting before install. Once it's up, tarp the floor, get the 5 gallon pails with a screen to reduce excess paint on a roller with an pole and roll away.
  14. pnhd65
    Oct 15, 2007
    1,166
    central pa
    I'm not talking prepainting sheetrock prior to installation, but prepainting OSB.
    greenohawk69 likes this.
  15. dlrides
    Jul 21, 2005
    9,523
    Cranial Perfection
    I was planning on using sculpted Italian marble with gold inlay. I could be convinced to use Iridium inlay due to it’s corrosion resistance, but I haven’t used such in a practical application.
    :dunno
    Yinzer Moto and Cogswell like this.
  16. Spam16v
    Jan 3, 2006
    1,559
    B-lo, NY
    Stay away from Italian, anything but Italian marble for driveways.
    Hannda and dlrides like this.
  17. CodeMonkee
    CodeMonkee Geek Adventurer
    Jul 26, 2001
    7,363
    Orygun
    dlrides likes this.
  18. CodeMonkee
    Jul 26, 2001
    7,363
    Orygun
  19. dlrides
    Jul 21, 2005
    9,523
    Cranial Perfection
    Put all the residence in one end, and that about what I’ll have !
    :lol3
    :clap
  20. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    20,160
    Canada's ocean playground
    Too much fuckery and no windows in the garage. From the M in machine and the M in main, make a line. House area left, garage right.
    Open up kitchen, living, dining for one area. 2 bedrooms don't need 3 bathrooms.
    NEPA 450x likes this.
