DR 650 engine upgrades
Discussion in 'Thumpers' started by payback, Apr 22, 2006.
  1. payback
    payback Adventurer
    Sep 4, 2005
    50
    Fernie, BC
    I've got a stock DR 650 2001, with 12,000kms on it... I'ld like to do some engine upgrades a little at a time, what would be the best, first, easiest upgrade.????? A little at a time, this machine will rip!! Any ideas????
  2. Win38-55
    Win38-55 Been here awhile
    Oct 20, 2003
    653
    Patten, Maine, USA
  3. FatChance
    FatChance Road Captain
    Jun 12, 2003
    13,222
    On the road
    +1 :nod
  4. TWO TRACK
    TWO TRACK n00b
    Apr 17, 2006
    5
    Michigan, Big Rapids
    I don't think you will find alot of factory add on's. FMF has a slip on exhaust But no special head pipes that I've ever saw. You might check into increasing the compression slightly and make sure you add the upgraded base gasket. that with a carburator off a drz 400 might be what you are looking for.
  5. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    11,615
    Golden CO
    sorry, I read DL650 for some reason. SV stuff will most certainly not work on a DR650. Still, you can do the usual carb, airbox, exhaust, high comp, big bore etc stuff. Its pretty much up to how much you want to spend and how much hp you want. You could even install a boondockers kit if you are in a real hurry to get somewhere.
    Saitune (sp?) does full exhaust for the DR and I think yosh might as well. High comp and big bore pistions are available and you could always get a cam ground if you really wanted. Big, flat slide carb couldn't hurt either (first guess would be a 41mm FCR).
    This is a good place to start
    http://www.kientech.com/
  6. joshinthecity
    joshinthecity www.joshinthecity.com
    Mar 15, 2006
    135
    Wollongong, NSW South Coast, Australia
    "Staintune"
    I've got the full system. it's nice.
    Josh.
  7. DurtDigger
    DurtDigger It's just a scratch
    Apr 1, 2006
    184
    Golden, CO
    Where did you get the full Staintune system at?
    Just put my deposit down on my DR650 today. :clap
    Rob
  8. payback
    payback Adventurer
    Sep 4, 2005
    50
    Fernie, BC
    how much more horsepower with that exhaust system??????
    #8
  9. 6Speed4
    6Speed4 Adventurer
    Mar 14, 2006
    78
    Georgia
    on the keintech site they say that the FMF Q2 weighs 5.5lbs and the stock ~15lbs. Is that close? I mean that is a llooooott of weight to drop. I am in the market for a DR and can't help but look at all the possibilities. Looking to build a mainly commuter, occaisional long hauler, and who knows how much off pavement.
    #9
    Sam71n likes this.
  10. joshinthecity
    Mar 15, 2006
    135
    You can get them direct from Staintune.
    www.staintune.com.au
    j.
    #10
  11. joshinthecity
    Mar 15, 2006
    135
    bugger-all...that i can tell.
    j.
    #11
  12. BikePilot
    Jul 5, 2005
    11,615
    Golden CO
    That is about right. I haven't weighed them, but the stock exhuast on most bikes like this is generally made from a lot of really heavy mild steel. I know just the muffler on my dad's XR650L has got to be close to 15lbs +. They approach to exhaust on these dual sports is very very different than on a close course machine (where you'd be lucky to drop .5lbs in most cases).
    have fun
    #12
  13. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,855
    Los Angeles
    Most important before you change anything to the engine, is remove the snorkel on the airbox and fit a Dynojet Stage II kit. Imho this alone makes more of a difference than any aftermarket exhaust.
    And so does lowering the gearing.
    #13
  14. Bald Wombat
    Bald Wombat Dirt Blaster
    May 1, 2008
    3
    Ballina Northern nsw
    #14
  15. plugeye
    plugeye MC rescue
    May 11, 2007
    6,308
    Garland, Texas
    you get squat from exhaust system
    maxcool is right on the money, airbox & dynojet
    leave exhaust alone, if you want to spend on even the cheapest exhaust, your money is 1000% better spent on a flatslide.
    #15
