DR 650 shock swap
Discussion in 'Thumpers' started by HKR, Oct 10, 2019.
Tags:
  1. HKR
    HKR n00b
    Oct 10, 2019
    7
    Netherlands
    Dear,
    Since I am doing a dr 650 suspension upgrade I have a question which I can't find anywhere.
    I upgraded my 1990 bush pig with a yz450f WP upside down fork assembly.
    I would also like to change the rear shock. I bought a very good second hand WP suspension rear shock. Unfortunately, the shock is 43cm. The old one is 38cm. The WP shock is also a bit wider, so it hits the braces that hold the linkages. It also hits the airbox. So i really can't make it fit without removing some material, which i do not want to do.
    My question is. Which rear shocks fits a dr 1990 well? Want to make it a well capable machine off road. So must be a good shock.
    I'm also 1,95 long. So not that light. Dr 650 does not like that. Feels like a pogo stock. :p
    Rebuilding the old shock is to expensive unfortunately.
    I searched for this but only got newer model solutions.
    Since those shocks are longer, that does not work for me.
    I was thinking about a WP suspension shock form a KTM LC4
    My shock specs:
    Length eye to eye: 38cm
    Outside Width top stud: 30cm
    Inside Width lower U bracket: 30cm
    Cheers
  2. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    8,328
    Truckee
    That is some funny brake line routing.
    HKR likes this.
  3. HKR
    HKR n00b
    Oct 10, 2019
    7
    Netherlands
    The brake line is to short. I still need fit a longer line.
  4. MrPulldown
    Aug 18, 2009
    8,328
    Truckee
    That is a long unconstrained span. When the fork compresses there is a good chance that the line is going into the front wheel. Also the fact that it is pointed down then back up is unusual.
  5. HKR
    HKR n00b
    Oct 10, 2019
    7
    Netherlands
    I know.
    Some braces have not been fitted jet for the brake line. it is also not routed the correct way but had to look if everything fit on the poto.
    I agree that looks odd but no, that is how the brake line is orginially routed
