DR350 Thread
Discussion in 'Thumpers' started by leonphelps, May 16, 2007.
  1. Silviu Gheorghiu
    Silviu Gheorghiu Adventurer
    Apr 13, 2017
    32
    Romania
    I never heard a OEM muffler so I don't really know but it has a deep bass sound unmodified. Not too loud but it still bothered me.
    So I did this:
    A variation of my chevron nozzle from the previous muffler. It works and no power loss noticeable.
    Friedom likes this.
  2. DualDog
    DualDog Been here awhile
    Jan 12, 2007
    265
    Galesburg, IL
    1993 DR350S Carb Question:
    I have a 93 DR350S (Street legal version - kick start). I had foot surgery in March and have stayed away from this bike since it is kick start (last year for street legal version before they went to electric start). Now the bike starts on full choke but if you give it any throttle or take it off choke it dies. I assume it needs a carb cleaning and was looking at a rebuild kit. I see there are kits out there for 90-92 and 94-99. Just curious if anybody out there has bought a rebuild kit for a 93. I am not sure if a different carb was used in 93 than other years or what is going on here. I was also thinking about installing a fuel screw to make adjustments easier. I called Jesse at Kientech and it sounds like he doesn't stock these anymore.
    Any thoughts or help here would be appreciated.
  3. vagabondmatt
    vagabondmatt '99 DR350SE
    Jun 26, 2014
    389
    Greensboro, North Carolina
    FWIW for both my old '93 kick only dual sport and my current '99SE, both bikes behaved very well after a thorough carb clean without rebuild kits. I made sure the tiny ports were open using thin steel guitar strings, that the float o-ring was in ok shape, and that the diaphragm was not torn.... and used a can of carb clearner. Good luck!
  4. Friedom
    Friedom Onward and upward!
    Mar 3, 2013
    4,376
    The Golden City of Tucson
    plugged or partially plugged pilot jet. Clean it or replace it. 37.5 Mikuni.
  5. Dirtnadvil
    Dirtnadvil Long timer
    Dec 22, 2005
    1,043
    Inside the Orange Curtain
    I understand what your referring to. I have a couple of after market tanks for my DRZ and there is a bunch of fuel I can't get to, so it is basically extra weight and a false capacity rating for the tank.
  6. thump!
    thump! Adventurer
    Jan 16, 2007
    4,369
    Northeast Tennessee
    for mikuni carb stuff procycle.us or moto-lab.com
  7. miniboxer
    miniboxer Adventurer
    Jan 15, 2011
    85
    You can rotate the intake on the carb by 90° to a horizontal position -> this allows to fully use the 4.2 gallon from the Acerbis tank. Alternativly you can use a petrol pump.
  8. plugeye
    plugeye dreamer
    May 11, 2007
    6,011
    Garland, Texas
    this is a clarke 4.2 gallon, yamaha petcock & BST33. smooth fuel line path
  9. motolab
    motolab Long timer
    Feb 16, 2006
    5,881
    I have a kit in stock that fits your '93 S model. Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, main jet access plug o-ring, fuel screw o-ring, slide guide o-ring, two felt throttle shaft seals, two stainless steel socket throttle blade screws and instructions. All o-rings in this kit are FKM (aka Viton).
    Regards,
    Derek
    hondabtr, Friedom and MrPulldown like this.
  10. tatt2mike
    tatt2mike Been here awhile
    Sep 29, 2016
    232
    XRL650 5.8 Acerbis all the way! Check out the bike specific thread index. Good chit.
  11. tatt2mike
    Sep 29, 2016
    232
    Anyone have a good rear spring for a 220# rider they would like to part with?. Racetech calls out 5.8kg as stock and recommends 6.1kg for my riding type. they offer a 6.7, 7.6, 8.1 kg.
  12. DualDog
    Jan 12, 2007
    265
    Galesburg, IL
    Thanks for the replies regarding the 93 DR350S carb issue. Motolab, I sent you a private message.
  13. Hugh B
    Hugh B Adventurer
    Jul 8, 2008
    42
    Sycamore, IL
    @Luketj2 I was having the same problem on my Dr. I checked the switches and they were good. It turned out to be a bad wire in the taillight. HTH
  14. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    6,662
    Truckee
    So this question is for you guys that have built engines from the bottom up (or feel you know). Been read that a crank and side cases are matched. One should NEVER swap a crank from a different engine into the a case. How true is this statement. School me.
  15. Friedom
    Mar 3, 2013
    4,376
    The crank sits in the bearings, not the case directly. You could definitely move a crank to a different engine. Case halves might be matched to each other, I've never heard this definitively answered.
    buzzword likes this.
  16. 2old2Bbold
    2old2Bbold was 2bold2getold
    Dec 10, 2011
    3,825
    Arlington, Texas
    From my experience, cases are matched, cranks are not.
  17. Anonawesome
    Anonawesome Scenic Rider
    Feb 2, 2010
    2,228
    Head in ID, heart in OH
    Pretty sure the cases are cast in one piece, then cut down the middle. By mixing cases, you don't know what condition the casting mold was in that day, and if each half will align properly. But yeah, bearings should make crank swapping a non-issue.
  18. 2old2Bbold
    Dec 10, 2011
    3,825
    Arlington, Texas
    Don't know how they are cast, but the story was... they are machined in pairs. Not sure if that's really the case but I wouldn't want to take the chance.
  19. Friedom
    Mar 3, 2013
    4,376
    Outside of 3d printing, I don't think you could manufacture a case in once piece.
    This is based on my casual armchair expertise though.
  20. brownvv
    brownvv Been here awhile
    Sep 23, 2012
    936
    colorado
    I am running that same muffler on both my bikes. I like it allot but yes it is slightly louder than stock
