DR350 Thread
Discussion in 'Thumpers' started by leonphelps, May 16, 2007.
  1. thatonetylerguy
    thatonetylerguy Been here awhile
    Aug 23, 2016
    136
    Portland, OR
    Yes. I'm inexperienced and nobody I know rides. Sometimes I have to ask dumb questions cuz I have no one else to ask.
    Hamburgerhotdog and Ibraz like this.
  2. everready
    everready Stuck in Ohio....Ugh!!!
    Jul 1, 2013
    3,419
    Macedonia, Ohio
    No worries. We all have to start somewhere. I thought you were just trolling.
    Ask away...................
    thatonetylerguy likes this.
  3. Dirtnadvil
    Dirtnadvil Long timer
    Dec 22, 2005
    1,146
    Inside the Orange Curtain
    I know this is an old post, but I'll chime in on the WR250R. For a guy who is 6'5" I think you'll find the WR too small and cramped. Im 6' nothing and the main reason I sold my WR was how cramped I felt. It was a great bike after I had it restrung and valved for my weight, how ever the bike requires a lot of shifting if your 200 lbs. If the bike was slightly larger and a 450 it would of been perfect
  4. Greg Bender
    Greg Bender Long timer
    Oct 22, 2007
    1,756
    Cave Creek, Arizona, United States
    That is good to know. I need to swap bikes with my friend one day and try his out. At 6'2", I already find the DR350 small (mostly corrected with lower foot pegs and handlebar risers).
    Regards,
    Gregory Bender
  5. Jeff@TheQuadShop
    Jeff@TheQuadShop TAT survivor
    Nov 28, 2004
    7,655
    Crestwood, Kentucky
    I'm 6'1", the Fishers seat and ROX risers made all the difference for me.
    Greg Bender likes this.
  6. brianpeck
    brianpeck Been here awhile
    Apr 9, 2017
    291
    Santa Barbara, CA
    Ended up finding both side plates & bolts for $9 shipped on eBay, figured for that price it wasn’t worth it to bug either of you. Thanks though!
    plugeye and Jeff@TheQuadShop like this.
  7. Friedom
    Friedom Onward and upward!
    Mar 3, 2013
    4,975
    The Golden City of Tucson
    I did a 385. It pinged. High octane fuel solved it. Then I made a different bike a 441 from Thumper Racing. No compression bump with that kit, less pinging there but it's there if you lug it when it's hot(see above posts).
    All in all, after having 8 of them I'd say if you don't like the DR in stock form(maybe accessorized), then go find a bike that you do like rather than trying to make this bike something it's not. After big bores, big tanks, big forks, my favorite is a 99 kicker with an improved seat.
    plugeye likes this.
  8. Friedom
    Mar 3, 2013
    4,975
    Fixed my bike. Decided that it was worth checking the remote possibility that something was wrong in the wiring, so I unplugged all nonessentials and it fired up.
    Turns out I had the power going to the handlebar switch from the red/white wire and bikey no likey. Also explains the burned headlight bulb.
    She's baaaaaaaack!
    Also swapped a fender on it that I think looks better, snugged up some bolts, tightened up the kick stand play, welded on a nub to stop the kick stand from going so high and leading to rubbing, replaced headlight bulb, wiped things down and took pictures and test ride.
    And the carb is SUUUUPER clean now, o rings updated, valves adjusted, cam checked, she ready to play.
    DR for sale!! Haha only real problem she ever gave me was when I plugged in the wrong wire.. 20191004_134256.jpg
  9. law1200
    law1200 Adventurer
    Oct 2, 2019
    41
    South Carolina
    I am very pleased with the power I gained from the 385 and after adding the exhaust the pinging is almost gone. I Can live with it I was just wondering if anyone had found a solution to the pinging.
    With the money I spent for the bike the engine kit and machining the cylinder am at $1500.00.
    My budget to get into the adventure riding was $2200.00 so after upgrading the engine I spent some money on some goodies like the trial tech Pro a large fuel tank HID head light fork springs couple ram mounts for electronics.
    It's not as powerful as the DR400 or as fast but I am happy with the old bike, it gets the job done and is reliable to boot.
  10. law1200
    law1200 Adventurer
    Oct 2, 2019
    41
    South Carolina
    Just wondering which cylinder head is preferred by riders with the kick start engine Auto or Manual?
    Please chime in. I have a manual and was wondering if the auto would be better.
  11. Btown Jason
    Btown Jason MotoChimp Supporter
    Sep 17, 2012
    200
    Bloomington, IN
    Has anyone here mounted both a Corbin seat and an acerbis 5.8 gallon tank (the one meant for an XR650) on their DR350SE? I have the Acerbis tank on the bike already (bought it that way) and just bought a Corbin seat. Now I can't get the thing mounted and I'm thinking that moving the tank a bit is gonna be my only chance at getting the seat on the bike. Any wisdom out there?
  12. Friedom
    Mar 3, 2013
    4,975
    Definitely the auto decoompression head. Furthermore - the dirt model cam is much friendlier on the foot than the SE cam. The decompression mechanism is a little different between the two. I could start my 99 dirt model in sandals. Sometimes it would start while I was priming it to be ready to kick.
    There's a good bit if play in the mounting of the tank. Certainly more so than the Corbin. You might need to modify the rearmost tank bracket, depending on how it was done. Just make sure you still have lock-to-lock steering when you move the tank forward.
    Btown Jason likes this.
  13. V-Stormer
    V-Stormer Bush Basher
    Aug 23, 2009
    394
    Vancouver Island, Canada
    TM33-8012 question . . . Is the throttle shaft on the carb supposed to go 100 % of it's range from idle-stop to end-stop when using the throttle?
    I can move the shaft by hand that way, but using the throttle it only goes 80% of the way. I've tried every adjustment possible on the push-pull cables, which I got from a TM33-8012 kit custom made for the DR350se. But no cable adjustment combination works. If I try to unscrew the in-line adjuster any further it will increase range, but things start to bind and not move freely. I had a similar issue with the stock push-pull cables. So I'm wondering if 80% travel is normal?
    Can anyone confirm what their throttle shaft rotation range is on a DR350 with a TM33-8012 and stock throttle tube setup? (I know you are out there!)
    I increased the pilot and main jets both a size up for my 440 big bore kit and it's running great. Barely perceptible hesitation at one point and lots of power. Can go from 60km to 100km in a few seconds in sixth gear. Passing is no problem. So I'm riding and enjoying it as-is for now until I can get a well informed answer. I've emailed Mikunioz and will ask a local shop I trust about carb stuff.
    (Been a while since I've been on this thread and man has it gotten big! . . . over 3,000 pages! . . . must be a record)
  14. V-Stormer
    Aug 23, 2009
    394
    I wanted to provide an update on this oil pressure indicator modification . . . it works like a hot damn!
    I can tell when the oil level is low, because when I come to a quick stop, the LED light flickers a bit. Usually at that point, the oil is around the bottom of the stick. When I fill it, it seldom if ever flickers. I think that's because there is not enough gravity feed when the oil level is low to keep the pump full of oil and pressure well above the switch cut-out point momentarily when coming to a quick stop or fast deceleration.
    One thing I've noticed though is that the connection needs to be waterproofed. When riding in wet weather, my heart kind of stops when I see the light on steady. Especially after I go through a puddle in the middle of who-knows-where! But after a few min of driving (if it's not raining), it dries up and it goes away. I might solder a short wire to the spade connector on the switch with a waterproof connector on the other end and then use some silicon or other goop to seal up the spade connector.
    But overall , this has been a great mod and saved my butt a few times when I wasn't expecting the oil to be low. Definitely would save my butt in a leak situation.
  15. turboguzzi
    turboguzzi Casual rooster
    Feb 9, 2017
    43
    Milan, Italy
    solution depends on how well the squish area was brought to a good height value. If you mounted your big bore without making a check, then do one with 1/16 solder ASAP :). Would aim for 0.9mm by milling the cyl.
    Stock is most likely above 1mm (mine measured 1.17), so it cant help much with stopping detonation/pinging
      File size:
      106.4 KB
      26
      File size:
      131.4 KB
      25
      File size:
      156.1 KB
      23
  16. Andreim92
    Andreim92 Lost
    Dec 10, 2016
    120
    RO
    Any tall and heavy guys around here? I'm about 6feet6 (1.97) and 240 (110kg) and thinking about possibly getting a little brother for the Africa Twin.
    I really tried getting technical with my first one, the Transalp, now with the AT, I learned a lot of stuff, but of course , as you know, those bike are heavy as shit and I really want to improve my riding ( not necessarily jumping off cliffs but small jumps I would like).
    I heard the bike bike has some frame flex and some cases with swingarm flex. Would like to get a SE model but at the right price would get a kickstarter.
    So my questions are...
    1. Are other fat blokes like me riding the DR hard-ish than can calm me down? (Enduro not MX)
    2. Is the flexing i mentioned above a problem?
    3. Will the bike hold my fat ass ok after a resprung?
    Thank you, Andrei
  17. Dirtnadvil
    Dec 22, 2005
    1,146
    I had the headlight cowling off doing some work and I noticed a wire connector with a brown and a black wire. Is this for the Euro model or something else....Thanks
  18. hellotimmutton
    hellotimmutton Been here awhile
    Oct 24, 2016
    241
    This mod seems like it should be an essential one for DR owners, given that oil starvation appears to be the #1 killer of these bikes. If you were to do it again would you stick with the adapter setup or just buy a slightly oversized one and machine it to the correct thread?
  19. V-Stormer
    Aug 23, 2009
    394
    I think either way would work equally as well, but it might be a challenge finding a oil pressure switch with threads larger than the size of that plug in the type and range you'd need. The adapter way was just easier for me in my garage shop. The thread pitch was wrong, so the other method wouldn't have worked for me because the thread was already the same size as the hole. Drilling out and tapping the plug, then taking the thread down on the switch seemed the best way at hand at the time.
    The key is locating the right kind of switch - a normally-open oil pressure switch that will close at about 3 or 4 psi (minimum pressure). The one I ended up with was a switch for FIAT 131 Mirafiori 2.0 Racing car - and purchased from the UK. Unfortunately the link I have for the one I bought doesn't work anymore. :(
    But if you could find one to that spec and had a large enough thread you could strip it and make the correct size and pitch thread to fit the plug hole, that's probably less work. Less steps in any case.
    As for oil starvation (which I think most often occurs in the valve head), I'm not sure how much this switch would help, other than in a no-oil or faulty pump situation. If an oil passage to or from the head is the culprit, the oil pressure light would still go out once the pressure goes above 4psi. It also doesn't tell you what the pressure is, just that it's above minimum. A gauge sensor instead of a switch would give you a better idea of whether the pressure is weak, but above minimum.
  20. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    11,760
    Southern Louisiana or Southern England or ...
    A blocked oil passage is almost never the culprit. Low oil level is.
