DR350 Thread
Discussion in 'Thumpers' started by leonphelps, May 16, 2007.
  1. dbarale
    dbarale Squiddly slow
    Oct 20, 2008
    2,716
    Western NC
    I posted some passenger pegs and factory mudguard/tag light/bracket in the flea market section. Please let me know if my pricing is off.
  2. hellotimmutton
    hellotimmutton Been here awhile
    Oct 24, 2016
    241
    At the stage of my engine disassembly where I need to split the case. A proper case splitter costs >=$124 (why is australia so expensive for everything?), but Ive seen some people suggest a harmonic balancer puller ($20) can get the job done, just wondering if anyone heres done that and how it worked out
  3. everready
    everready Stuck in Ohio....Ugh!!!
    Jul 1, 2013
    3,417
    Macedonia, Ohio
    https://www.rockymountainatvmc.com/...tm_term=description&utm_content=youtubevideos
    Not exactly cheap but better than $124.00.
    If you're handy you could probably make one. There are quite a few videos on YT.
  4. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    821
    A case splitter is an awesome tool.to have, if you're likely to split cases more than once per year. If not cases can be split with elbow grease, patience, and a rubber mallet, which is much less expensive. Just don't get tempted to shove a screwdriver in there and pry, you'll likely ruin.the mating surfaces. Best of luck!
  5. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    8,323
    Truckee
    Are there pry points on the case. A section that has built up material intended for a screw driver. I recall seeing a pry point somewhere on the bike before. The head? Rocker cover?
  6. plugeye
    plugeye MC rescue
    May 11, 2007
    6,796
    Garland, Texas USA
    me too. clutch cover?
  7. mentolio
    Jul 14, 2016
    821
    Built up spots, yes. That's where I hit the cases with the mallet. Pry points I do not remember being there. Between the built up spots on the cases, and smacking the shafts while pulling on the cases, my 250 came apart pretty easily. Not as easily as with my new Tusk splitter, but pretty easily.
  8. V-Stormer
    V-Stormer Bush Basher
    Aug 23, 2009
    394
    Vancouver Island, Canada
    I split my cases with elbow grease...can’t remember if I used a rubber mallet or not but I’m sure one was probably involved. I believe I used multiple plastic and/or wood wedges carefully placed where the cases had thick material once I got a bit of a split going. I’d tap them only a small bit at a time going around all of them. I think how I got the initial split going was to wedge inside the case well enough below the rim of the head surface as to not damage that surface or crack or chip anything on the case. I went very slowly, gently and carefully throughout the process, never forcing it. If something seemed too stuck, I stopped, reassessed and was prepared to stop entirely if I needed to.
    But as previously suggested, check online for DIY case splitter ideas. I just bought a spare DR350SE bottom end to build a spare engine to keep on the shelf and I’ll probably go the DIY splitter way when I get to working on it.
  9. hellotimmutton
    Oct 24, 2016
    241
  10. Boblosi111
    Boblosi111 Adventurer Supporter
    Jul 6, 2019
    32
    Indiana
    Seems like working on 20 - 30 year old dual sport motorcycles lot's of elbow grease needed sometimes even with the right tool!
    Just about done with a complete tune up & maintenance end to end top to bottom, on my 91 ds350s. At this point I'm quite pleased with how it's going. But very nice to have a twin dr350s (low miles) I've been riding in the meantime. So much elbow grease used but I know just what I got now. 8500 miles and she's rock solid now. I feel a smile on my face just typing this. If I was gonna do it worth doing it right
    BikePilot likes this.
  11. V-Stormer
    Aug 23, 2009
    394
    I found this solution to be intriguing . . . https://kdxrider.net/forums/viewtopic.php?f=77&t=17772#p162123
    Looks to me like a harmonic balancer puller which I've seen on amazon.ca for $29 Cdn (close to Aud). They're advertised locally all over the place for about double that. I'm going to check out locally first and see how large they are. I have old (broken) cases that I can measure up against. Some kit's include long 8mm and 10mm bolts, but metric ready-rod would also work if you can find it at a fastener supply store.
    thump! likes this.
  12. everready
    Jul 1, 2013
    3,417
    Macedonia, Ohio
    Do you have Advance Auto or Auto Zone stores, or stores like them in Aus? If so, you might be able to rent a puller. You 'buy' the item and when you return it, you get all of your money back. It might be worth checking into. Even a generic gear puller might work.
    DBamaC likes this.
  13. plugeye
    plugeye MC rescue
    May 11, 2007
    6,796
    Garland, Texas USA
    +1
    steering wheel puller or the like should work fine.
    every shop needs one
    thump! likes this.
  14. MrPulldown
    Aug 18, 2009
    8,323
    Truckee
    Getting cold out here. Throttle side grip heater went out. Finger tips were frozen by the time I got home from my after work commute. Burrrrrrr.
  15. plugeye
    plugeye MC rescue
    May 11, 2007
    6,796
    Garland, Texas USA
    dang, still wearing hunting vest and no gloves. shorts to the gym
  16. Ibraz
    Ibraz Been here awhile
    Feb 11, 2017
    465
    Québec
    Is your chain contacting the aluminum underside or just the black chain guide in front? My chain is adjusted to a little less than 1.5 inches or so, andlooks like this when I pull it up to the swingarm:
    Yeah, I know...I really should make putting a rear chain guide on this thing a priority, but...
    I leave it a little loose like this, as the bike seems happier with it this way. I run a 14t front sprocket (little if any effect on the slack) and a 52 tooth rear (which may have some effect). A smaller rear sprocket like a 42t (which I think is what most of the 350s come with stock?) would likely have the chain slapping the aluminum if set up like mine. If in ONE click you're going from "chain slapping aluminum" to "too damned tight," there's something wonky going on. I would suggest putting your rear wheel in the air and slowly turning it while observing the chain closely. If while rotating the rear wheel you notice the chain going from slack to tight and back again, you likely have a "tight spot" in the chain. When you ride doe you hear a "wurrrr-wurrr-wurrr" noise coming from the front sprocket area that speeds up and slows down with acceleration/deceleration? And remains constant at steady speed? If you experience this, also a dead give away for a damaged chain. A "tight spot" is a section of the chain that either stretched significantly more or less than the rest of the chain.
    I know you said your chain is new, but who makes it and where did it come from? My original brand new chain was a DID that I ordered from eBay. It was very inexpensive, and the first one I ordered I put on my buddy's D350, and it's been fine. "Same" chain (same model ordered from same seller, I mean) on my anemic DR250 needed adjustment after every ride for the first 1000 to 1500 miles, until i ran out of adjustment and replaced it. Moral of the story: I either got a defective DID chain, a counterfeit chain, or my DR250 makes more power than any DR350 (least likely of the options;)). Could be your new chain is a POS like mine was, and now you may have a tight spot (or three) in it. What are your sprockets like? Did they get replaced with the chain? Sometimes you can get away with just doing the chain if the sprockets are worn evenly and very little, unlike this front:
    View attachment 1864058 View attachment 1864059
    Old front sprocket, less than 1500 miles, and the suspect chain.
    If you look closely at the sprocket, some of the teeth seem to be directional/pointing in one direction like a claw. No bueno. Either my sprocket was also a counterfeit (rear sprocket showed none of this wear), or the "bad" chain caused it to wear prematurely. I use a Bikemaster chain now that a friend turned me on to. It's an x-ring, doesn't cost a fortune, and is tough as nails! In about four hundred miles I've adjusted twice, and it's now holding steady adjusted as-is.
    Check the chain and sprockets as I said and let us know what you find. Hope this is some help?[/QUOTE]
    The chain is a lot slacker than in your picture, I'm able to push it against the underside of the swingarm with absolutely no resistance yet on the "next" adjustment tooth it is tight to the point of not having any play.
    When I did the first adjustment I was at a friend's place and I think the rear axle was under tightened. Riding the bike like this may have gouged the adjusters (not visibly) or the axle.
    I'll have a bit of time tomorrow to check things (I'll try rotating the axle).
    The PO gave me a bill from the shop that did the tune up a few days before I bought the bike. Same shop who changed the filter and missed the O-Ring, and same shop that said that the bike was ready to braaap and needed nothing even though it had a loose primary nut and carb needed an overhaul + clutch basket is dragging (first single cyl and carbureted bike for me so I trusted them).
    It'll get a new chain and some internal (clutch basket + valves + gear selection stopper) work this winter just to be sure (I'm not able to ride it at the moment so it's condition won't deteriorate.
    Can't trust the PO or the shop that did the work.
  17. Thedktor
    Thedktor Adventurer
    Mar 10, 2019
    65
    United Kingdom
    I have done many without a puller. What you need to consider is that most have a "fixed" side where the crank is a semi-interference fit on the main bearing so the first stage is to open the cases leaving the crank on the flywheel side in the left case. ie. pull the right hand case off leaving crank and gearbox parts remaining n the left case.
    The manual mentions this. The gearbox shafts and cogs come out easily, then get a hot air gun on the left crank bearing, you may be lucky and the crank will come out of the bearing, or the bearing may come out with the crank.
    So to reiterate - all the shafts on the RH side will slide off the bearings, with a little help from a rubber mallet ;)
    V-Stormer and hellotimmutton like this.
  18. thatonetylerguy
    thatonetylerguy Been here awhile
    Aug 23, 2016
    136
    Portland, OR
    I think you got the wrong guy. I don't remember posting about a problem with my chain other than it was super rusty.
    Thank you for all the detail though. Stuff like that still helps.
    Ibraz likes this.
  19. V-Stormer
    Aug 23, 2009
    394
    I was having lunch with some riding buddies yesterday and one of them bought a Royal Enfield Himalayan. To my surprise, it has an oil cooler the same size as mine, placement is the same, mounting is almost exactly the same way, with oil lines that are similarly placed on the engine to the DR350. This cooler would almost be a turnkey fit compared to my custom built one. I'm also guessing that Enfield parts are going to be quite a bit less expensive. If this had been available when I was building mine, I'd have tried to get these parts and may end up doing that anyway in the future. Here are some pics.
    I'd order the cooler, mounting bracket, and the lines. That gives you the proper connections to the cooler and the pipes coming off of them are just short with hoses attached. There is the banjo bolt on the DR for the oil coming off the head that would need to be figured out and the return to the oil tank, but I think that would be easier to solve than all the stuff I had to do for mine. Something to consider anyway.
    Greg Bender and OHjim like this.
  20. hellotimmutton
    Oct 24, 2016
    241
    Hamburgerhotdog likes this.
