1. eNewsletter Sign Up
DR350 Thread
Discussion in 'Thumpers' started by leonphelps, May 16, 2007.
  1. Greg Bender
    Greg Bender Long timer
    Oct 22, 2007
    1,737
    Cave Creek, Arizona, United States
    Over the past several months, I've noticed progressively increasing fuel consumption, progressively increasing oil consumption, and progressively decreasing overall power. I decided it was time to give my DR350 some love and investigate. Check out the photo, I'm pretty sure I've found the problem. Top ring speaks for itself. Middle ring is stuck. Oil ring still rotates well.
    Hamburgerhotdog likes this.
  2. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    11,284
    Southern Louisiana or Southern England or ...
    Uh-oh!
    Is that a stock piston?
  3. Greg Bender
    Oct 22, 2007
    1,737
    Yes, 100% stock. Original piston from the factory with ~39,000 miles on the engine.
  4. everready
    everready Stuck in Ohio....Ugh!!!
    Jul 1, 2013
    3,341
    Macedonia, Ohio
    Why does the piston crown have the step in it? Is that normal?
  5. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    8,169
    Truckee
    Wonder how many times that piston went up and down in the 39K miles.
    No not normal.
    The chamfered top edge looks to be normal-ish due to wear. The wear in the top ring grove is crazy though. Looks like the end of the ring wore the extra width; just a little bit with every stroke. Pretty cool actually.
    everready likes this.
  6. plugeye
    plugeye MC rescue
    May 11, 2007
    6,660
    Garland, Texas USA
    hey greg,
    have any numbers to compare? fuel & oil consumption vs. time
    looks like you had maybe another 30K before all hell broke loose
    MrPulldown likes this.
  7. everready
    Jul 1, 2013
    3,341
    Macedonia, Ohio
    What does the cylinder look like?
  8. Greg Bender
    Oct 22, 2007
    1,737
    Here's the cylinder. I'll have my machinist take a look at everything.
  9. Greg Bender
    Oct 22, 2007
    1,737
    I don't have any super scientific numbers, especially with oil consumption. I just know that it was going up.
    Fuel economy is also a bit difficult, because different routes I ride have more/less high speed pavement to access them. But, here are three MPG I observed riding very similar routes on subsequent weekends:
    • 50.25
    • 47.76
    • 46.55
    Also, when I was in St. George riding with friends a couple of weekends ago, I noted that I got substantially worse gas mileage than he did. He and I have been on enough trips together that I know we are always fairly close.
    The big clue for me was when I removed the intake boot and a LOT of oil ran out of it. I knew I needed to look further.
    Regards,
    Gregory Bender
  10. MrPulldown
    Aug 18, 2009
    8,169
    Truckee
    Wonder how many DR350 pistons look like that and jsut keep on chugging along
  11. slartidbartfast
    Dec 23, 2003
    11,284
    Greg Bender likes this.
  12. Greg Bender
    Oct 22, 2007
    1,737
    Yep, I knew something wasn't quite right, but it still ran a lot better than I would have expected.
  13. turboguzzi
    turboguzzi Casual rooster
    Feb 9, 2017
    42
    Milan, Italy
    Greg
    Had very similar failure, actually lost a bit of piston crown, had me quite miffed, never happened to me even in my vintage road race engines that often see WOT and 12K rpm... my only explanation is the stock lean jetting of 127.5 on the CV carb. I switched at some point to 140, bike runs lots better, but i guess that the slowly overheating damage by the PO started the crack. 1997 bike with 20K miles BTW
  14. memopad
    memopad Been here awhile
    Aug 28, 2017
    251
    UP Michigan
    I know exactly where most of those pictures were taken. Fun place to ride
  15. slartidbartfast
    Dec 23, 2003
    11,284
    That looks like the failure was next to the intake valves. I'd expect a heat-related failure to have been on the exhaust side.
  16. Greg Bender
    Oct 22, 2007
    1,737
    I'm not sure what the cause was...might be just the piston just wearing out. I'll wait and see what my machinist says.
  17. turboguzzi
    Feb 9, 2017
    42
    Milan, Italy
    yes and no.... see the pic, the valve reliefs for the intakes are very close to the top ring groove, hardly 2-2.5 mm of meat at the nearest point, easily the weakest point in the crown, the exhaust valve reliefs are further away from the edge ring groove. if bike was working at edge of detonation for a while and piston heat stressed, material would crack where its thinnest IMHO.
    the whole underside of the piston shows general overheating, dont see particular hot spots under the exh reliefs honestly.
    if you have other explanation for the failure, im all ears :)
    no signs whatsoever of valve to piston contact BTW.
    Greg, what jetting and what carb are you running?
  18. slartidbartfast
    Dec 23, 2003
    11,284
    Fair enough - thinner metal failing first makes sense. Detonation not so likely in a stock DR engine I would have thought. I had some minor pinging in my DR after I trucked it from High-altitude Colorado back to Louisiana. The tank probably had 85 Octane in it.
  19. Friedom
    Friedom Onward and upward!
    Mar 3, 2013
    4,870
    The Golden City of Tucson
    I had similar failure in the same area on the latest DR that I fixed up. The engine still ran, but the piece of ring that snapped off and embedded itself into the head made enough noise to get the PO to stop running it.
    Greg: are you considering a big bore?
  20. Friedom
    Mar 3, 2013
    4,870
    Heads up, if anyone is considering a Lectron..
